F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.2" touchscreen for NBT EVO2 on f30
ARMA SPEED
      03-05-2019, 08:01 AM   #45
glachhman3
47
Drives: SO M2
Originally Posted by vilord View Post
There are 2 places to change the screen size and resolution.
If you search for RESOLUTION you should find both.
Here are the correct options for the 10.25 APIX2 touchscreen I have, which came from an X5:
CID_APIX_MODE = APIX2
CID_COM_MODE = MMI
CID_COLOR_DEPTH = 24bit
CID_RESOLUTION = 1440_540 (might also be CID_DISPLAY_RES)
CID_DISPLAY_SIZE = 10_25
DISPLAY_VARIANTE = breites_display
DISPLAY_SIZE_RESOLUTION = 10.25_1440x540
DIMMUNGSVARIANTE alte_dimmung
Ty! Gonna give this a go tonight
      03-05-2019, 09:39 AM   #46
AcExSpades
AcExSpades's Avatar
Peru
74
Drives: 11 MW E92 M3
2011 BMW M3  [0.00]
2006 Subaru WRX STi  [0.00]
Hi guys, any issues when upgrading to the 10.25 touchscreen (obviously aside from fitting the screen).
I'm mostly talking about everyday things. Using navigation, touch feedback, using reverse or top down view, etc...
I want to make sure that if I do this, there aren't any downsides.
Thanks
      03-05-2019, 11:04 AM   #47
yjypm
yjypm's Avatar
219
Drives: 2018 M3 ZCP
Thanks
Do it!
Instagram:catpupu_f80
      03-06-2019, 08:33 AM   #48
Dtwok335
Germany
16
Drives: M3F80-Frozenblack-metallic
Hey does anyone of you know, how I can retrofit my F80 2015 (ID4 I think?) to ID5 or ID6_light?
Ist ist just replace the unit an the display and coding? Or are there wires that need to be changed? I've read about something like that...
Coding is no problem. Just dunno what parts I really need to retrofit.
Thanks!
      03-07-2019, 12:13 PM   #49
glachhman3
47
Drives: SO M2
CID_COM_MODE = MMI
Perfect. I needed to change just that last line. Now I’m trying to figure out how to fit this display without cutting my dash.
      09-23-2019, 12:23 AM   #50
hlrzr
Love the X5, but R1 is life!
20
Drives: 2016 X5 50i M-Sport
Sorry to bring this thread back but I'm contemplating a hybrid solution and am hoping you guys can help.
I've got an F15 NBT non-touch screen 10.2 display. I got in on a joyeauto carplay unit which works flawlessly however having a non-touch screen means I have to mirror a lot from my phone.
I'm just wondering if I can do a straight swap of a newer F15 touchscreen (likely from the EVO) to this? I've tried finding pics of the connectors and they appear to be the same. I know the touch functions likely won't be recognized by the NBT HU but would the carplay unit recognize them? I've put this question towards the reseller and likely manufacturer in the future.
Before I go dropping some coin on a touch screen, I'm just trying to figure out if the non/touch are interchangable on the NBT head unit.
Cheers!
      09-24-2019, 12:27 AM   #51
yjypm
yjypm's Avatar
219
Drives: 2018 M3 ZCP
Cheers!
The voltages are different between nbt and nbt evo. You might want to use a non-touch display.
hlrzr19.50
      03-10-2020, 09:30 AM   #52
GOWRIN
GOWRIN's Avatar
113
Drives: BMW F36 435D XD
Originally Posted by FRANKLINDEE View Post
I've installed the G30 screen on my F30 and looks perfect you will just need to trim the holes where the brackets goes in order to slide on the right the screen in order to the 10,25 screen to fit properly and of couse you will need to fabricate with fibleglass the back pannel in order to match with the F30
i will do mine next week i will post some photos
Thinking of using a G30 screen for my F36 retrofit, did you get around to doing this, would be interested to see how it all looks?
