09-08-2021, 02:50 PM | #1 |
ex deus machina
124
Rep 968
S63 crossflow exhaust turbo manifold on N63
As title states, can you fit an S63 crossflow exhaust turbo manifold from M5/M6 F10/F90 to a N63 motor that uses twin scroll turbos? Specifically, N63R/N63TU2
I searched around but could not find anything You would think that F10 550i owners would try this but their turbos are not twin scroll like the M5 so that would not work without S63 turbos/downpipes, However all G30 M550i use very similar turbos to previous and current gen M5 so it would be interesting to see if this works.
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
09-08-2021, 10:05 PM | #3 |
162
Rep 761
09-09-2021, 07:51 AM | #4 | |
ex deus machina
124
Rep 968
if the manifold make the car more quiet I can add downpipes without an increase of rumble,
07-22-2023, 08:52 PM | #5 |
148
Rep 548
I agree as well. The lci m550 with an aftermarket exhaust sounds lumpy, and isn't smooth. It's not an engine you want to hear pushed even higher in the rev range. At least the m8 and m5 sounds smooth. The concern would be the turbos spool too fast and there's excessive torque down low causing havoc on the transmission.
09-17-2023, 11:20 PM | #6 | |
148
Rep 548
09-23-2023, 03:12 PM | #7 | |
ex deus machina
124
Rep 968
this will not work because the O2 sensors are reading per bank without crossflow, while M5 DME know that the exhaust is cross fed from one bank to another (from some of the cylinders) you will need to get M5 ECUs + Custom tune in order for this to work
09-24-2023, 02:17 PM | #9 | |
570
Rep 1,295
Would it not achieve similar results to what you want to achieve with a simple xpipe or h-pipe with dealing with the headache of swapping manifolds?
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-24-2023, 05:39 PM | #10 |
148
Rep 548
I actually put the M8 comp exhaust on and the 3.5 pipes are a huge improvement. With the 200 cell dps, response is phenomenal now but it's the nature of the motor-- lumpy sound. The nature of a cross banked manifold make for less turbulence in the exhaust from what I know. I'll put them in when I upgrade the turbos next year- either Pure or Weistec units.
09-24-2023, 07:20 PM | #11 | |
162
Rep 761
Thanks Byron |
10-06-2023, 11:12 PM | #12 | |
148
Rep 548
10-09-2023, 10:09 AM | #13 |
ex deus machina
124
Rep 968
No, 2K for DMEs + 1K for custom tune, not worth it
10-09-2023, 04:18 PM | #14 |
148
Rep 548
02-13-2024, 12:16 AM | #15 |
148
Rep 548
02-19-2024, 02:41 PM | #16 |
Rep 5
I've done this and need info and contact for your guy, please. I've completely upgrade the top end to S63 and just need the tune. I'm struggling finding someone who can help. PLEASE holler back - Thank you
02-23-2024, 07:09 AM | #18 |
23
Rep 47
Sorry for my bad english.....i hope you can understand.
I installed 200 cell metal catalytic converters from F90 M5 with the M5 sport exhaust system because of Stage 2 tuning. However, the system is very loud in its configuration. Therefore, I removed the preheating of the catalytic converters to reduce further problems with the neighbors. Now we have 79db/a by 3500U/min. |
03-07-2024, 01:18 AM | #19 | |
148
Rep 548
03-11-2024, 04:24 AM | #20 |
23
Rep 47
from turbos ->200 cell catted downpipes M5 -> M sports exhaust system.
( the picture are 2 sets. ) |
03-28-2024, 07:41 AM | #21 |
Rep 13
Hi guys,
Any updates on the s63 exhaust manifold on the n63 engine. Have done this job, but the O2 sensors reading cilinder 1,2,3,4 on bank 1 instead of 1,4,6,7 (cross bank manifold) Need to find out how to make the reference changes in the dme. Love the new sound, way better throttle response and the way the turbo's spools way faster (machined to fit the s63 manifold 70mm instead of 50mm) cheers! |
03-28-2024, 07:26 PM | #22 | |
148
Rep 548
Are you saying you still need to fix the sensor readings or you already fixed it? You can reach out to Uktu @ UNP tunes and see what he can do for ya. |
