BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications BM3 exhaust flap 540i
      04-25-2024, 02:23 PM   #1
kmac1980
36
Drives: '19 540xi
Hi everyone ,
I have read this forum and others extensively and haven’t really found an answer to this.
I was trying to play with the exhaust flap in the Bootmod3 app on my custom stage 2 tuned ‘19 540xi and not sure if the coding is working or not.
I have changed the setting in my custom map for exhaust flap to be open always in sport mode (and reflashed) However, when I put the car into sport at idle and get out and check, the flap is closed. The burbles settings seem to work fine, so I believe the flash is working.
Does this setting only force the flap open when in motion? How exactly does this setting work on a 540 in bm3? ( believe it’s different in the stock m550i vs stock 540i)
Thanks
Kevin
      04-26-2024, 08:06 AM   #2
tjbuggy2b
193
Drives: 2018 540i xDrive M Sport
Interested in this code-ability. I should have my Remus on next weekend and suspect I may want the flap always open in all modes but what I'd REALLY might like is to be able to set the flap partially open in comfort mode, and always open in sport mode.
      04-29-2024, 04:51 PM   #3
Doctor X
Doctor X's Avatar
79
Drives: B58
Originally Posted by kmac1980 View Post
Hi everyone ,
Thanks
Kevin
I had this same issue, no matter what I tried doing through bimmercode/bootmod3 my flap would still close on its own.
What I had to do was have my dad rev my car and unplug the sensor as the flaps opened hahah.
No regrets.
      04-30-2024, 09:11 PM   #4
kmac1980
36
Drives: '19 540xi
i just want to know what the "expected results" are supposed to be from the Bootmod3 option of exhaust flap in sport mode.
I dont think i want it always open as i need a quiet level in comfort mode.
No regrets.
      05-01-2024, 11:25 AM   #5
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24463
Drives: 07-335/12-328/18-M4/21-M4CP
Get a valve controller instead and you can change the mode with a click of a button
https://x-ph.com/sale/
Phone number 702-494-9435
      05-01-2024, 03:40 PM   #6
kmac1980
36
Drives: '19 540xi
yeah i was hoping not to need to do this if i could code it to sport mode...
      05-01-2024, 03:41 PM   #7
kmac1980
36
Drives: '19 540xi
No regrets.
what car do you drive? i dont think the g30 b58 flap opens at all in park no matter how much you rev it in sport it stays closed...
      05-02-2024, 10:04 AM   #8
thecooltype
drive to survive
thecooltype's Avatar
87
Drives: 2017 540 XI
No regrets.
with bimmerlink you can also set it to open but this only seems to happen when you step on the gas..I ended up removing the fuse after opening it so it stays open all the time
      05-07-2024, 12:19 PM   #9
Doctor X
Doctor X's Avatar
79
Drives: B58
If you have factory mufflers the car will be quiet even if you have resonator and downpipes.
      05-09-2024, 05:08 PM   #10
jnnguyxn
Drives: 2021 540i
Do you have a link to the valve controller?
      05-09-2024, 05:21 PM   #11
mike@x-ph.com
24463
https://x-ph.com/sst-exhaust-flap-co...yoc-from-2017/
      05-12-2024, 02:13 AM   #12
blueboxer007
Drives: G30 540i
Normal behavior. With that setting on, the Valve opens under any amount of throttle input, it will then do the burble and proceed to close. Everytime. With that setting off, you have to hit certain conditions for the valve to open like a certain amount of throttle input or rpm achieved.
5post
