04-16-2024, 01:31 PM | #1 |
33
Rep 105
Android Auto / Apple Carplay
Does anyone know if using a cable for Android Auto or Apple Carplay is supported? I have tried to find detailed information specifically about using a cable, but have only found that its supported on the G05 and a few things similar to this which makes me think its wireless only. Trying to figure out some things for longer trips since the wireless charger is garbage. I know some other people have just put a different wireless charger on top of the shotty one, but if I can just connect a cable for it all and go, the better.
Android Auto is supported by every BMW with a Live Cockpit Plus or Professional that runs on Operating System 7. In addition, you need a compatible smartphone which is: Any smartphone with Android 11.0 and 5GHz Wi-Fi. In the EU, smartphones must comply with additional regulatory requirements in order to use 5GHz Wi-Fi in the car. Or, a Google or Samsung smartphone with Android 10.0.
2021 X5 xDrive40i M-Sport | Phytonic Blue / Cognac
04-16-2024, 01:49 PM | #2 |
4722
Rep 8,798
Drives: eVeRyOnE mAD!
this is a non-issue. charging the iPhone and CarPlay are independent of each other. you can easily charge the iPhone via cable while CarPlay is operating wirelessly as designed. you don’t have to be charging wirelessly to use CarPlay
04-17-2024, 07:03 AM | #4 | |
4722
Rep 8,798
whether your phone charges wirelessly or via cable, CP and AA operate wirelessly. put another way, CP/AA function isn’t supported via the cable that’s plugged in the phone to charge it. |
04-23-2024, 06:28 PM | #5 |
33
Rep 105
yeah......no you didnt until just then. Lots of different car manufacturers supported Android Auto and/or Carplay via a wired connection prior to offering it wireless. My friend's Toyota for instance ( yes...I know...Not a BMW.....easy killer) supports Apple Carplay via a cable ONLY. So while charging is separate than Carplay, it is supported via the cable ONLY and you still have to use the cable. hence the single connection for both. Manufacturers can choose to offer the features as they will. All you had to say was "no, its not supported via cable". Remember....Your non issues are not everyone else's non issues. I'd rather have it one way or the other. All wireless, or turn WIFI/BT off and use a cable.
04-23-2024, 07:26 PM | #6 | ||
4722
Rep 8,798
how can you infer the possibility of operating via cable after I specifically mentioned it was designed to operate wirelessly? put another way, it only supports wireless CP/AA. how many different ways do I need to say it for you to understand I already answered your question in my original response? instead of stating an untruth, I would’ve given you a pass if you simply admitted you misunderstood I’m familiar with wired CarPlay. some bimmers had it about a decade ago (I’ve owned a bimmer since 2008), and I am a proponent for support of wired CarPlay especially since wireless has proven unreliable for many people |
