BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
      10-27-2020, 12:02 PM   #111
drwankel
drwankel's Avatar
1053
Drives: 2012 E92 M3 ZCP, 2021 M340i
This thread really ought to be stickied.
Does anybody know if there is an unstamped part for the bmw motorsport waterpump with the metal impeller?
      11-27-2020, 07:40 PM   #112
Brasilcat
Brasilcat's Avatar
66
Drives: 2011 M3 E93
2011 BMW M3  [0.00]
Amazing thread and information.
I'm sure everyone here appreciates the effort and time it took to compile and share this information.
Cheers!
Theodore672.50
      11-27-2020, 10:11 PM   #113
Redd
3910
Drives: 2010 BMW E92 M3 Dakar Edition
The Rein OEM waterpump has a metal impeller but the metal is not as smoothly finished as the BMW Motorsport unit.
      12-23-2020, 09:47 PM   #114
Theodore
Theodore's Avatar
673
Drives: 2011.5 E92 M3
Updates and corrections for Original Equipment (OE) Equivalents (Thanks Davisca455):
BMW E9X M3 A/C Belt Tensioner Pulley Only = INA 5320557100
BMW E9X M3 Alternator Belt Tensioner Pulley Only = INA 5320342100
Built before 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = INA 5320418100
Built on or after 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = Only available from BMW 11287841531
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
Davisca4552207.50
      01-13-2021, 11:36 AM   #115
Assimilator1
Assimilator1's Avatar
594
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Good thread, but I don't know why you haven't updated the MTF oil for the manual gearbox, I've provided the info 2-3 times already in this thread
Theodore
      02-22-2021, 01:54 PM   #116
Assimilator1
594
2008 BMW M3  [0.00]
Has anyone found a replacement for the double studded rubber mount (aka bobbin) that holds the PAS pipe to the bracket? (which bolts to the subframe).
It's the part that nut, item no 15 screws to in the diagram below the PS pump in the op.
I've ordered a bobbin from GSF that they think is close, it's for an original Mini!
I'll find out what it's like tomorrow, hopefully! [edit] Nope, was way too big!
I ended up using a mount intended for a VW Passat 2002 engine cover, turned out to be a perfect fit, and slightly thicker so stronger!
You can get Febi ones (part no 23304).
And apparently the VW part no is 059 103 658A (which appears to be Febi anyway).
This shows the original BMW one vs the VW/Febi one (the original BMW one had sheared off through the rubber, I'd glued it with silicone, but it wouldn't have held for long).
[edit] If anyone wants an exact match and not one slightly stronger (why? lol), then this one seems to be the job VW 037 133 567F, air pump rubber mount apparently.
Also, has anyone ordered the INA tensioner pulleys lately?
I bought 2 today from GSF, the INA 5320557100 AC tensioner pulley and the alternator tensioner pulley INA 5320342100.
The alternator tensioner pulley was exactly the same size, although it did have a bolt with a large washer crimped to the bolt, it was easily screwed off. Much cheaper at about £20 , vs BMWs pulley and arm at ~£150!!
The AC tensioner was however a slightly smaller diameter (~4mm), that said, the pulley I had on there wasn't genuine anyway (although it was INA) so maybe that was wrong in the 1st place? (interestingly it was exactly the same size as the alternator tensioner pulley).
My car's build is 4/2008, which annoyingly is right at the change over point between 2 different PAS/AC tensioner pulley and belt config's. The belt on my car is a PK 1067.
Anyone know which size pulley it should have?
M3_Legend355.00
      07-08-2021, 01:24 AM   #117
romero1990
176
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
can anyone confirm if Bosch changed the part number for our injectors? I tried to find the 0280158164 but it is back ordered everywhere. But Bosch website said this
https://www.boschautoparts.com/en/au...n?partId=62418
      07-10-2021, 07:29 AM   #118
Assimilator1
594
2008 BMW M3  [0.00]
Sorry I can't help, but how about contacting Bosch?
      07-10-2021, 06:50 PM   #119
Davisca455
Davisca455's Avatar
2208
Drives: 2008 M3
I ended up using a mount intended for VW engine covers, turned out to be a perfect fit, and slightly thicker so stronger!
Pulley sizes and part numbers are here:
https://www.bimmerpost.com/forums/sh...php?p=26791901
Chris,
2008 E92
      07-12-2021, 01:25 AM   #120
Assimilator1
594
2008 BMW M3  [0.00]
Yea I found that thread a little while after posting that message, and posted there .
But it's good information that you posted the link for others.
Btw, IIRC (I need to double check) I think mine is the earlier version, but doesn't have the offset pulley! Lol, someone prior to me had changed the pulleys and I'd just copied their mistake, doesn't slip though!
Davisca4552207.50
      08-10-2021, 08:28 PM   #121
lauz
49
Drives: bmw z4m
Is there a similar list of parts for z4m coupe or roadster (s54) ?
      08-14-2021, 01:01 PM   #122
Assimilator1
594
2008 BMW M3  [0.00]
Isn't that the engine from the previous M3?
      01-10-2022, 03:51 PM   #123
ZiMMie
26
Drives: S54/E36
Alternative Pre-Cat Sensors.
Bosch # 0 281 004 047. Alternative OE #'s (0055199542 , 00551995420 , 55199542 , 55260358 , 55275929 , K0055199542)
Should be under 60€. Length is 330mm compare to the 340mm on the OE sensor
      01-21-2022, 12:57 AM   #124
W12x
203
Drives: M3, Z/28, Evo Final Edition
+1 on the Rein unit, not sure about their quality but that's the only one with metal impeller I found so far other than the Motorsport one that cost $700+ now...