Thanks
      03-10-2020, 11:09 AM   #53
psyki
E36fiend
286
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Thanks
It's been done but it does not fit without significant modification, is there a particular reason you want to use a G30 screen and not one that requires much less effort?
      03-10-2020, 11:50 AM   #54
GOWRIN
GOWRIN's Avatar
113
It looks a lot nicer than the F15 screen and is more readily available so was looking into whether it was possible. But if it needs a lot of modification then I might have to think about going with the F15 screen.
      03-10-2020, 11:56 AM   #55
psyki
E36fiend
286
2014 X5  [0.00]
I'll give you that it is angular with sharper edges and does look nice. When I did the 10.25 touchscreen retrofit I just removed the chrome trim and painted it black, looks much better.
GOWRIN112.50
      03-10-2020, 12:04 PM   #56
GOWRIN
GOWRIN's Avatar
113
I must admit that definitely does look nice, I might actually have a look into that and do the same. The silver surround just doesn't look nice.
      03-10-2020, 12:09 PM   #57
psyki
E36fiend
286
2014 X5  [0.00]
There's not a single chrome/silver bit of metal visible on my car (except the door pulls I guess) so it just looked way out of place. The backing of the screen comes off pretty easy and it's not hard to remove the silver trim after that, it just clips in.
Appreciate 2
yjypm219.00
GOWRIN112.50
      03-11-2020, 06:51 AM   #58
GOWRIN
GOWRIN's Avatar
113
Yes I am considering wrapping my interior, not sure what colour yet. Maybe carbon look.
Awesome thanks for the tip, will be giving it a go once I receive it. Will upload some pictures on I get a change to start my F36 build thread.
      01-12-2021, 03:28 PM   #59
Big_CG
Big_CG's Avatar
186
Drives: 2020 X5
I am trying to install part number 8715335 10.25 display from a 2019 X3 on my 2018 X3 that came with the base 6.5 display.
I plugged it in, coded the following with bimmercode:
CID_RES to 1440
CID_Display size to 10.25
display_variante to breites
However I am getting no signal. Any ideas?
      10-04-2021, 09:36 PM   #60
fe7565
fe7565's Avatar
557
Drives: 2012 BMW 328i N26
Cheers!
I know this is a while ago, but any success with getting a touch screen working?
      10-07-2021, 07:18 AM   #61
toxik
toxik's Avatar
2509
Drives: 2017 340i xDrive 6MT
Cheers!
yes a lot of people have done this, a whole thread about it here F15 10.2" Monitor installed to F30 car https://f30.bimmerpost.com/forums/sh....php?t=1168747
fe7565556.50
      10-07-2021, 03:34 PM   #62
fe7565
fe7565's Avatar
557
Thank you for the link. It's the touch-screen part that I am wondering about. The original F-15 screens did not have them. Also wondering the same as "hlrzr" if the Android MMI unit is able to interface with the OEM screen's touch functionality.
      04-30-2024, 08:15 AM   #63
SoundQ2
SoundQ2's Avatar
Drives: 17 Porsche 911, 18 BMW M4 Cab
update to 10.2 Touchscreen upgrade
I found the 14-18 X5/6 part number 6816387 fit (with modification to dash) and a cheaper alternative is part # 8715339 ('18 M550i).
I have NOT done this as I'm still researching. Wanted to know if anyone can verify this. I do know the part numbers are correct but not sure WHEN the X5 went touch screen.
The X5 (6816387) parts are about $300 and up while the M550i (8715339) are $100 or more LESS. (odd how I phrased that...sorry). Again I did not do this yet.
3 outcomes...
1) works perfectly (after coding and cutting dash)
2) I would get the larger 10.2 screen with no touch.
3) It doesn't work and I keep my 8.2 non-touch.
Thinking about the less expensive option (M550i) and selling my perfect 8.2 for what I paid for the 10.2...
I have a 18 M4 made in 6/17...I think around 10/17 they put touch screen in but didn't activate the touch. That's the main reason I bought Bimmercode only to find out mine wasn't a touch screen. But Bimmercode has come in handy with other mods!
f30post
