TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > about window liquid
      11-04-2008, 04:44 AM   #1
**335i**
**335i**'s Avatar
Switzerland
184
Drives: TOYOTA & 2008 E92 335i 6MT
2008 335i  [9.00]
Question about window liquid
hi
i have summer liquid and winter is coming i am not going to use it untill next spring, car will be in a yard for 5 month, there is lot of summer liquid in a tank in my 335i i think maybe its beter to dilution with winter liquid or maybe its beter to spray summer liquid on a windows and then to fill with winter liquid, what u guys think?
thanks
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
      11-04-2008, 01:44 PM   #2
Barmats
Barmats's Avatar
17
Drives: 2019 BMW X5
I don't know how cold it gets where you are, or what the temp rating of the summer washer fluid is, but I know this... you don't want the washer fluid to freeze!!! Once that happens, the only way to fix it is to thaw it and replace the fluid. This happened to me once -- I used a diluted mix of washer fluid and water and forgot to switch when winter arrived -- and I had to bring the vehicle indoors to thaw the frozen lines. If you think there's any chance of that happening, I'd drain the summer fluid into a separate container and use winter fluid. It's a small amount of work that's may be well worth the time spent.
      11-05-2008, 04:52 AM   #3
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
but how to allow summer liquid from my 335i into some kind bottle? its only possible to use it sparaying on a windows and then to fill with winter liquid
      11-05-2008, 05:03 AM   #4
GhOsT_E90
GhOsT_E90's Avatar
35
Drives: 2008 BMW 335i E90
2008 335i E90  [0.00]
I dont really think there is summer or winter windshield washer fluid, unless you diluted the fluid with more water. The washer fluid contians a certain amount of alcohol, in some washer fluids anyway and some contain a type of anti freeze washer fluid. So i would just fill it up with some new washer fluid,either being BMW brand or auto parts store brand they would have something for winter and it should be fine. Whatever is left in your windshield washer tank now just top it off with the new fluid.
Mods: JB3,RR catted DP, RennArt resonated exhaust, AFE intake, 19x8.5 & 19.9.5 Linea Corsea Strasse mounted on Nitto Invo 235/35/19front & 285/30/19rear. M3 spoiler, front spilters and ACS roof spoiler. And whooping Blue0013 around the Nurburgring all day long.
      11-05-2008, 09:43 AM   #5
Barmats
Barmats's Avatar
17
Drives: 2019 BMW X5
I would use a siphon to drain the fluid, which is probably the easiest and least expensive way to do it.
      11-05-2008, 11:03 AM   #6
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
so just fill it up with some new washer for winter on top
this would be also an option but more expensive, cos to buy siphon more expensive then to buy washer fluid
p.s i called to my BMW dealer, so they said that its a summer fluid, and it should be changed to a winter fluid, or like GhOsT_E90 said to fill on top some winter fluid
      11-05-2008, 11:16 AM   #7
Barmats
Barmats's Avatar
17
Drives: 2019 BMW X5
I would lend you my siphon but it's a bit of a drive... topping it off with winter fluid should be fine. It doesn't sound like you've ever filled the tank with water.
      11-05-2008, 11:19 AM   #8
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
yes would be nice, but i live in Lithuania no i never filled tank with water, i bought mine 335i in June 2008, so from that time i did nothing
      11-05-2008, 08:00 PM   #9
HighVoltage
HighVoltage's Avatar
32
Drives: 07 E90 335i
I would be careful about leaving the washer tank empty. The E9x uses the same/similiar pump style as the E46. These things are not very robust to begin with. There is a rubber seal that seats between the pump and the container than can dry out and crack. Lso the pump itself doesnt seem to respond well to being left out to dry/ The one saving grace on the E46 is that it is/was easy to get to in order to replace. Doesnt look so easy on the E9x...
      11-06-2008, 05:19 AM   #10
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
not gona leave it empty, will mix with winter fluid
      11-08-2008, 08:50 AM   #11
KEVXI
KEVXI's Avatar
Drives: 328xi
2008 328 xi  [0.00]
do you guys go to the stealership? or any kind of fluid work in the bimm i was told buy the ca of course that only to use oem fluid.mine is low right now! thx
