Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > The Definitive Tyre Thread (FAQ inside)
Closed Thread
      07-19-2012, 10:49 PM   #1
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
814
Drives: a black car
- ask questions
- find answers
OK it’s a very common question on here with too many threads being created about what tyres should I buy, should I buy runflats (RFTs) or non RFTS, where should I buy tyres etc… Please read this thread first before creating a new thread about tyres!
You can ask questions in here. There’s always the search button too.
Here are some common topics… feel free to add to this down the bottom and I’ll update this post.
1. What are the advantages/disadvantages of runflats?
2. What are some good tyres?
3. Where can I buy tyres from?
list of threads started by forum members on specific tyres
4. What tyre size should I run?
5. Where should I get my tyres mounted?
6. What tyre pressure should I run at?
7. READ THE FAQ
1. Runflats are designed to do just that, allow the vehicle to operate safely in the sudden event of lost tyre pressure and/or allow the driver to continue driving up to a speed of 80 km/h in the event of a flat tyre for a few hundred KMs.
Advantages:
- Safety
- Convenience
Disadvantages?
- Stiff sidewall construction means a very firm ride and the tyres generally do not have as much grip as non-run flats
- Expensive, a lot more expensive than non-RFT counterparts which are better.
- Generally seen as more prone to punctures (hard statistic to track but people generally report more nails in tyres etc in RFTs than non-RFTs)
It’s my opinion, and that of many others, that non-RFTs are the way to go. Cheaper, better handling and providing more grip, these are all priorities to me above worrying about getting a flat tyre.
Again a slightly subjective topic but the current cream of the crop is generally accepted to be the Michelin Pilot Super Sport. It has loads of grip (wet and dry), handles very well, wears well and has good road manners (i.e quiet).
Some other recommended tyres for different scenarios and indicative pricing.
Best overall: Michelin Pilot Super Sport ~$1,800
High performance: Yokohama Advan Neova AD08 ~$1,300 (very grippy in the dry, still impressive in the wet and good road manners)
Road legal track tyre: Toyo R888 ~$1,400 (even grippier than the Yokohamas, but rather noisy)
Good value all-rounder: Continental ExtremeContact DW ~$1,200. This tyre is priced very reasonably and has been getting good reviews from customers.
*: this can’t be purchased at Continental tyre dealers in Australia as it was developed for the North American market. All these tyres are grey imports.
**: DW indicates Dry/Wet. There is also a DWS version getting around which means dry/wet/snow. There is no point purchasing the DWS for Australian conditions.
Kumho KU31s often come up in threads, these tyres are good for the price and on a 325i will do the job... on a 335i, I'd recommend something grippier.
Ideally, it’s best to support local vendors where you can. I’d highly recommend Tyrepower in North Melbourne, (03) 9329 7333, you can PM ‘Vans’ on this forum.
Otherwise, it’s hard to beat www.tirerack.com. Good site for reading reviews as well.
If you need local rubber fast here are forum members recommendations:
Sydney: Tempe tyres, Taleb tyres, St George tyres
Melbourne: Tyrepower North Melbourne
Brisbane: TBA
Perth: TBA
Adelaide: TBA
4. What size tyres can I fit?
Use the search tool.
All E9X models can comfortably fit up to 19" wheels without any modifications.
20" wheels can fit as well depending on width and offset.
Generally accepted 19" fitment is:
Front: 235/35/19
Rear: 265/30/19 (255-275 works as well)
5. Where can I get my tyres mounted?
If you buy tyres online you'll need them mounted, most tyre places in Sydney will charge between $60 and $80 to fit and balance 4 tyres. Some members have reported the shop getting the shits with them due to not buying locally so this can be used to list all the places members have had tyres fitted before
Sydney: Tempe, Taleb, 7day tyres (Granville), Payless Tyres Hume Hwy South Strathfield
Melbourne: TBA
Brisbane: TBA
Perth: TBA
Adelaide: TBA
6. What tyre pressure should I use?
BMW/Manufacturers in general will suggest 30-32psi, which gives a more 'supple' ride.
This comes down to a matter of personal preference but most people will tend to run high 30s all around. This will see longer tyre life, better fuel economy and sharper handling. Don't overinflate your tyres though - this can decrease traction significantly and cause uneven wear patterns.
