M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      02-11-2017, 05:45 PM   #1
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
Wheel Spacers 10mm or 12mm??
Now I have read all the threads and checked for pics. My issue is, on my last cars when I have run spacers I always end up rubbing when no one else does. I have a 13 M5 stock height and 343 wheels. I wanted to run 10mm all around to play it safe with any rubbing issues. Then I read the MS spacers had issues in the 10mm sizes. Would this be consistent with other brands? I just want the wheels to come out a bit more to look nice. Im afraid the 12mm up front may be too much. Pleas let me know your thoughts, thanks!
      02-11-2017, 09:31 PM   #2
KMORGSM5
KMORGSM5's Avatar
320
Drives: 14 CP M5
I have 12mm front and 10mm rears with 305's. no rubbing issues and looks great!
Appreciate 2
      02-11-2017, 09:48 PM   #3
SapphireM5
SapphireM5's Avatar
711
Which brand are you running? Any issues with the 10mm? Thanks
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
      02-11-2017, 10:30 PM   #4
josec70
josec70's Avatar
4092
Drives: 22' Individual Chalk M5C
Ran MS 12mm Fronts with 10mm Rears on 343's with no issues at all on my previous set up.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      02-11-2017, 11:33 PM   #5
JtheW
115
Drives: 22 m850gc
I've got H&R 10mm all around with no issues. But, I've got 601s with stock tire sizes (265/295) and lowered on KW HAS. I've got no rubbing at all and l like the way it looks. I probably could've gone with 12mm but then I think I'd have rubbing issues. Didn't want to chance it but overall I'm happy with it. Hope that helped you out a little.
22 M850i gran coupe
      02-12-2017, 12:20 AM   #6
apexlocator
243
Drives: 2014 M5
I use to run 12mm front and rear and am lowered on H&R springs, OEM pzeros, with no issues.
Appreciate 2
      02-12-2017, 08:57 AM   #7
SapphireM5
SapphireM5's Avatar
711
Thanks guys! So it looks like either way I shouldn't rub with the 12 or 10. Maybe 12 in the rear and 10s up front? I dont want the fronts to stick out too much. I dont know why I have the worst luck with rubbing in any of my previous cars. I know if theres a 1% chance of rubbing I will be that guy. So maybe 10mm all around is my safe bet. Just need to research issues with the 10mm unless you guys can recommend a manufacturer with no issues. Thanks in advance!!!
Edit: I think I am just going to do 10mm all the way around. Are manufacturers still having issues with the 10mm lips breaking? Thanks
      02-12-2017, 11:43 AM   #8
josec70
josec70's Avatar
4092
Where did you hear about the issues with 10mm MS spacers? I've had a 12/10mm set up on two F10 M5's and never had an issue. With this setup you will not rub; I was also on H&R and zero problems with rubbing or the spacers.
      02-12-2017, 11:49 AM   #9
SapphireM5
SapphireM5's Avatar
711
Hey Bud, i found a thread where a member posted that the ring on the 10mm spacer broke off. And there are issues with the 10mm sitting flat against the hub or the wheel. I want to run 10mm all around, I think for me they will be best. There are alot of members running the 12/10 setup and cant find alot of issues, so maybe it was a defect caught in early manufacturing.
      02-12-2017, 01:53 PM   #10
josec70
josec70's Avatar
4092
I wasn't aware of that; good luck with whatever setup you end up going with.
      02-12-2017, 06:11 PM   #11
KMORGSM5
KMORGSM5's Avatar
320
Drives: 14 CP M5
This is 12mm front 10mm rear
      02-12-2017, 06:17 PM   #12
evilb
evilb's Avatar
167
Drives: McLaren MSO 570S, 18 Raptor
I have 12MM MS spacers front and rear on KW HAS with no rubbing ever. MPSS stock sizes.
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
Appreciate 2
      02-12-2017, 07:00 PM   #13
SapphireM5
SapphireM5's Avatar
711
Thanks guys! Pics are really helpful!
      02-13-2017, 07:47 AM   #14
carrera2RSL
183
Drives: F10 M5 CP
Plenty of threads on this you can run 15mm all round no problem, My car is running 13mm Rear and 15mm front about 12mm lower than CP stock (CP height), so 22mm lower than a regular M5. I will probably go 15/15
I have run 10/10, 12/10, 12/12 and now 15/13
      02-13-2017, 10:15 AM   #15
SapphireM5
SapphireM5's Avatar
711
Thanks, yes I read all the threads I could find and some members reported issues with spacers when others didnt. Thanks everyone I think I made my decision, you guys def. helped out!
      03-14-2017, 09:28 AM   #16
carrera2RSL
183
Drives: F10 M5 CP
A few pics of 15F 13R, I have some 15's for the rear on their way !
      03-14-2017, 10:28 AM   #17
SapphireM5
SapphireM5's Avatar
711
Very nice! Ended up w 10mm all around
      03-14-2017, 11:43 AM   #18
ykjones
Master Gunnery Sergeant
ykjones's Avatar
72
Drives: 2013 F10 M5 Signapore Gray
Nice. I have 12 up front and 10 rear on KW HAS and OEM 20" tires. No rubbing issues.
VF Engineering Hex Stage 1, RPI GTM Black edition, KW HAS, Dinan sway bars, Matt Schnell spacers, IND black chrome, M Performance rear spoiler, M Performance rear diffuser, Michelin Pilot Sport 4S's, ESS stainless steel brake lines, EBC Red Stuff ceramic pads, BMC air filters, charcoal filter delete, sprint booster, V1w/Blendmount, BIM coding all options, Pedal Haus pedals, Formula One Pinnacle Tint
      03-14-2017, 01:06 PM   #19
SapphireM5
SapphireM5's Avatar
711
Same set up I'm going with based on your review and advice!! I'll see how the front 10mm look after the drop then go from there.
      03-14-2017, 03:30 PM   #20
josec70
josec70's Avatar
4092
I had 12mm Fronts and 10mm Rears on KW HAS on stock 20" 343's and it worked very well. The KW HAS work very well and still are on my car today but with a 21" wheel setup.
      03-14-2017, 03:32 PM   #21
SapphireM5
SapphireM5's Avatar
711
Yup nothing but good things I hear about the HAS setup. I just don't want any rubbing so for now 10mm all around and I'll play it by ear afterwards on the front based on looks.
      03-15-2017, 02:53 AM   #22
carrera2RSL
183
Drives: F10 M5 CP
Zero rubbing with 15/13, should be the same with 15/15
m5post
