New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      01-17-2019, 10:20 AM   #23
jawolf
Drives: 2011 BMW Z4 sDrive30i
2011 BMW Z4  [0.00]
When mine broke I found you had to buy the whole bar so I simply drilled ans screwed mine back together. Did both sides while I was at it.
      01-18-2019, 10:06 AM   #24
Tangent
299
Drives: G01, F82, E89, F25
When mine did this I just superglued the thing back together. It's been holding great for a couple of years now.
      03-14-2019, 01:08 PM   #25
Rgouldjr
Drives: 2011 BMW Z4 Sdrive 3.0
Brackets
I ended up casting my own out of Aluminum and then painting them.
Drilled them out and bolted them together with a few #10 bolts with nylock nuts.
I don't think they will break ever again.
RobbiZ4127.50
      03-15-2019, 04:19 AM   #26
Sirrith
Drives: Z4 23i
Would you take orders for these?
      05-27-2019, 04:03 PM   #27
jamulcah
Drives: BMW e89 Z4
Originally Posted by IvorZ4 View Post
This is how I fixed this and I think it's a solid repair and probably stronger than the original brackets. When my other one breaks, I will effect the same repair.
Thanks Ivor. This is a great tip, and I've just done the exact same to my own Z4 and it works a treat. Very clean result!
      07-11-2019, 07:38 PM   #28
Silverstar
Drives: BMW Z4 Sdrive30i
Originally Posted by HenryHank View Post
I had mine replaced under warranty at the dealer.
But now there's a small net in the back. Is that something new, or was just missing from my car when I bought it (used)?
I am wondering about this too, my 2009 model does not have the net yet the other day I saw a 2012 model which has this net attached to the divider. I tried to see if I can find it on realoem but when I put my VIN it does not show any nets, so I assume this only came on later cars? does anyone know?
      08-25-2019, 04:37 PM   #29
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Drives: BMW Z4 E89 sDrive 30i
AFAIK the net was added as of spring 2012.
      11-08-2021, 04:09 AM   #30
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
For you guys in the states,
you can try to order it from Treatstock.com
Maybe there is a cheaper option to get it printed directly in the states?
https://de.treatstock.com/product/1l...nk-loading-aid
      02-14-2022, 02:55 AM   #31
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
      02-23-2022, 09:29 AM   #32
mopedmaster
Drives: 2011 Z4 SDrive35i
Or print them yourself...
I created an alternative hinge design which looks very close to stock.
If you would like to just purchase the hinges, they are available on Treatstock (internationally):
https://www.treatstock.com/3d-printa...rtition-hinges
If you would like to purchase the 3D model and print the hinges yourself (or have them made from metal/other materials), it is available on Cults3D:
https://cults3d.com/en/3d-model/vari...artition-hinge
Pictures:
Thanks,
Rob
      02-24-2022, 05:26 AM   #33
Marcoose
Marcoose's Avatar
484
Drives: 2016 sDrive35is
If you have or can fabricate more, I’ll buy a pair. Thanks.
      03-05-2022, 01:45 AM   #34
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Great job!!
      06-08-2022, 02:29 PM   #35
Chrisw73
Drives: (2) 2007 X3, 2016 Z4, 2018 X5
Pictures:
Thanks,
Rob
What size bolts? I ordered the replacement parts based on your drawing now need to grab bolts.
      06-08-2022, 03:24 PM   #36
Tangent
299
Very nice piece! For what it's worth my original Superglue fix is still holding since I did it about 5 years ago.
      06-17-2022, 09:53 AM   #37
marknewham
Drives: BMW Z4 35iS
The reason they only supply the complete assembly by the way, is probably because the brackets are plastic-welded on.
This is what I used:
4.5mm drill bit
Countersink drill bit
Countersunk M4 Allen bolts (25mm long, stainless steel)
M4 nut (Nyloc in the photo but any nut will do)
Drill carefully through the plastic pillars from the inside of the bracket, all the way through the outside on both halves.
