Kickdown Ruined?
04-15-2014, 10:28 AM | #1 |
34
Rep 197
Drives: BMW 328i 2007
So i test my cars power sometimes . When ever i use the kickdown which is when i press the accelerator all the way until it clicks , while im shifting manually the car automatically downshifts. When the rpms get really high i try to shift but it doesnt shift up to the next gear. Basically it gets stuck in gear for some odd reason until i release the gas
Anyone know whats up :O |
04-15-2014, 10:42 AM | #2 |
Rep 44
Does your car shift by itself if you go all the way to redline? My car does this weird thing where above 6K RPM or so the car will ignore my manual shift requests until the car hits redline at 7K. At that point, the car will shift on its own.
This is especially annoying in third gear. On the 335, the car is way out of the powerband by the time it finally shifts at redline in third. Once the car shifts finally into to fourth on its own at redline, the acceleration picks up noticeably. |
04-15-2014, 10:58 AM | #3 |
34
Rep 197
I think we both have the same problem! :|
04-15-2014, 10:59 AM | #4 | |
7478
Rep 10,120
04-15-2014, 11:02 AM | #5 |
101
Rep 535
04-15-2014, 11:06 AM | #7 |
34
Rep 197
04-15-2014, 11:07 AM | #8 | |
34
Rep 197
04-15-2014, 11:58 AM | #10 |
84
Rep 1,099
wen u hit the kickdown, the click at the bottom, the car will downshift into the lowest gear it can and redline every gear. if u wanna shift manually don't hit the kick down.
04-15-2014, 12:54 PM | #11 | |
Rep 44
Using the paddles or shifter below 6k results in an immediate shift, as you would usually expect. I've written the problem off as a software design issue put in place to keep you and the car from trying to call for a shift at the same time and result in upshifting the car 2 gears instead of 1. |
04-15-2014, 01:01 PM | #13 |
Rep 44
It could just be something weird with the transmission software for my 07 build. You are correct that does take a half a second or so to register a manual shift. However, I could sit above 6k for 4-5 seconds and the car will refuse to shift manually until I hit redline.
04-15-2014, 01:42 PM | #14 | |
30
Rep 780
04-15-2014, 01:54 PM | #16 |
34
Rep 197
Maybe our Automatics are garbage i want a manual!
04-15-2014, 02:33 PM | #17 |
Rep 44
