04-25-2023, 12:34 PM | #90 |
5490
Rep 8,830
One thing about keeping the valves open all the time is your cold starts will be WAY louder this way. I have the Dahler exhaust valve controller and if i force the valves open during cold starts its easily 2-3x as loud.
05-01-2023, 10:37 AM | #91 |
5490
Rep 8,830
Confirming that the Dinan Xpipe works with the Akra rear section perfectly. I'd say it increases the volume by 15-20% overall. Keeps the exotic tone but just more of it. Any competent shop can install this in under an hour and thats taking their time.
05-01-2023, 10:42 AM | #92 |
Self-Deprecating Narcissist
7266
Rep 6,561
Not sure if it is just the photo or if those clamps are so close together that it may cause some knocking or clanging.
05-01-2023, 10:43 AM | #93 | |
819
Rep 838
Drives: ...
Garage List 2015 Lamborghini Hu ... [10.00]
2018 BMW M3 [10.00] 1997 BMW E36 [0.00] 2022 BMW X5M [0.00] 2022 BMW 330i [0.00] 2023 Cadillac Escalade [0.00] 2023 Honda Civic Ty ... [10.00] |
Please post sound clips
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
05-01-2023, 10:47 AM | #94 | |
5490
Rep 8,830
05-01-2023, 10:49 AM | #95 | |
5490
Rep 8,830
I'll try to get clips this weekend but the iphone never seems to capture it accurately.
Wtfitzvi818.50 |
06-08-2023, 10:13 PM | #98 |
22
Rep 29
Anyone have the size or good recommendation for replacement band clamps. The set for front and X connection are not great and have minor leaks. When really tightened down they either warp in odd way or the bolt heads bottom against the clamp side.
Could be way better from factory |
06-09-2023, 05:57 AM | #99 |
5490
Rep 8,830
Interesting. I would have to re-check mine. I do noticed that after installing i feel more "rumbling" inside my car while the car is idling.
06-09-2023, 08:24 AM | #100 |
22
Rep 29
Mainly when cold start, seems there is some pipe expansion. I replaced 2 of the bolt sets with flange one and its better but the metal of the band is touch low qual. Different levels of stretch across the whole set.
The rear connectors to the Stock exhaust seem fine, just the other 4 I am assuming a good set of 3.25 inch id or whatever the true dia is would work but was wondering if anyone had the actual dimensions before i remove it again. Thoughts appreciated Last edited by -DB-; 06-09-2023 at 04:05 PM.. |
06-11-2023, 02:40 PM | #101 |
119
Rep 287
you made a video of the sound?
09-25-2023, 07:57 AM | #103 |
3917
Rep 3,130
09-25-2023, 08:11 AM | #104 |
325
Rep 8,091
09-25-2023, 11:57 AM | #106 |
92
Rep 199
Did anyone tried Full decat both primary and secondary cats as downpipes + dinan Xpipe then other part of exhaust stock ?
I have Full decat + GPower exhaust which has a mid section with resonator but I get drone at low rpm in highway speeds so I am thinking in changing mid section with X-Pipe and rear end of exhaust stock exhaust so that way I get less drone and big noise since using XPIPE makes lots of difference. |
04-24-2024, 10:38 AM | #107 | |
DD214
273
Rep 286
Has anyone been there to test fit yet so we can see if the X-Pipe will work on the LCI? If not, I might just order and be the test dummy. |
04-24-2024, 11:05 AM | #109 | |
3917
Rep 3,130
Does not. Tis going to require a bit different pipe as the connection method to the DP's differs between the S63 (clamp) and S68 (gasket). |
Falcon90034.50 |
04-26-2024, 08:50 AM | #110 |
DD214
273
Rep 286
