      09-22-2008, 08:05 AM   #23
AndyM
AndyM's Avatar
134
Drives:
Originally Posted by jkp1187 View Post
Great post!
How much should we expect to pay for the replacement bin? I don’t see any prices on the pages linked above.
Sorry for the delay, retail is $365.13.
      12-06-2008, 12:49 AM   #24
m7ammed
m7ammed's Avatar
Saudi Arabia
210
Drives: 2019 M2 Competition
Originally Posted by CAMike View Post
Andy, do you have a part number for the Euro arm rest? I am trying to see if I can get the center storage bin (on the dash where the iDrive would be if I had it) and the wallet holder but my dealer is closed until the 25th of this Month. If you have the part number, I'll see if I can get that too.
Thanks!
whats a wallet holder?
      08-05-2010, 11:05 AM   #25
larryzhou
Drives: 120i mt
thanks a lot,,,
      08-05-2010, 08:24 PM   #26
Six Pot
Six Pot's Avatar
417
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Hey Andy, can you get a better pic of the back of the bin. Is that an insert that can be removed to route wires into the bin?
      08-06-2010, 07:34 AM   #27
JimD
JimD's Avatar
368
Drives: 128i convertible
My early June 09 build 128i vert came with the larger bin. It holds a few CDs nicely.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      08-06-2010, 08:24 AM   #28
AndyM
AndyM's Avatar
134
Drives:
On the inside, back wall of the armrest? That is a business card holder.
      08-06-2010, 08:39 AM   #29
Six Pot
Six Pot's Avatar
417
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Ah, was wondering if I could re-route some cables into the armrest directly. Thanks
      09-07-2010, 03:12 PM   #30
Guynamedsean
32
Drives: 2012 Carbon Black 650i M Sport
That's not a wallet holder or business card holder. It's part of the iPod kit. You put your iPhone or iPod in there,then plug in. Allows you to control iPod from headunit. If you have this kit you can also just save music to USB drive and plug in.
You guys were joking right? Thought this was common knowledge round here.
      09-07-2010, 03:16 PM   #31
AndyM
AndyM's Avatar
134
Drives:
Originally Posted by Guynamedsean View Post
That’s not a wallet holder or business card holder. It’s part of the iPod kit. You put your iPhone or iPod in there,then plug in. Allows you to control iPod from headunit. If you have this kit you can also just save music to USB drive and plug in.
The Ipod holder is on the underside of the armrest. We were talking about the business card holder on the inside of the armrest along the back wall of the storage area.
      12-15-2010, 08:31 AM   #32
gnpower
18
Drives: BMW ///M Sport 135i
I do like the larger armrest compartment. I feel the current storage is useless for my needs. All I can keep in there is a pen. Will replacing your armrest eliminate the armrest squeeks?
///M 135i
      12-15-2010, 09:25 AM   #33
AndyM
AndyM's Avatar
134
Drives:
You need to add felt to eliminate the squeaks. You can find info on it somewhere on here.
      03-12-2011, 01:45 PM   #34
New21er
35
Drives: 2011 135i
Just saw this and I want one. Can anybody provide a part number ??
      03-12-2011, 03:07 PM   #35
AndyM
AndyM's Avatar
134
Drives:
Black is: 51 16 9 110 501
If you need another color, you can find it at realoem.com
      06-26-2012, 06:34 PM   #36
pikuko
Drives: 128I
AndyM,
I really like the modification with the short armrest, I went to the leatherz website but i couldn't find it, any way you can point me to the right direction how to get the same one you have?
Thank you.
      01-28-2013, 10:43 AM   #37
Milton
Drives: 135i
Sorry, but its necessary to remove the 10mm nut near the usb connector?. Im affraid if I broke the plastic cover.
Thank you.
Removing the center armrest without removing the entire center console is not difficult. I did not like the useless bins for storage in the stock armrest so I got European version with the bigger storage space.
Tools required
10mm Socket and wrench
T-20 Torx Bit
Removing the Stock Armrest.
Raise the armrest and next to the USB/iPod interface is a cover. Remove it and you will expose a 10mm nut:
Remove the 10mm nut (make sure you do not drop the nut into the center console). Set the cover and the nut off to the side.