Countersink the top bracket holes on the outside so that the bolts sit flush:
Assemble the two halves of the bracket together and tighten up the nuts on the bolts (not too tight). Make sure the brackets are properly aligned.
Now on the bottom of the bracket, use a Hot Glue Gun to fill the space around the nut with glue. Don't get any glue on the thread as you need to remove the bolt once the glue has set. The glue will now hold the nuts in place in the perfect position for the bolt to be inserted. This makes assembling the bracket onto the bar in the boot (trunk) much easier and also prevents the nut from loosening.
Job done and it looks pretty neat. I actually replaced my stainless steel bolts with some black ones I bought from Amazon and the repair looks like it was original equipment, plus it's considerably stronger than the plastic weld that was there before. These are the bolts I used:
http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
Hope this helps.
Really good guide and served me well with my repair, didn't bother with the glue gun bit but did up fine - Thanks for taking the time to post this!
Mark
      07-11-2023, 08:15 AM   #38
Thatch
Drives: 2009 BMW Z4 35i
Thanks to this post I managed a similar fix with a few M4 bolts and a bit of Loctite. This part broke for me as I was looking at the car to purchase. I didn't realize it at the time but even though I could put the cargo cover in place it didn't hold proper position and the top was very erratic in operating.... sometimes it just refused, red light blinking and the trunk wouldn't open. I had to fish for the trunk pull several times. Almost thought I had bought a real problem case, then I made the connection to this part and did the fix last night. The cover now drops into place and latches solidly and the top and trunk are working fine. I appreciate what BMW is trying to do here, but my god it's a bit overkill on the sensors.
I didn't notice that anyone else was having top operating issues though in their descriptions, or perhaps that was just a given?
Regardless, thanks for the info here, even if it is an old thread.
      03-20-2024, 09:31 AM   #39
Renfield
Drives: 2013 BMW E89 black on black
3D printed fix
Hello folks.
I recently bought a 2013, and the PO had "fixed" the broken bracket with three zip ties. Those have all died now, and the right side is loose.
I specifically did not want to recreate an overdesigned failure. Only create a simple solution that does a good job replicating the aesthetic of the original. So about 20 minutes in Tinkercad and bada boom, bada bing.
Designed to work with Zip Ties or bolts/washers.
If using zip ties, I'd suggest a cross pattern approach.
When my installation is complete, I'll post pictures and a link to the free download on Tinkercad.
George
B21160.50
      03-21-2024, 07:01 AM   #40
Renfield
Clamp it, Jed!
Second time was the charm. I added an alignment notch to the far side for ease of assembly. Holes are 5mm.
And the link I promised:
https://www.thingiverse.com/thing:6542849
I'm very pleased with the function and aesthetic. Fun little design project.
This is the test fitting. I'll have the bolts painted black before final assembly.
George
      03-21-2024, 12:37 PM   #41
Hedders
Drives: BMW E89 3.0i
Renfield,
I know nothing about 3d printing but just found a site that will print that file for a charge.
It works out twice as much as just buying the ones in the earlier link!
B21160.50
      03-22-2024, 04:35 AM   #42
Hedders
Has anyone managed to order these?
I tried yesterday but just ended up 'waiting for a quote'. I didn't hear anything so I have just filled in the form again and see if the actually do sell these things.
RobbiZ4127.50
      03-22-2024, 05:26 PM   #43
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Requires some patience...
What about Rob's solution?
https://e89.zpost.com/forums/showpos...7&postcount=32
U could purchase the file and get it printed by a 3D print service provider.
By the way, I've printed mine with transparent ABS and integrated a bigger LED that got connected to the trunk light:
https://www.zroadster.com/forum/thre...3/post-3641544
      03-23-2024, 03:54 AM   #44
Hedders
That is very cool!
I have already joined a 3d printing page on FB and made a new contact
zpost