Try this out:
Front: 38psi
Rear: 38 psi.
Advanced drivers might tweak the tyre pressure on each axle to finetune their handling
A slightly lower front tyre pressure may reduce understeer, but again, many variables and recommended for advanced drivers only.
It's also worth nothing these are 'cold' temperatures, as a rule of thumb, when the tyres are hot and you go to check their pressures after some street driving they will gain +4psi.
If you look at the centre of your tread pattern, and notice wear occurring there and not on your sidewalls, this indicates overinflation
If the shoulder of your tyres wear quicker than the inside, this indicates under inflation.
Tracking & Tyre Pressures
Street tyres will get very hot on the track and as such they will inflate a fair bit temperature wise over what you think you've set it at. It's hard to say set it to xx psi as there are many variables to consider.
(or slightly lower than your street setup OR equal to OE spec) and going out for a few laps. After that, check your pressure to see what it's at, it might be 40psi, which would bring us to our ideal range of 38-42 for most tyres and applications.
When tyres get hot, naturally they'll start to lose a bit of stickyness and you'll feel the car squirm around a bit.
Do:
- start your first session with a lower tyre pressure
- check them constantly
- inspect the sidewalls for signs of underinflation
Don't
- use your street tyre pressure of 40+... many tyres will have a max of 50psi and on the track, you could easily gain 10psi which would post a safety threat
7. FAQ
Can I use non-RFT tyres on my BMW wheels?
Yes!
Will putting non-RFT tyres on my BMW void warranty/insurance?
No!
Can I put RFT tyres on aftermarket wheels?
Technically, yes, but the RFT properties won't work as the wheels don't have the special lip required to keep the tyre on the rim in the event of a flat
Can I repair a RFT tyre?
Manufacturer says no, but as long as it's not too close to the sidewall and you haven't driven on the tyre while flat, then yes you can get it repaired just like a conventional tyre
I bought tyres from tirerack, where can I get them mounted?
See point 5 above
If I put 19inch wheels on my car will the ride be bumpy?
Generally accepted that it will be due to the lower profile rubber, however if going from 17" RFTs to 19" non-RFTs then the ride would be comparable. It's rather subjective.
If I have non-RFTs and get a flat what should I do?
1. Carry a slime kit and compressor (available from Repco, Supercheap Auto etc)
2. Call for roadside assistance
3. Have a friend drop off a spare wheel (make sure they bring tools!)
What's the factory torque spec for our BMW lugbolts?
92 ft lbs... +/ 7ft lbs.
I've heard of lugbolts coming loose and becoming brittle with age - is this true?
Yes, especially when tracking the vehicle. Keep spares on you or at home, or for peace of mind change the lugbolts annually when tracking (or at least inspect them)
Do tyres go 'off'?
Yes! When purchasing new it's ideal if they have a build date within the last 12 months, 12-24months is getting on and if 24months + you better be getting them damn cheap.
If you drive a car (especially noticeable in high performance cars) that has tyres already 6-7 years old even if they've only done 5,000kms, the silica compound just degrades and they'll provide very little grip.
Be wary of tyre shops selling 'cheap' rubber that is already a few years old.
All advice is general and does not take into account your specific circumstances or rules and regulations of your state or territory.
jard35.50
      07-19-2012, 10:50 PM   #2
814
Drives: a black car
post additions/questions and I'll add them to the list.
      07-19-2012, 11:05 PM   #3
Michael BD
Michael BD's Avatar
Australia
25
Drives: BMW M340iXDrive
Thank you for all the information, this is fantastic.
Can you please add something on what to do if I run non-RFTs and I get a puncture. What to do ? Should I have in the boot some foam or other stuff to temporarily drive the car?
      07-19-2012, 11:26 PM   #4
814
Drives: a black car
Ideally, call NRMA/RACV/RACQ etc... and get them to sort you out. Else have a friend drop off a spare.
Worst case, you can 'limp' to somewhere to get a new tyre mounted.