On the back of the center console is a trim panel. To remove the trim panel, pull straight back. I was able to do it by hand (no tools) by gripping it towards the bottom. You may need to use an interior trim tool to remove the panel.
With the trim panel removed, you expose 4 fasteners: 2 T-20 Torx screws at the top of the armrest and 2 10mm nuts at the base. Begin by undocking the cell phone connector from the armrest and then remove the 4 fasteners.
To remove the armrest, you will need to lift it up until it clears the 2 captive bolts at the base. The center console has enough play to allow you to clear the bolts. Once you have the armrest over the two bolts, slide the armrest back.
If you are simply removing the armrest, you are done. To install the armrest, it is the reverse of removal.
If you are installing a new armrest, there is more to it if you have the iPod sleeve. The iPod sleeve is held in place by 3 self tapping T-20 screws. To access the screws, open the sleeve and lift the velvet-y backing.
Remove the three screws:
A new armrest will not come with the sleeve. The sleeve is expensive, so you will want to re-use it. To transfer it to a new armrest, use a piece of paper with the paper aligned with the longer (left in the picture above) and the bottom edges. Use a pencil to mark the holes on the paper. Align the paper on the bottom of the new armrest and transfer the holes to the new armrest. The T-20 screws are self tapping, so all you need to do is line up the iPod sleeve and screw it down.
Here is a comparison of the larger storage armrest and the worthless one. I lined the bottom of the new one with some toolbox drawer liner to keep things from sliding around a bit.
note: new armrests come with a new lid, I have one off for another project.
      02-20-2013, 07:10 AM   #38
dorkdog
Big Mouth No Filter
dorkdog's Avatar
49
Drives: 128i Montego Blue 6MT Sport
almost 5 years later... an answer!
Originally Posted by Piggy View Post
Anyone know if there is an armrest delete option, or some type of block off plate to make the removal of it look finished. Thanks Jeff
You'll have to order BMW part number 51169110474 (they come in different colors); it's about $15. It's a plate you put over the space where the armrest was, after you remove it.
We do not inherit the Earth from our parents; we borrow it from our children
      02-27-2013, 03:01 AM   #39
Jadel
Drives: 135i
Oh, now thats a neat alternative, would like the OP bigger bin one but its a bit too exxy.
The default one is so bad. The whole car is pretty awful storage wise tbh.
The thing next to the light switch stuff falls out of, the ash tray .. wow an ash tray in 2012 thats a good idea. The whole arm rest including the scoop underneath and the horrible plastic thing in between the rear seats.
I guess the glove compartment is ok .. apart from its rattles.
      03-02-2013, 06:08 PM   #40
Gray_Panther
Gray_Panther's Avatar
1555
Drives: 128i
Just dropped in to say your seats look magnificent. As if no soul has ever been in it.
2012 BMW 128i 6MT Deep Sea Blue Metallic
      02-20-2016, 03:53 PM   #41
nachob
2314
Drives: 2004 330i ZHP, 2022 Cayman T
yes, there is a cap if you remove the armrest for about $15. I am tempted as I am tired of squeakgng a creaking. Part number 51169110474
      12-04-2016, 03:28 PM   #42
badge502
badge502's Avatar
Drives: 2012 BMW 128i
2005 BMW R1200ST  [0.00]
2012 BMW 128i  [0.00]
Is it possible to remove the armrest from the bracket? Looks like removing 5, 17, and 6 (on both sides) would allow the armrest to seperate from the bracket.
Looks like this little cap needs to come off, but I don't want to break it... Has anyone ever done this successfully?
      05-02-2023, 04:30 PM   #43
Luxury
Luxury's Avatar
86
Drives: A4 1.8TQM, 135is DCT
Yes. Three things. You'll want to use a small pick tool. Second look at the images below.
There are four retainers moulded into the inside of the cap. Think about which ones are easily accessible to the tool so you don't cause damage. If you pull the cap outward at each one of those spots the cap will be free. I think it gets easier after each release. I will make a full dissasembly tutorial soon.
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPSS - BMW 313M's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | #341/586
      09-17-2023, 02:03 PM   #44
Jason135i
15
Drives: 2013 BMW 135i Convertible
2013 BMW 135i  [0.00]
I upgraded my armrest and installed a MagSafe stick on mount to hold my phone in place. The old one with the built in iPhone 4 cradle always annoyed me.
1addicts
