BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum Unable to lower 3rd row right seats
      10-02-2021, 01:15 AM   #1
Len1011
Drives: G07 X7
Hi,
I'm unable to lower the right 3rd row seat, just get the warning chime and a message on the dash saying. 'Rear right seat movement restricted'. All other seats move around fine.
Anyone come across this?
Thanks
      10-02-2021, 08:31 AM   #2
unfoundnemo
unfoundnemo's Avatar
1920
Drives: 2022 i4 M50
2022 BMW i4 M50  [0.00]
2022 BMW X7  [0.00]
Originally Posted by Len1011 View Post
Hi,
Thanks
Yes, it's pretty common... poor design.
I find that if I pull up on the strap that releases the headrest a few times, or do it while it's initializing the process, it will often work it's way out and go down on it's on a few times before it is an issue again.
Mine hasn't been too bad, but it happens probably 30% of the time. I don't play with them often, so a minor annoyance, but at some point I have to remember to tell my SA.
Here's a SB on the issue thenew3 was kind enough to provide. My issue is likely the routing of the Bowden cable:
https://g07.bimmerpost.com/forums/sh...00&postcount=2
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC
      10-02-2021, 08:40 AM   #3
NVRfollo
866
Drives: 2021 M550
Hi,
Thanks
Do you have car seats in the 2nd row that are anchored? Do you have the rear window controls disabled? I had same issues with 3rd until I undid the anchors before doing anything to the 3rd row. I also enable the rear window controls before I touch the 3rd. I reenable after I am done
      10-02-2021, 08:56 AM   #4
Len1011
Drives: G07 X7
Hi,
Thanks
So I have a child on the opposite side via the seat belts not isofix.
I have the rear window controls enabled
      10-02-2021, 08:59 AM   #5
Len1011
Drives: G07 X7
Hi,
Thanks
https://g07.bimmerpost.com/forums/sh...38;postcount=2
Hey, are you referring to the headset straps on the 3rd row seats? Don't think I've ever noticed them, are they hidden at all?
      10-02-2021, 08:59 AM   #6
NVRfollo
866
Drives: 2021 M550
Not sure if the rear controls disable the 2nd row movement, but when you adjust the 3rd row, the 2nd row has to move forward to make room if it is all the way back
      10-02-2021, 09:16 AM   #7
unfoundnemo
1920
Drives: 2022 i4 M50
2022 BMW X7  [0.00]
Yes. They're not hidden. You could see the strap in the diagram of the SB at that link. They stick out a good couple inches.
      10-02-2021, 10:54 AM   #8
X7Newbie
Drives: BMWX7
Hi
I had this problem and the cable snapped so it required service to resolve.
      10-02-2021, 04:23 PM   #9
Len1011
Drives: G07 X7
Originally Posted by X7Newbie View Post
Hi
Is it a big job? Require parts from Germany (like most things)?
      10-02-2021, 10:33 PM   #10
MoistureFarmerBBY
Drives: 2021 BMW X7 xDrive40i
Hi
I just took my 2021 X7 (4K miles) in for this very issue yesterday. Parts are in order and I'm told it's a "big" 1-2 day job.
      10-03-2021, 03:13 AM   #11
Len1011
Drives: G07 X7
Hi
Thanks
      10-03-2021, 10:01 AM   #12
X7Newbie
Drives: BMWX7
It took about 48 hours in Canada so not bad.
      11-29-2021, 07:56 AM   #13
MystroX5
MystroX5's Avatar
6295
Drives: 2020 X7 M50i/ 911
My left rear 3rd row is going on for this. Started to act up in the fall. The headrest wouldn’t flip down when pushing the button but if I manually pulled it down, the seat electrics would fold flat. Now the seat is jammed in the upright position regardless of manually lowering the headrest.
      11-29-2021, 06:43 PM   #14
jhb
18
Drives: 2021 X7 40i
Originally Posted by MystroX5 View Post
My left rear 3rd row is going on for this. Started to act up in the fall. The headrest wouldn't flip down when pushing the button but if I manually pulled it down, the seat electrics would fold flat. Now the seat is jammed in the upright position regardless of manually lowering the headrest.
I had this issue almost immediately on delivery. They had to order the Bowden cable which took about a month. Fixing it took 2 days if I recall. Haven't had an issue since, but I rarely use them.
2021 X7 40i
2015 X5 35d
2012 x5 50
2006 x5 4.4
2000 528i: 1989 525i: 1986 528e
MystroX56294.50
      11-30-2021, 06:57 AM   #15
MystroX5
MystroX5's Avatar
6295
The third row for me is mainly for carrying luggage on long trips. No one ever sits in the third row.
