03-11-2024, 03:50 PM | #1 |
11
Rep 43
Individual part numbers for the BMW M Performance Brake Kit components
Does anyone have the individual part numbers for the BMW M Performance Brake Kit components, or do you have suggestions on where I can find the part numbers?
I am trying to piece this upgrade together without buying the kit from BMW. |
03-11-2024, 08:37 PM | #3 | |
3132
Rep 4,380
low ball park for just the calipers 2x rear calipers, $1500 ish 2x front calipers $2000 ish |
03-11-2024, 11:18 PM | #4 | |
11
Rep 43
alohasurftoad3132.00 |
03-11-2024, 11:19 PM | #5 |
11
Rep 43
03-12-2024, 04:54 AM | #6 | |
Idiotic lifter of heavy stones...
2015
Rep 2,195
Drives: 2015 F31 325D M Sport touring
As an example: Front discs: https://www.realoem.com/bmw/enUS/sho...diagId=34_1949 Part no.2 - 34106797603 (grooved/slotted discs) And pads: https://www.realoem.com/bmw/enUS/sho...diagId=34_2012 Part no.8 - 34116865460 Brake dust shields are the same
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
PininMargherita10.50 |
03-12-2024, 02:13 PM | #7 | |
243
Rep 499
Most major online retailers give you a kit contents breakdown. For example this is from FCP euro
What is your current car?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
03-12-2024, 03:16 PM | #8 | |
11
Rep 43
I have a f32 428i 2017 with 6MT |
rlesko242.50 |
03-12-2024, 03:17 PM | #9 | |
11
Rep 43
03-12-2024, 04:06 PM | #10 | |
2015
Rep 2,195
Put the last 7 digits of your VIN into the box at the top of the page and it'll bring up your exact car Look at the brakes diagram and check to see if there's only one part number for the brake disc shield. IIRC they're all the same inc the M3 & M4
03-12-2024, 05:21 PM | #11 | |
243
Rep 499
Also, the genuine rotors which are grooved and slotted, but not cross drilled, are known to make some sort of ticking sound which can be bothersome.
03-12-2024, 08:10 PM | #12 | |
11
Rep 43
03-12-2024, 09:33 PM | #13 |
29
Rep 103
Man you guys make this look real hard. I could sell you my M3/M4 front and rear with Rotors for way less than all that. I also have Seemlegit adapters. Just so you know use Ebay for lower cost low mileage used parts like the dust shields.
03-12-2024, 10:00 PM | #14 | |
11
Rep 43
I've gotten conflicting info on whether I need new dust shields, but visually, I think the front 100% needs new dust shields. Someone mentioned I can just bend the existing ones back but I'd rather not and do this the right way. Vin last 7: F713031 This is what I have on the car now for the rear: Do you know which model BMWs came with the 370mm front and 345mm rear rotors so I can better ebay? Thanks for the suggestion |
03-12-2024, 10:01 PM | #15 |
11
Rep 43
Also, what is the "Seemlegit adapters" ?
03-13-2024, 07:51 AM | #16 |
243
Rep 499
Its a carrier bracket which would adapt F8x calipers to F3x wheel hub, allowing you to put F8x rotors and calipers on.
03-13-2024, 04:43 PM | #17 |
11
Rep 43
03-13-2024, 05:07 PM | #18 |
243
Rep 499
03-14-2024, 05:51 AM | #19 |
2015
Rep 2,195
They can be retrofitted to all F3X cars IIRC; you just need to ensure you run 18" wheels at a minimum to clear the calipers
03-15-2024, 12:45 AM | #20 |
132
Rep 21
Drives: 2018 Glacier Silver F31
I recently upgraded my brakes with the performance kit, but didn’t use the pads. If you’re interested I’ll letting them go along with the read dust shields. My car didn’t need them.
03-15-2024, 09:50 AM | #21 |
11
Rep 43
03-23-2024, 03:44 AM | #22 |
65
Rep 127
I made a similar upgrade about 2 years ago.
Parts list: https://f30.bimmerpost.com/forums/sh...3&postcount=15 Pictures: https://f30.bimmerpost.com/forums/sh...4&postcount=23 Thread: https://f30.bimmerpost.com/forums/sh...php?p=26543141
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
