06-04-2022, 01:58 AM | #1 |
Rep 11
BimmerUtility and Cheat Codes for aSLA & TLA
Hi all,
Did anybody try to enable Auto Speed Limit Assist (aSLA) and Traffic Light Assist (TLA) through the cheat code available in Bimmerutility. currently speed assist works fine with all the options (adjust automatically, manually, show anticipation, etc..), However, the rest of the options are grayed out and can not be selected. I noticed in the cheat code XML that it requires coding in 4 parts, I was able to locate 3 of them only. The first part (1/4) is missing. Not sure if that is intentional. So currently, I can see 'Consider traffic lights' but not selectable, same as 'Display traffic light phases' Any thoughts on this is highly appreciated. Thanks. Here is some background and screenshots. 2020 G06 fully loaded with 5AU, etc.., Using E-Sys 3.38.2, PSdZData lite V.4.35.21. I-step S18A-22-03-553. |
06-04-2022, 04:00 AM | #2 | |
212
Rep 451
Drives: 2017 X5 & 2020 X5
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
06-04-2022, 04:04 AM | #3 | ||
Rep 11
07-06-2022, 09:42 AM | #5 |
Rep 18
07-07-2022, 02:06 AM | #6 | |
111
Rep 272
I tried to do enable these using esysX but couldn't enable them. Got error message that 'This setting is not enabled for your location |
07-07-2022, 08:05 AM | #7 | ||
25
Rep 90
OzJedi111.00 |
07-07-2022, 02:49 PM | #8 | |
212
Rep 451
I live in hope that with the advent of ID8 and more advanced navigation systems the map database will one day include it for all previous versions. Emergency Corridor option does not work either not sure why but probably the same reason as TLA. UCC works well on the open road but not that great around town and has certainly saved me a few $$$ in speeding fines. PS Anybody who wants my cheat sheet please PM me their email address so I can send them a copy
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 07-08-2022 at 02:32 PM.. |
07-08-2022, 03:07 PM | #9 |
Rep 18
TLA not working with BimmerUtility
aSLA works fine using BimmerUtility (adjusting manually, not with "Cheat codes" option in BimmerUtility), however TLA does not work.
I have done all these (bellow in PDF)- but TLA still "not available in this country". Also - VIP ECU returns an error while coding. Any ideas? |
07-08-2022, 03:16 PM | #10 | |
Rep 11
As for VIP ECU, you can't code it while engine is running. |
07-08-2022, 04:27 PM | #11 | |
212
Rep 451
07-10-2022, 02:17 AM | #12 |
132
Rep 191
For me everything works in my country (Slovenia) except UCC.
UCC is not working at all in Europe. TLA works, but most time i need to press SET on red light. On monday i was driving from Slovenia to Macedonia. SLI must to be coded to work in Serbia and Macedonia (it is coded on my car) So aSLA works in Slovenia, Croatia, Serbia and Macedonia. Emergency corridor works in Slovenia and Croatia, even on border between those two countries. In Serbia and Macedonia i get massage emergency corridor and TLA are not supported in those two countries. In Macedonia i saw traffic lights on map, but TLA doesn't work. Even Stop and Yield sign detection are working in these 4 countries, but in Macedonia i don't get sound notification. I just get sign warning in speedo. |
07-13-2022, 05:33 AM | #13 |
Rep 18
Sure, I put the car in diagnostic mode and coded aSLA successfully.
aSLA works perfect, car changes the speed according to driving conditions and signs. However TLA coding according to BimmerUtility cheat codes does not give a positive result. I believe the navigation system does have the traffic light information (I could code it half a year ago and saw the lights on the map), but after the BMW update it's gone. |
07-13-2022, 05:36 AM | #14 | |
Rep 18
as some user mentioned already - VIP module acts strange: you can code it successfully after some tries. Coding gave an error 3 times and 4th time coded successfully. Can't explain. |
07-13-2022, 05:39 AM | #15 | |
Rep 18
I did successfully TLA in previous software version - map showed traffic light icons etc and TLA worked fine except automatic stop (it just showed the light in HUD and cluter). After an update from BMW- of course coding is gone. So I believe the mapping data already has all the traffic lights info - but my code sheet was not accurate now. |
07-22-2022, 02:26 AM | #16 | |
212
Rep 451
It sounds like one of the land mask values might NOT be correct ie (FF,FF,FF,FF) or you have a syntax error in your FDL coding values. One minor syntax error is enough to prevent it from working
07-26-2022, 03:27 PM | #20 |
356
Rep 689
Drives: 22 TR X3MC
Do you need ACC for TLA? I wanna do this for my x3M
2022 X3M Comp
2013 335i xDrive (Sold) |
07-26-2022, 06:59 PM | #21 |
212
Rep 451
You need Driver Assist Professional (5AU)
Anybody wanting a copy of the Cheat sheet can down load it at the BimmerUtility Facebook Group Site https://www.facebook.com/groups/1573...674/files/docs Please note there are 2 codes specific to the G05 in the SAS3 & DSC_VIP <function start="19" end="19" comment="IntRxSWINVarianten - Nr001 G05_G06_RxSWIN_neu" mask="11111111b">01</function> <function start="17" end="17" comment="IntRxSWINVarianten - Nr001 G05_G06_RxSWIN_neu" mask="11111111b">01</function> These 2 FDL settings above will differ if you are coding another G series model
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 07-26-2022 at 07:15 PM.. |
jd85_m0.00 |
07-27-2022, 07:58 AM | #22 |
152
Rep 706
Thanks Shaun.
Has anyone got ‘Highway Exit Assistant’ to come up on their Headunit/screen as an option? Have done the coding but no joy, is the only one can’t get to come up. |