      07-19-2012, 11:43 PM   #5
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
slime kit ftw
      07-20-2012, 12:01 AM   #6
814
Drives: a black car
Originally Posted by pavo335 View Post
slime kit ftw
good idea. forgot about that. I actually have one too
jl795.00
      07-20-2012, 12:37 AM   #7
mrtanz
Australia
24
Drives: BMW 2008 325i upgrade
Stu any chance of adding ideal tyre pressure for tracking, general road use
i know ther eis the tyre placard but most of the times they are for the stock tyres
      07-20-2012, 01:21 AM   #8
Michael BD
Michael BD's Avatar
Australia
25
slime kit ftw
Which is what?
      07-20-2012, 02:39 AM   #9
814
Drives: a black car
Will do
      07-20-2012, 02:57 AM   #10
MO3
MO3's Avatar
Australia
163
Drives: DCT M3
Dry Grip.......................97%
Wet Grip.......................89%
Road Feedback...............96%
Progressiveness.............89%
Wear............................91%
Comfort........................88%
Buy again......................99%
Dry Grip........................92%
Wet Grip........................60%
Road Feedback................90%
Progressiveness..............90%
Wear.............................69%
Comfort.........................73%
Buy again.......................90%
Current: 2018 M3 | individual Fire Orange
Gone: 2016 M4 | BSM
      07-20-2012, 02:57 AM   #11
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
slime kit ftw
Which is what?
There are a few threads with the slime kits, if you can't find them (remember search is your friend) then google slime kits. Same as BMW mobility kit but IMO better
      07-20-2012, 06:28 AM   #12
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
I'm going to highly recommend Mobile Tyre Shop in Melbourne. They come to you. Just had my front tyres changed by Paul.
See my thread here:
http://www.e90post.com/forums/showthread.php?t=720750
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      07-20-2012, 08:33 AM   #13
sbce90
Me Boosta
sbce90's Avatar
Australia
250
Drives: 320i / MB C63 / VW up!
Quality thread Stu! Sticky
      07-20-2012, 08:38 AM   #14
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
For, #3, I would HIGHLY recommend discounttiredirect.com
great pricing, and free shipping. If not, take the printed quote in to your favorite tires retailer and have them match it. voila! money saved!
      07-20-2012, 03:32 PM   #15
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
Free shipping to Australia :
      07-20-2012, 05:23 PM   #16
QLD
QLD's Avatar
44
Drives: 2010 LCI E92 - Mineral White
Great thread - thanks.
I always wonder when I see people say you can fit 275s on the rear no probs, is that for standard suspension only?
Mines got lowered springs and I gotta say things look pretty snug between the tyre and the wheel arch... certainly doesn't look like there much room for expansion?
..sweet torquin' diesel!
      07-20-2012, 05:26 PM   #17
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Ohh didnt see the section it was posted in. Thought it was a general thread based on thread title.
My bad. I didnt know tirerack serves australia. I wonder if discount tire does.
      07-20-2012, 05:29 PM   #18
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
Yep I have 275 pss and fits just right lowered
      08-01-2012, 04:49 AM   #19
335arctic
335arctic's Avatar
Australia
Drives: 335i Coupe
I use the Yokohama AD08 stock size.
Front: 225/35/19
Rear: 255/30/19
It turns out that AD08 have a squared sidewall, so its actually closer to 235 & 265 in reality. A friend use to have Bridgestone RE-11 & he switched to AD08, same measurements,the AD08 have more contact surface. But, the downside is that is kinda noisy. Meaning that I need a louder exhaust LOL.
19" 230 Wheels/19" Work Meister S1R - Yokohama Advan AD08 - Stett CAI Intake - M3 strut brace - M3 Rear swaybar - KW V1 - Kraftwerk Tune - ER Charge Pipe - Forge DV's
      08-02-2012, 07:14 PM   #20
814
Drives: a black car
FAQ Updated:
Do tyres go 'off'?
      08-03-2012, 03:10 AM   #21
MO3
MO3's Avatar
Australia
163
Drives: DCT M3
Is the build date somehow written on the inside of the tyre?
Gone: 2016 M4 | BSM
      08-03-2012, 03:34 AM   #22
814
Drives: a black car
It's on the outside, a 4 digit code after the sizing.
eg:
3010 = 30th week of 2010
1012 = 10th week of 2012
4009 = 40th week of 2009 and so on...
Closed Thread
