04-15-2011, 02:10 AM | #23 | |
Supreme Allied Commander
3863
Rep 54,426
Drives: F80 M3
The front we will have to wait and see, some sources say the 1-series M uses the M3 wheel carriers, others say it's simply the 135i style wheel carriers. Can anyone come up with a photo to show me? |
04-15-2011, 08:00 AM | #24 |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
04-15-2011, 10:39 AM | #25 | |
3863
Rep 54,426
Drives: F80 M3
So to the OP, the M3 fronts struts will work only if you were to install M3 wheel carriers as well. |
04-16-2011, 04:36 PM | #26 |
53
Rep 659
[QUOTE=HP Autowerks;9378063]Very M3 like.
So to the OP, the M3 fronts struts will work only if you were to install M3 wheel carriers as well.[/QUOTE how much are the carriers? |
04-16-2011, 09:17 PM | #27 | |
3863
Rep 54,426
Drives: F80 M3
[QUOTE=crex;9386993]
M3 control arm conversion kit and a good set of coilovers will net you much better results. |
04-17-2011, 06:52 PM | #28 | |
890
Rep 7,047
I'm asking what are the differences that make the 1M, compared to the M3, other than just a 3" shorter chassis and susp tuning? I think the 1M is an excellent deal for a performance vehicle. Having this much M3 in it makes the deal even sweeter. I clearly admit that I didn't now the 1M has this much in common with the M3. I was under the impression that the 1M was the 1 series chassis, everything except the body, only widened to give better handling and to accommodate the wider wheels/tires, along with some M3 parts to improve handling. But the, with the M3 sub-frames, control bits, and steering, I can see why it's "essentially" the M3 chassis. Last edited by RPM90; 04-17-2011 at 07:13 PM.. |
04-17-2011, 07:31 PM | #29 | |
3863
Rep 54,426
Drives: F80 M3
