Transmission fluid change interval
10-07-2015, 12:51 PM | #1 |
26
Rep 175
I'm reaching close to 60k and thought I saw somewhere 50k - 60k is optimal time frame to do transmission fluid and filter change but couldn't find any thing beside transmission oil being lifetime or something from bmw.
would you do transmission fluid/filter change at bmw dealer or indy shop? and what's the going prices? |
10-07-2015, 01:03 PM | #2 |
Kind of a Big Deal
167
Rep 857
You can take a look at this recent post. I got the 50-60K interval from the guy who writes the column in Roundel. It cost about $150 for six liters of the ZF fluid and maybe $130 for the replacement pan/filter -- but it's like $800 at the shop.
Key takeaways: You really want to do it on a lift, it's easier with a helper, and you want to borrow one of those gun-style IR thermometers because the fluid has to be between 40-50 C when you do the final pour. Oh and you want one of those beefy fluid pumps that does half a quart per squirt -- when the car is on the stands and is warming up, you don't have time to mess around with the lotion pump thingy. http://www.e90post.com/forums/showthread.php?t=1176822 |
10-07-2015, 02:14 PM | #4 |
213
Rep 2,210
Its really easy to do with a floor jack and jack stands, provided that you dont have those tiny little 1 ton jack stands that only hold the car at ride height. Ive done it twice now using jack stands that put the jack mount about 12" above the floor and its fine. It might not be as comfy as sitting on the couch drinking a beer, but ive also spent an hour doing less comfortable things.
10-07-2015, 02:57 PM | #5 | |
765
Rep 3,558
link for pump: http://www.idparts.com/motive-power-...ro-p-2319.html |
10-07-2015, 04:18 PM | #7 |
158
Rep 866
I was quoted $620 and $530 by two reliable mechanics. Chose the $620 one because he knew exactly what to do, had the latest software, and he only did BMW's and Mini's. I had it done at almost 70K and there was a significant improvement in smoothness and not even the small amount of slippage it might have had before.
Either would have been good. PL |
10-07-2015, 04:55 PM | #8 |
Kind of a Big Deal
167
Rep 857
Not sure -- that number was bandied around here on the forum.
My hat is off to the stalwarts like Mik who did the DPF think on jackstands IN THE WINTER. For me, gosh, just getting the fluid up in the right place and all was tricky with a lift. |
10-07-2015, 05:12 PM | #9 |
614
Rep 2,410
I'm sitting on the couch drinking a beer as I type. I completely agree with your statement. :-)
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
10-08-2015, 05:59 AM | #10 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
These transmissions don't have a built in temp sensor that measures fluid temp? Or it's just not accessible using torque.
I changed the fluid on my GTIs dsg, and they have a temp requirement too for measuring fluid level. Anyway I'd figure BMW would have a transmission temp sensor. |
10-08-2015, 06:02 AM | #11 |
Kind of a Big Deal
167
Rep 857
I believe there is an internal temp sensor. The shop mechanic where we had the DIY, at BMW of Annapolis, said they just use the OBD port for that info but I could not find trans temp listed on Carly.
10-08-2015, 08:37 AM | #12 |
671
Rep 1,442
This is emblematic of a division between those who truly know what the hell they are doing and those that don't. ...I generally stay away from projects where my first thought is will I get crushed under my car...
10-08-2015, 09:51 AM | #13 |
229
Rep 3,489
Drives: Montego Blue 335d
got my tranny diferential and engine done for $350 labor and about$175 worth of AMSOIL oil
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
10-08-2015, 09:58 AM | #14 |
111
Rep 529
10-08-2015, 04:55 PM | #15 |
765
Rep 3,558
I did it on jack stands too. It wasn't that bad but I was in a clean cement garage. As a teenager, I had to work on VW Scirroco in gravel driveway. A piece of cardboard is your friend.
10-09-2015, 11:49 AM | #17 |
33
Rep 246
10-13-2015, 06:31 AM | #18 |
229
Rep 3,489
rulonger just take a cruise and go on vacation amigo
10-13-2015, 08:15 AM | #19 |
111
Rep 529
10-14-2015, 02:16 PM | #20 |
229
Rep 3,489
jajaj very true and very unfortunate
