BMW: Change your Oil the RIGHT Way! (Step-by-Step)
01-11-2017, 12:06 PM | #1 |
ArmoDIY channel! www.youtube.com/user/eLToROLoCoTV
18
Rep 16
How to Do an Oil Change on a BMW 323i/325i/328i/330i/335i/335is E90/E92 N54
Actual Model of the Car in the Video: 2009 BMW 335i E90 N54 Sedan Hope my video was helpful! Like and Subscribe for more interesting DIY videos! Leave Comments with Questions or Suggestions! Cheers! |
01-11-2017, 02:27 PM | #2 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
The RIGHT way also involves emptying the old oil that sits in the oil filter housing (use a syringe) and priming the system by pouring the first 1/2 litre of new oil into the oil filter housing, rather than the filler in the rocker cover.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Mosaud19983979.00 |
01-16-2017, 10:35 AM | #3 | |
18
Rep 16
However, that will go under a "Complete Engine Oil Extraction" category, in which case the oil is so used/burnt that it will not mix with the new changed oil. What I was demonstrating in my video goes under "Step-by-Step Oil Chnage, the right way for E90" which should be done generally between 6k-8k based on preference. In this case only draining the engine and replacing the oil would be significant; remainder oil in the filter housing will be blended with the new oil during the first 5min of the running engine. Cheers. |
01-29-2017, 11:30 PM | #4 |
24
Rep 48
Drives: 2008 E92 335I Coupe
just an FYI...that mobile 5w-30 is NOT the proper oil for that engine.
02-11-2017, 12:11 AM | #6 |
403
Rep 1,425
Do a transmission oil and filter change Diy step by step
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
02-15-2017, 09:11 AM | #7 |
39
Rep 250
What is the proper oil?
2009 Lexus GX470
03-02-2017, 07:34 PM | #8 |
24
Rep 48
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market:
Castrol Syntec European Formula SAE 0W-30 Mobil 1 SAE 0W-40 Pennzoil Platinum European Formula Ultra SAE 5W-30 Valvoline SynPower SAE 5W-30 i switched from the castrol 0w-40 that the PO had in there to german castrol 0w-30 on this oil change because i was eating that 0w-40 like crazy...two FULL quarts from when i bought the car till this recent oil change... and so far ZERO oil consumption and much cooler oil temps.this Castrol 0W-30 is being replaced by there new 5W-40 formula so when i can't get 0W-30 anymore i will switch to Amsoil 5W-40 European formula.... http://www.amsoil.com/shop/by-produc...?code=EFMQT-EA Last edited by SJM67; 03-02-2017 at 07:55 PM.. |
03-31-2024, 07:29 AM | #9 |
28
Rep 67
Cold Oil
In the video he mentions to do the oil change with the oil cold so you don't burn yourself. Completely wrong, warm/hot oil gets the contaminents out of the oil as it drains. I've been doing oil changes for over 50 years and always drain my oil when the engine is at operating temperature and have never burned my hands.
