F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F80 Front Wheel Bearing & Hub on F30
proTUNING Freaks
      05-01-2024, 09:42 AM   #1
Jaik
Drives: White
Howdy, does anyone know if it's possible to mount F80 front wheel bearing and hub onto F30? The wheel carrier mount looks very very similar? I'm adding F80 M3 rotors to the car and the F80 front wheel bearings have extra support pins to support the rotor. The wheel speed sensor is different between F30 and F80 but could be looked into
Would anyone also happen to have the height of the bearing and hub from the face of the carrier mount to the face of the hub? I'm keen to understand if this is taller or shorter than F30 bearing.
Thanks!
      05-06-2024, 01:50 PM   #2
erball
Professional Mashocist
12
Drives: 19 Individual 440I
Help us understand why you'd want to? I'm assuming you've already purchased the caliper offset kit (in order to fit the 380mm rotors), so I'm struggling to understand why this would be needed.
Appreciate 2
Polo088161616.00
Dom147102.50
f30post