      01-06-2022, 09:38 PM   #16
MystroX5
MystroX5's Avatar
6295
I forgot to add follow up on the fix. This is so common there is a TSB on it. You will know when you will soon have this done when your 3rd row head rest starts to not drop easily when you lower the 3rd row seats. My headrest started to stick and I would manually pull the release strap under the one head rest that wouldn’t drop and the power seat would lower. Eventually even manually lowering the head rest, the one seat would not lower at all. This is when the TSB fix is required. Everything looks and works great now. Be aware the service department will have to order the parts in after first diagnostic. 1/2 day in the shop for first diagnostic and I took my X7 home to wait for parts to come in. Parts took 3 days to come in. The actual seat fix with new Bowden cable is 3/4 of a day.
Here is what my service department found and fixed.
MISC MISCELLANEOUS CUSTOMER CONCERN
A
CUSTOMER STATES 3RD ROW ON DRIVERS SIDE THE MOTOR WILL NOT GO ITS
STUCK.HE CAN HEAR IT RUNNING
THE
HEAD REST STARTED FIRST NOT
WORKING IN AUGUST. NOW IT WONT WORK AT ALL.
• 173
W
52-30-7-485-444 BOWDEN CABLE RELEASE: 521061
1-
52-20-9-473-697 ACTUATOR, FOLDING
BACKREST: 521061
PARTS:
0.00
LABOR:
0.00
OTHER:
0.00
TOTAL LINE C:
4762
L/R SEAT HEAD REST NOT DROPPING AND SEAT JAMMING WHEN TRYNG TO FOLD
DOWN. SHORT TEST
L/R SEAT LOCK AND SEAT POSITION FAULTS. REMOVED UPPER
, SEAT COVER TO ACCESS CABLE DRIVE ACTUATOR,
FOUND SEAT CABLES JAMMING
DURING RELEASE PROCEDURE. REMOVED REAR SEAT ASSY
FOUND SEAT COVER
, DEBRIS JAMMED IN RELEASE MECHANISM. PARTIALLY DISASSEMBLED SEAT FRAME,
, REPAIRED AND RE INSTALLED ASSY
REPLACED R/R 3RD SEAT ACTUATOR AND
, CABLE FOR HEAD REST RAN SEAT INITIALIZATION PROCEDURE CLEARED CODES
      01-07-2022, 09:01 AM   #17
bradythedog12
127
Drives: 2020 X7 M50i, 2014 X6 50i
Hey MystroX5 - how long before this started happening in ownership time and/or mileage?
      01-07-2022, 09:33 AM   #18
MystroX5
MystroX5's Avatar
6295
Depends how many times you lower the 3rd row I would think. I didn’t lower my 3rd row many times at all and it started a year after ownership for me. If you use your third row a lot, I suspect it’ll happen within the first couple months if it’s going to happen. Some here had this done within the first month. For me and my use of my X7, I need the cargo space for trips and I dont ever take more than four passengers at one time so my third row is down most of the time.
Just watch to see if the 3rd row headrest start to get sticky or delays dropping after you push the lowering button. If it’s starts this, then just plan on a scheduled service when it’s convenient because it’s going to have to be fixed. There is a lot of internal complicated movements to lower the third row seats and all of these movements have to happen in a specific order. If the headrest doesn’t drop right away then the rest of those operations can get jammed or confused and the rear seat won’t lock, sensors won’t trigger, etc….
      01-07-2022, 09:51 AM   #19
maitrimk
76
Drives: 2021 G20 330i, 2022 G07 X7 40i
Would this have been fixed on 2022 year or possibly same crap?
      01-07-2022, 10:15 AM   #20
MystroX5
MystroX5's Avatar
6295
Across every year. I believe it’s the way they route the Bowden cable in manufacturing. Why they don’t change this routing by now is anyones guess???
At this point I assume BMW has bigger fish to fry by trying to see if the customer notices milk crates as rear seats and if a $200 credit is acceptable.
      01-09-2022, 01:52 PM   #21
mitch57
805
Drives: 2020 BMW X7 xDrive40i
How did you ever find out about the problem if the 3rd row is down all the time? Mine are down all the time.
Do we all need to lower and raise our 3rd row seats until it fails to get this covered while still in warranty? Otherwise, you know it's going to happen the one time I need to raise the 3rd row AFTER the warranty runs out.
      01-09-2022, 03:22 PM   #22
MystroX5
MystroX5's Avatar
6295
I was detailing my leather in the fall while the weather was warm and getting ready for a long cross country trip this winter. Thank goodness I got it taken care of before we go.
xbimmers
