04-24-2020, 08:16 PM | #1 |
372
Rep 446
Drives: 2018 M2
27E4 Brake Vacuum Sensor GOOD NEWS
So,
I got the dreaded 27E4 after a recent brake flush. Though I suspect that fluid had been on the sensor awhile, and the flush finally pushed the sensor to the limit. I realize you need to just get the OEM part 34302283605 and remove the sensor, and replace the sensor on the car. HOWEVER, there was a lot of discussion around part 13628657300 which is labeled as a diff pressure sensor, but all the numbers on the sensor match exactly with the sensor on oem part 34302283605. Well I bought a used diff pressure sensor (13628657300) off a 2014 x2 I believe with about 20k miles, and it seems to be working! I'm not surprised, I mean its a sensor, it does the same thing no matter where it is in the car, the ECU just determines is range/function based on where its plugged in be it diff, abs, intake etc. I'll probably replace with a brand new 13628657300 when I muster up to doing that tedious task again. But I think its safe to say its a cross compatible part, saving you about $130!
Current: 2018 M2 DCT
Previous: 2011 E92 M3, 2007 E92 328xi Insta: @kmannc |
04-25-2020, 10:17 AM | #2 |
207
Rep 242
Also replaced the this sensor, a few weeks ago. Totally fixed my limp mode, vac pump on all the time, and 27E4 fault code.
Wish I had known could've bought just the sensor; would've saved $120. I'll keep that in mind for next time, thanks! |
04-25-2020, 10:19 AM | #3 | |
372
Rep 446
Drives: 2018 M2
Have you noticed your abs pump cycling less since replacing? I don't think I've heard mine on the past few startups
04-25-2020, 11:11 AM | #4 |
207
Rep 242
Yes, I mentioned vac pump but maybe I meant abs pump. Whatever buzzing sound that comes from the footwell or driver side fender. It was on a lot before replacing the sensor, now I never hear it.
04-28-2020, 09:22 AM | #5 |
372
Rep 446
Drives: 2018 M2
Okay thats good to hear. It would kick on every morning when I'd start the car over the past year or so. After the flush, it started happening multiple times while driving. Now I don't hear it at all either.
04-28-2020, 09:31 AM | #6 |
372
Rep 446
Drives: 2018 M2
Adding pics of the new sensor (diff pressure sensor). vs the old sensor I took out.
[IMG][/IMG]
04-28-2020, 10:13 AM | #7 |
1343
Rep 1,881
13628657300 pops up as an intake manifold pressure sensor. Its pretty cheap too, like $50.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
05-04-2020, 12:40 AM | #9 |
414
Rep 258
Tonight I pulled the old sensor--it had a bit of brake fluid on one of the mounting ears, but nowhere else. I don't know it it is good or not, but it's out! When I pulled it out I heard a large "pop" and an inrush of air as it entered what I presume was the vacuum system. I have a new sensor on order and will install it and hope for the best.
05-06-2020, 12:34 PM | #10 | |
372
Rep 446
Drives: 2018 M2
My fluid was dusty coated all over the sensor. I think it got spilled on when BMW did it for the last owner. Then the pressure changes from my recent flush caused the sensor to be pushed over the limit
04-03-2021, 07:12 PM | #11 | |
31
Rep 69
04-03-2021, 07:48 PM | #12 | ||
11503
Rep 1,067
https://www.m3post.com/forums/showthread.php?t=1338052 It is not nearly as bad as it seems, but requires finesse.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
RedCardinal31.00 |
04-03-2021, 09:13 PM | #13 | |
31
Rep 69
Thanks! |
Dpc2u11503.00 |
01-03-2024, 11:59 PM | #14 |
Rep 29
My car has thrown this code twice in the last few weeks. Once after about an hour drive and again a couple weeks later, after only about 10 minutes. There doesn’t seem to be any evidence of spilled brake fluid on the sensor or connector. When it does go into limp mode, I just pull over and restart the car. It doesn’t happen again for days or weeks. With an intermittent code like that, is it likely the seal on the sensor periodically leaking and just replace the sensor or do you guys think it could be pointing to something else? Thank you.
01-05-2024, 08:18 AM | #15 | |
4482
Rep 7,122
As a side note my pump buzz around for a bit more since I changed the fluid couple of years ago (and yes, over spilled...). Bought a cheap sensor after reading this post, never got worse so haven't got around to change it. Cheers, Mr Lazy |
knous816.50 |
01-05-2024, 08:27 AM | #16 | |
Rep 29
01-06-2024, 04:58 PM | #17 |
Rep 29
Problem solved, was a jacked oring on the sensor.
RocketyMan230.50 |
01-07-2024, 05:56 AM | #18 |
4482
Rep 7,122
01-14-2024, 05:00 PM | #20 |
1944
Rep 1,905
Drives: E92 M3
That blue o-ring on the sensor can get ripped during install or even removal. It might not be the o-ring itself but perhaps the sensor itself causing the code.
I replaced my sensor in 2022 and then in 2023 the sensor and vacuum lines as part of a master cylinder, brake booster, and reservoir refresh. The one year old sensor's o-ring looked about that bad but I didn't have codes.
knous816.50 |
03-21-2024, 10:52 AM | #21 |
97
Rep 128
This thread was very helpful for me. I started noticing the pump ran nonstop the moment I picked my car up from a brake job approx. one month ago. Then, two weeks ago, the car went into limp mode, but the car didn't store any codes. I drove the car two more times, and it went into limp mode again the second drive, this time storing the 27E4 code.
I spoke with the shop, and their head mechanic told me there was no way the sensor could've gone bad and that something else must be the culprit. I asked him to check the sensor, and after some colorful back and forth, he finally relented and swapped out the sensor. The car has only been driven 50 miles since the repair, but the pump has not come back on, except for 3-4 seconds upon startup. Giving the shop the benefit of the doubt, I tried to pay for the replacement, but the shop's owner insisted on covering the cost, as it appeared they did let brake fluid drip onto the vacuum line, which trickled down to the sensor. |
