03-23-2020, 07:59 PM | #1 |
Remove Before Flight
6891
Rep 1,615
How to remove permanent marker?
Hypothetically, let's say someone took a permanent marker, and wrote all over (and I mean EVERYWHERE) in the interior of your M2-- dash, leather, trim, alcantara, etc.
How would you get it off without ruining the finish? TIA. |
03-24-2020, 07:38 AM | #2 |
479
Rep 683
Oh boy. Try nail polish remover in a spot. It's basically acetone with some oils and conditioners mixed in.
Then give everything a good cleaning with your fav interior cleaner. Then destroy all permanent markers within a 1/2 mile radius. I hate to ask, but do you have a pic? I know that's morbid but have never seen anything like what you describe.
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT 2013 Porsche Boxster S |
flybigjet6891.00 |
03-24-2020, 08:18 AM | #3 |
6891
Rep 1,615
The M2 part is hypothetical.
The actual is a lot worse. My brother-in-law passed away last weekend from terminal kidney cancer. He was a "for real" diagnosed paranoid-schizophrenic (and I guarandamntee you that you can't comprehend how this destroyed his family-- anything you can imagine? A thousand times worse.) Anyhow, he was living in his parents driveway in an RV that they had bought him-- and he pretty much went crazy with permanent highlighter and wrote on every available surface-- pretty much destroying the RV. My father-in-law asked me if he knew any way to get some of it off-- we're NOT talking a little area you could use nail polish remover-- we're talking Every. Surface. In. The. RV. Cloth, plastic, formica, paneling, etc. I have NO idea what to use. I was considering isopropyl alcohol. I'd thought of acetone, but that'll take the finish right off. So, no pictures-- the entire thing is pretty upsetting, actually. R. |
Killed by Death12797.00 |
03-24-2020, 09:24 AM | #4 | |
683
Rep 857
03-24-2020, 09:43 AM | #5 |
479
Rep 683
I think the actetone would work on the hard surfaces but test, test test.
You plan on doing this yourself or hiring a professional service? There's a ton more surface area in an RV than an M2. Here's an idea. I'm sure a few of those permanent highlighters are still around (even if they're used up). Get in touch with the manufacturer and let them know about your situation. I'm sure they could recommend the mildest product for various surfaces that would still do the job. They might even have some stuff in house that they can share with you. It's worth asking. Tough family situation. It sounds like your inlaws did the best they could.
2017 LBB ///M2 DCT 2013 Porsche Boxster S Last edited by McGary911; 03-24-2020 at 09:56 AM.. |
flybigjet6891.00 |
03-26-2020, 07:07 PM | #9 |
10933
Rep 4,551
Drives: 2015 328d xDrive
Dark-Yoda25.50 NYC Bimmer259.50 |
07-13-2020, 01:16 PM | #11 |
30
Rep 17
believe it or not, use the sharpie and go over the sharpie area you want to remove, and wipe it away quickly. This is an old trade secret I learned years ago. Try it first in an inconspicuous area. Not sure how its going to work on a porous material. The theory is it softens the ink and you can easily wipe it way.
02-10-2023, 01:20 PM | #12 |
17
Rep 48
A dry erase marker will remove a permanent sharpie marker on plastic. You need to wipe it before it fully dries and it may take more than one go at it.
Not sure if it would work on a porous surface. |
02-10-2023, 06:50 PM | #13 |
7364
Rep 7,318
Magic eraser is very abrasive, do not use it except as a last resort.
The best chemical for removing Sharpie ink is methanol. It wipes right off of hard surfaces with it. In our lab we use methanol to rinse the writing off of beakers. It just runs right off without being touched. However, I am not sure what surfaces are or are not safe to use methanol on. It works even better than acetone and is probably less harmful to more surfaces, but it's still a strong alcohol. |
