10-22-2018, 06:53 AM | #23 |
16
Rep 29
I've installed the G30 screen on my F30 and looks perfect you will just need to trim the holes where the brackets goes in order to slide on the right the screen in order to the 10,25 screen to fit properly and of couse you will need to fabricate with fibleglass the back pannel in order to match with the F30
i will do mine next week i will post some photos |
10-24-2018, 02:29 AM | #25 |
Rep 26
10-24-2018, 04:41 AM | #26 |
16
Rep 29
Hi
I've purchased form a very good seller @naviprof he will provide all necessary items to do the retrofit including coding I've paid 1200 GBP all in you will need to modify the dash (holes where the bracket with screw goes) , cut the original bracket and put new bracket to make it in straight position i will fabricate with fiber the back to match the f30 dash hope to post some picture soon let me know if you have other questions |
11-05-2018, 03:33 PM | #27 | |
53
Rep 182
12-24-2018, 02:45 PM | #28 | |
18
Rep 130
Drives: 2016 bmw 328i xdrive
12-25-2018, 04:37 PM | #29 | |
123
Rep 565
HU_ENTRYNAV2 > HMI > DISPLAY_SIZE_RESOLUTION = "8.8_1280x480" (the second one should be optional - the 1st one is important) See this thread for more info (you have HU_ENTRYNAV2, which is a newer version of HU_ENTRYNAV). Note that if you bought a touch screen and don't have navigation, it won't work. You have to get the non-touch version (part no. 65506822626). EDIT: Here is a link to a thread with pictures of an upgraded screen on HU_ENTRYNAV2. Last edited by MarkoSK; 12-25-2018 at 04:44 PM.. |
12-25-2018, 05:18 PM | #30 | |
18
Rep 130
12-25-2018, 06:44 PM | #31 | ||
1166
Rep 2,180
Coding should be: Quote:
There is a Touchscreen coding entry as well. |
12-25-2018, 07:25 PM | #32 | |
18
Rep 130
The screen i bought was from this listing by a member here. The link to the listing is here: https://f30.bimmerpost.com/forums/sh....php?t=1563906 Can someone please tell me if im doing something wrong here. I fdl coded those settings and the screen stays blank. the sticker on the back of the screen says F3X Touch |
12-26-2018, 10:46 AM | #33 | |
1166
Rep 2,180
Screen should display right away if a) it is from an NBT EVO2 and b) it is not defective.
No coding should be necessary if your NBT EVO2 HU was connected to its APIX2 screen from factory. All the coding, except perhaps "touchscreen" should be in place already. Does the screen shows "No Signal"? Quote:
12-26-2018, 11:48 AM | #34 | |
18
Rep 130
12-26-2018, 09:53 PM | #36 | ||
219
Rep 464
Instagram:catpupu_f80 |
12-27-2018, 06:56 AM | #37 |
123
Rep 565
12-27-2018, 07:40 AM | #38 | |
1166
Rep 2,180
Blank screen means two things: screen is damaged or voltage/coding is incorrect. A “NO SIGNAL” message display means that the voltage is correct but the coding isn’t. The touchscreen display obviously requires extra coding but it seems that either the voltage was changed or the “NO SIGNAL” message was eliminated. |
12-27-2018, 11:56 AM | #39 | ||
219
Rep 464
01-10-2019, 01:36 AM | #40 |
490
Rep 1,309
Just to correct a misconception here...
I have an evo / apix2 10.25 screen, which may act differently... However, when the NBT was set for the 8.8, my screen just showed black and appeared to be "broken" as others have mentioned. I actually got the screen cheap because the seller said it was broken / for parts. Once I changed the coding to 10.25, but at the wrong resolution, it then said NO SIGNAL. Once I changed the coding to the right resolution, it worked fine. So... it was definitely black even with the right voltage and a working screen. Now to figure out how to flash my evo... the istep on this thing is ancient... pre-id6 existing, and so my touchscreen doesn't do anything. |
Jhnblckwood130.00 drivef30111.00 |
03-05-2019, 12:16 AM | #41 | |
47
Rep 138
03-05-2019, 12:45 AM | #42 | ||
219
Rep 464
Sorry I don't remember the exact parameters but it was pretty easy.
03-05-2019, 07:31 AM | #43 |
47
Rep 138
Damn I tried that. I wonder if this screen is a dud. I have backlight but nothing else. Trying to fit the screen from a 18 x5 into my 19 M2c. Gonna give it another try.
03-05-2019, 07:49 AM | #44 |
490
Rep 1,309
There are 2 places to change the screen size and resolution.
If you search for RESOLUTION you should find both. Here are the correct options for the 10.25 APIX2 touchscreen I have, which came from an X5: CID_APIX_MODE = APIX2 CID_COM_MODE = MMI CID_COLOR_DEPTH = 24bit CID_RESOLUTION = 1440_540 (might also be CID_DISPLAY_RES) CID_DISPLAY_SIZE = 10_25 DISPLAY_VARIANTE = breites_display DISPLAY_SIZE_RESOLUTION = 10.25_1440x540 DIMMUNGSVARIANTE alte_dimmung Last edited by vilord; 03-05-2019 at 08:00 AM.. Reason: had the wrong resolution |
