08-29-2011, 01:10 PM | #1 |
10
Rep 32
6MT Speed Bumps...
What is the best way in general for the car while driving over speed bumps?
What aspect and how does each affect certain components(motor mounts/transmission/suspension etc)? 1) Neutral/roll over bump 2) Low gear/with gas 3) Leave in gear/no gas |
08-29-2011, 01:24 PM | #2 |
Ya ya ya, I am Lorde, ya ya!
266
Rep 2,772
Drives: E90 M3, 2015 SQ5
Since when did the M3 become a Fabergé egg??
08-29-2011, 01:35 PM | #4 |
1558
Rep 2,505
I wonder how some owners even own a M3???
I frequently visit other forums and this forum seems to lack intelligence compared to the others.
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
08-29-2011, 01:39 PM | #5 |
7
Rep 57
Any of the options will work fine depending on your speed and terrain...
Drives: 997 Porsche turbo Stable: Porsche Panamera '09 e93M(sold), '09 e90(sold) |
08-29-2011, 01:54 PM | #7 |
2362
Rep 4,255
LOL!!!!! The more you read the forums the more it seems to be possible.
///M Power
08-29-2011, 02:11 PM | #8 |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
how u drive over a speedbump in a honda civic = how u drive over a speedbump in a M3..6mt or dct
08-29-2011, 03:13 PM | #10 |
594
Rep 4,488
As much as my personality tempts me to chime in with a post similar to the others here, since I'm a new 6MT driver I'll sympathize with the OP.
Any of those should be fine. I personally coast over them in 1st or 2nd with little to no gas because this car can creep on a flat surface without any gas and it still won't stall. If you're paranoid about stalling because you're coming up to a really big speed bump (they're out here in Texas), then sure give it some gas. There really isn't much point to clutching in over a speed bump unless you're coming in way too fast because you didn't see the speed bump and now need to slam on the brakes. In that case, brake hard, clutch in to avoid stalling, release the brakes just before you go over the speed bump to avoid having a bunch of extra weight on the front end, and hope you scraped off enough speed to avoid bottoming out your front end. Then put the car into 2nd or 3rd, smoothly clutch out, and carry on.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
08-29-2011, 03:16 PM | #11 |
314
Rep 8,496
08-29-2011, 03:20 PM | #12 | |
314
Rep 8,496
clutch in off the gas car goes over bump slip clutch back in For high speed bumps off the gas car goes over bump back on gas OP is this your first manual? |
08-29-2011, 03:23 PM | #13 |
594
Rep 4,488
If it is, since I was in the same boat I created this thread and got a lot of helpful responses. There are some great people on these boards: http://www.m3post.com/forums/showthread.php?t=501071
08-29-2011, 03:24 PM | #14 |
258
Rep 5,012
The ideal speed bump pass is as follows: have enough momentum to barely put the car over the speed bump, then use the brakes to slowly roll the car down. With the front wheels it can be momentum from coasting. When the tires hit the bump, you should be with the clutch in and in 1st. If needed, you can help the car roll over the bump if you didn't calculate the speed correctly. But you'll need to power the car after the front wheels are over the bump and just before the rear ones hit the speed bump. Again, at that time you have the clutch in and should have enough momentum to barely barely get over the bump and over, before you start breaking to slow the car down. And yes, I'm talking about Texas sized speed bumps , like the ones where I live. And some of those require the additional step of getting sideways, to avoid hitting anything. Those super long ones about 4' long and about 4" high, are not even speed bumps to most < he he>.
08-29-2011, 03:29 PM | #15 |
594
Rep 4,488
Out of curiosity, why do you bother clutching in for speed bumps? I haven't seen a need but since I'm fairly new to this I'm always open to more information.
08-29-2011, 03:33 PM | #16 |
10
Rep 32
Um this is the first manual car I've owned. I've had the car for a few years though. I'm not trying to ask how to get over a speed bump without stalling. Just want to know what is best for the car and puts least amount of wear on the clutch/transmission/motor mounts etc. I drive over a lot of them on a regular basis and was looking for a technical answer. Thanks
08-29-2011, 03:36 PM | #17 | |
594
Rep 4,488
ADDED: Besides, remember that the transmission is connected to the REAR wheels, not the front wheels which would be the only ones affected by the differences in the options you're contemplating -- unless you're actually considering clutching in before the REAR wheels go over the speed bump.
08-29-2011, 05:19 PM | #18 | |
Troll
79
Rep 1,193
I coast over in 2nd gear.
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport Quote:
08-29-2011, 06:07 PM | #19 | |
594
Rep 4,488
Speaking of abuse, if you feel like you're damaging the rental car, then maybe you should slow down rather than needlessly damaging someone else's property and making rental cars cost more for the rest of us?
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 08-29-2011 at 06:24 PM.. |
08-29-2011, 06:14 PM | #20 |
11
Rep 619
Depends. Does this guy live in your neighborhood?
2008 E92 M3, ESS VT-1, AA Full Exhaust, Volk TE-37, PSS10, ST BBK, ARKYM Motorsport Spliter, Vorsteiner Diffuser, BMW Edition Grill/Gill's, BMW Performance Spoiler, AUTOcoture Blacked Out Headlights, LCI Tail lights, Vorsteiner Carbon Fiber Center Dash Insert, Ultimate Racing Pedals (Because Race Car), AA SSK, Speed Cloth. |
08-29-2011, 06:24 PM | #21 |
11
Rep 619
This speed bump may require a particular technique