2011 BMW E92 M3
2018 Tesla Model 3 Long Range RWD
      03-14-2022, 07:29 PM   #125
tdott
3956
Drives: M3
Did some searching and believe I found the INA version of the later deflection pulley (after 4/29/08) BMW 11287841531:
INA 11287535860, 5320512100, FP05121
FCP: https://www.fcpeuro.com/products/bmw...em-11287535860
I was able to cross reference this with the Duralast 231163 and Dayco 89163, which is a replacement for BMW 11287535860 pulley that others mentioned worked for them. I prefer sticking with the INA pulley and this fits the bill.
Will confirm in a few weeks hopefully:
      05-26-2022, 01:23 PM   #126
Ant Man
75
Drives: E92 M3 Individual Edition
Vaico DCT filters are made in Taiwan and not OE quality- confirmed directly by Viaco.
The genuine Getrag parts can be purchased outside the dealer network.
Theodore672.50
      05-26-2022, 01:28 PM   #127
BayAreaE93
BayAreaE93's Avatar
42
Drives: BMW E93 M3 DCT
2008 BMW M3  [0.00]
Those Vaico DCT filters gave me my biggest headache thus far with my M3... installed one, could not get it to seat exactly right and said fuck it... then DCT fluid spewed out of it and all over my driveway XD
Had to wait a week for an OE getrag filter which went in perfectly and fixed my issue. Left a nasty one star review on FCP Euro which they later deleted...
Theodore672.50
      05-28-2022, 08:25 AM   #128
Theodore
Theodore's Avatar
673
Updated to remove Vaico DCT filters and replace with Getrag. Thanks.
Appreciate 2
      09-20-2022, 12:43 AM   #129
LKN624
LKN624's Avatar
Germany
274
Drives: 08' E90 M3 and 08' E92 M3
7 BMW E9X M3 front lower brake caliper pins = BMW only, OEM equivalent not available
Just FYI...the lower pins #7 are...ATE 11.8171-0067.1
Appreciate 2
      03-01-2024, 07:39 AM   #130
m3s65b4.x
60
Drives: 2007 e92 6M/T
BMW E9X M3 Wiper Blades - not available
Maybe covered earlier but can we consider Valeo wiper blades 574399 VF336 ?
Tuner199.00
      04-10-2024, 01:58 PM   #131
Assimilator1
594
2008 BMW M3  [0.00]
Updates and corrections for Original Equipment (OE) Equivalents:
BMW E9X M3 Manual Transmission Fluid (BMW MTF-LT-2) = Pentosin MTF2 75W-80 (no longer in production)
BMW E9X M3 radiator - exact equivalent not available
Why have you ignored the info I posted 3 times before about the MT LTF2?
Was it because of the 2 different Castrol names? I see I didn't clarify that previously, the 2018 (& 2019) ZF TE-ML11 pdf lists both the Castrol Transmax as well as the Syntrans. Here's the text from that pdf (I've also attached the pdf to this post) :-
Castrol BOT 338
=> BMW Oil No. 2300 7533 513 (clutch bell housing label MTF-LT2)
=> VW Oil No. N 05279800
=> Castrol Syntrans B 75W
=> Castrol Transmax Manual B 75W
I've provided multiple links regarding what the oil is, including by the manufacturer of the gearbox (ZF).
So at the least, Castrol Transmax Manual B 75W was the genuine OEM MTF LT2 oil.
This is the relevant text from the "List of lubricants ZF TE-ML11" 2024 (see link in my quote below).
S6-53
According to spare part number of vehicle manufacturer:
- Esso Gear Oil 304 / BMW Oil No. 2300 1434 404 (clutch bell housing label
MTF-LT1)
no longer available => replaced by Castrol BOT 338 (ZF approval number
ZF001053)
- Castrol BOT 338 (ZF approval number ZF001053)
- Castrol BOT 207 (ZF approval number ZF001069)
=> BMW Oil No. 2300 7533 818 (clutch bell housing label MTF-LT3)
Warning: use of incorrect lubricant can cause transmission failure
Err, as I said earlier
MTF LT2 also = Castrol Syntrans B 75W (to name 1 of 3 others), as per ZFs own pdf "List of lubricants TE-ML 11", oil still available!
Fantastic idea for a thread!
One addition for you, which you actually already have linked in your ZF oil pdf .
Castrol Syntrans B 75W is a direct replacement for LTF 2, and was originally the recommended oil by BMW, Castrol's data sheet still shows this.
Also the oil's viscosity ratings exactly match Castrol BOT 338's oil as shown in their SDS pdf, section 9.1 and listed in the ZF TE-ML 11 pdf.
Currently, the cheapest place to buy 1 ltr bottles of these in the UK is Broughton Lubricants, followed closely by Opie oils.
[edit]
The Castrol Syntrans B 75w has been discontinued in the UK, and Boughton Lube's state (a Castrol agent) that it has been replaced by Transmax Manual FE 75W, but that is not BMW approved.
Just trying to track down some Castrol Transmax Manual B 75W, which is proving easier said than done....... well it looks like that's been discontinued too , so there's no point adding the info to the op now (but their was 4+ yrs ago ).
I wonder if the VW numbered BOT 338 oil is still available (and cheaper than BMWs).....
      04-10-2024, 04:39 PM   #132
Assimilator1
594
2008 BMW M3  [0.00]
I actually came back to this thread intending to see/ask if anyone's managed to track down an OEM supplier of the horns.
I see the original ones are made by FIAMM, pic of my M3's horn one and two, and No2 again showing the BMW part no.
Hmm, looking at the numbers on the top, the 2 horns are the same, I thought they were different tones for some reason.... [edit] yes they are 2 different tones according to realoem.
m3post
