Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d Performance Tuner Remap - JBD?
      03-14-2011, 12:24 AM   #1
schulteonline
Drives: 2011 335d M Sport
Looking to get a remap for my 335d. Does anyone have experiance with the JBD from Burger Motorsports?
      03-14-2011, 12:35 AM   #2
f00dstamps
24
Drives: 2010 BMW 335d
I've had my JBD for 4 days and my car is noticeably faster. I had it on the stock setting for 10 minutes before I dialed it all the way up to 100%. I have not thrown a code yet.
      03-14-2011, 08:21 AM   #3
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
Mine is running great on 100%. No problem pulling away from a stock 335i. 0-60 in 4.5 seconds, and 12.9 ETs.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      03-14-2011, 08:50 AM   #4
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Here is some info on the JBD. Its a great inexpensive way to add some serious pep to the D.
http://www.e90post.com/forums/showthread.php?t=422987
and a dyno...
      03-16-2011, 01:27 AM   #5
schulteonline
Thanks guys for the feedback. Sounds like this is the ticket. I am going to pull the trigger and get it comming ASAP. Can't wait to see how this performs.
      03-16-2011, 08:42 AM   #6
cssnms
cssnms's Avatar
208
Drives: 2011 BMW 335d
To clarify, I don't think the JBD is considered a "remap." It's a tune box which tricks the rail pressure sensor into delivering more fuel.
      03-16-2011, 09:48 AM   #7
bimmerlex
bimmerlex's Avatar
26
Drives: 2018 F15 X5 xDrive35d
You can't go wrong with Burgertuning
      03-16-2011, 10:00 AM   #8
e92bmw
Drives: 335i
2007 335i coupe  [0.00]
Somebody correct me if Im wrong, but I think the jbd works like the jb+(for the i) it trick your car into thinking your in higher altitudes so you run more boost.
      03-16-2011, 11:57 AM   #9
Mike@N54Tuning.com
4918
No, the JBD remaps the fuel curve and only slightly increases boost pressure.
Mike
The_Wood106.00
      03-16-2011, 02:32 PM   #10
vase330
vase330's Avatar
102
Drives: 19 E63S; 15.5 RangeRover ATB
Does it eliminate that lag at tip-in I felt in the X5 35d?
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      03-16-2011, 02:33 PM   #11
Mike@N54Tuning.com
4918
Yes, throttle response is greatly improved.
Mike
      03-16-2011, 02:58 PM   #12
vase330
vase330's Avatar
102
Looks like I will be getting this when I get my diesel X5. I wonder if only downside is more fuel consumed, but going easy should alleviate that! I like to have the GO-ability when I want it and sip the fuel when just tooling around.
      03-16-2011, 03:10 PM   #13
cssnms
cssnms's Avatar
208
No, I believe the JBD works like most diesel tune boxes (Mike correct me if I am wrong here). The JBD intercepts the high pressure rail sensor signal (that's what the JBD plugs into) and it sends a different signal to the ECU which demands more fuel pressure, in otherwords it tricks the ECU into raising the pressure on the high pressure fuel pump which results in more fuel being delivered and that's where the power comes from.
As I understand it, that's NOT a remap in the traditional sense. Diesel tune boxes do nothing more then by-pass the rail sensor and deliver a signal to the ECU that tells it to raise fuel pressure vs the ECU giving a comand based on it being reprogrammed.
      03-16-2011, 03:27 PM   #14
f00dstamps
24
With slightly more aggressive acceleration because of all the additional power and according to the OBC, I get better gas mileage. I'm not sure if it's completely accurate. I have read that it will take time for the OBC to adjust and recalibrate itself.
      03-17-2011, 12:20 PM   #15
schulteonline
I think cssnms is correct. I found a pretty good writeup on the differance between remaps and tune boxes. Enjoy the read.
http://www.endtuning.com/dieseltuningboxes.html
      03-19-2011, 07:06 AM   #16
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
If you plan on running it 100% be sure to include the scan tool option to clear codes.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      03-19-2011, 09:01 AM   #17
cssnms
cssnms's Avatar
208
      03-19-2011, 09:24 AM   #18
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
That was a very interesting read. The jist of it seems to be that remaps are preferable to tuning boxes because they work directly with the ECU as opposed to tricking the ECU, and therefore put less strain on the engine, injectors, and other supporting engine components. Perhaps somebody more knowledgeable can chime in and make sure I'm getting it right.
In any case, there are only 2 things holding me back from getting a JBD. One is I don't want to risk anything with my warranty. And the other is concern about long term reliability. Many people are running the JBD and are very satisfied, but what worries me is what will happen after 50,000 or more miles of running the car at a greater-than-factory power levels. Perhaps that's not as much of an issue for someone who's on a lease and planning on changing out of the car in a few years, but I plan (and hope) to keep mine for a very long time.
      03-19-2011, 10:02 AM   #19
cssnms
cssnms's Avatar
208
I don't claim to be more knowledgable then you, but in a nut-shell your observations are correct. Although a remap would be more desirable IMO, I believe this to be relatively benign way to increase power in your diesel.
I believe the repracutions/risks of using the JBD are lower then the gas juice box variant. Diesel tune boxes place extra load on the high pressure fuel pump and your concerns about long term reliability as it relates to these added stresses are valid. That said, there are tolerances built into the various mechanical components, now whether or not the JBD exceeds those tolerances I don't know. I would venture to guess that one would be well within those tolerances at the base setting.
      03-27-2011, 10:17 AM   #20
rogerdiaz
28
Drives: 2015 335i
Same
Ditto, would like to see long term data/issues
      03-27-2011, 12:36 PM   #21
azwillnj
318
Drives: 2023 M340i xDrive
What kind of mileage increases are you seeing?
Alex.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      03-28-2011, 08:02 PM   #22
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
63
Drives: Audi SQ5
Subscribed and can anyone here verify if the BT scanner can only be linked to one VIN or up to 3?
