01-21-2019, 07:13 PM | #1 |
70
Rep 117
Was curious what you guys thought. it seems the guys behind the xHP flasher have an android app called XDelete that will successfully disable Xdrive without impairing any other functions of the vehicle. Currently it only supports E series vehicles the few reviews I see of it show that it works pretty good. They claim the F series cars will be supported some time soon. Is $150 worth it to disable XDrive to you? I can see this being useful for users who have an XDrive vehicle but no AWD dynos near them and the people who want to do the occasional burnout. Even after disabling you still will have the extra weight and XDrive suspension obviously so I dont know how this will help in the driveability department.
Edit: I forgot to mention the creator says that you can switch back and forth when ever you feel like it. Similar to flashing a tune. |
01-21-2019, 07:31 PM | #2 |
98
Rep 227
Drives: 2000 BMW E39 M5
I'm definitely getting xDelete once it becomes available for the F3x. Will use it during warmer months, then revert to stock during the winter.
Early reports from E90 owners indicate slightly improved steering feel, reduced understeer, and of course no more torque steer.
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
01-21-2019, 08:33 PM | #3 |
Vault Dweller
705
Rep 577
Curious. So you are stuck with all the downsides (weight, drivetrain loss, higher price/maintenance) and none of the upsides of xDrive (added traction/grip)? Why not buy RWD!
10
longreach1.50 ihateredlight55.50 jmrCRX0.00 M Smurf156.50 Insane435480.50 Wills28684.50 ASalgar20.00 metallicpea714.00 Flipflap3512.00 |
01-21-2019, 08:34 PM | #4 |
5923
Rep 10,304
Did the author of the app explain the science behind disabling xDrive system, which is a permanent AWD system?
One can theoretically remove the front drive shaft but other xDrive components will continue operate as intended. |
Blubaron791434.50 |
01-21-2019, 08:34 PM | #5 |
204
Rep 499
I'd definitely consider this for the summer months -- would be fun to have a RWD car for part of the year. As long as I can switch it back and forth, as often as I'd like, and there's no other disadvantages, it sounds pretty cool.
01-21-2019, 08:37 PM | #6 |
Vault Dweller
705
Rep 577
My guess is that it is just not transferring extra power to the front wheels and keeping the 60-40 split all the time. Just a guess and kinda fake RWD if so, thus me wondering.
01-21-2019, 08:39 PM | #7 |
5923
Rep 10,304
I still think the creator of the app has a responsibility to disclose the science behind the software to make sure the changes are indeed safe.
01-21-2019, 08:39 PM | #8 | |
Vault Dweller
705
Rep 577
This seems like an improvement @6:48 ! Last edited by zambarossa; 01-21-2019 at 08:46 PM.. |
Blubaron791434.50 Poochie9107.50 |
01-22-2019, 06:00 AM | #9 | |
6659
Rep 15,858
As I see it, it is going to add premature wear to the transfer box, even extra oil changes in the box may not be enough to keep longevity. the other question; Does it impinge on DSC function in any way? To me, this is not an engineering solution at all, could well be asking for trouble. |
01-22-2019, 06:01 AM | #10 |
6659
Rep 15,858
01-22-2019, 06:42 AM | #11 |
No 55mph
1622
Rep 8,477
I bought AWD for a reason - if I wanted RWD only, I would have purchased that way...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
7
01-22-2019, 06:46 AM | #12 | ||
70
Rep 117
01-22-2019, 06:49 AM | #13 |
70
Rep 117
here is a link to their thread on E90 Post on page 2 they have a FAQ pdf link.
https://www.e90post.com/forums/showthread.php?t=1557299 Curious how it would affect MPG considering your not driving the front wheels yet have the extra weight. |
01-22-2019, 06:52 AM | #14 |
70
Rep 117
Creator says it's like flashing a tune to your car. you hook up your phone and you can switch as much as you'd like with no issues.
01-22-2019, 07:01 AM | #15 |
98
Rep 227
It's a small segment of the market, but US-spec F31s only come with xDrive. If RWD were an option then I'd have been all over it.
HeartbreakerF80157.00 |
01-22-2019, 07:18 AM | #17 | |
6659
Rep 15,858
One further point with the M5, transfer box oil changes are scheduled at every 5th oil service, ~50,000 miles intervals. |
01-22-2019, 07:29 AM | #18 | ||
6659
Rep 15,858
01-22-2019, 07:29 AM | #19 | ||
70
Rep 117
on a side note what is the oil change interval for our transfercases? |
01-22-2019, 07:33 AM | #20 | |||
70
Rep 117
01-22-2019, 07:35 AM | #21 | |
Cheapskate
4457
Rep 4,995
I think if someone with it posted an xdrive car doing a burnout or something to illustrate how much it really disables xdrive, it would clear things up. It does seem like it just pushes more power to the rear though. If it's like the high power GTRs you see do a rwd burnout and then an awd launch...that would be pretty crazy. |
