M2 Technical Topics > Suspension | Brakes | Chassis > Brake judder
      06-01-2016, 08:05 PM   #1
Pyrat 2
Pyrat 2's Avatar
1419
Drives: Rapidly from A to B
Brake judder
So I went to the track a week ago and had a great day. I drove the car hard and used the brakes hard. No fade the entire time. For sure a more aggressive pad would have been nice but the stock pads held up fine given that I was running the stock MPSS and that this was my first time out. After every session I did a full cool down lap with no brakes and then when off the track I did further cool down before parking to make sure that brakes were nice and cool. Despite all of my precautions I have uneven pad deposit and brake judder on both the front rotors.
So rather than ask the question on how to solve this short of new rotors and pads what I really want to know is how do I prevent this in the future? In this case I had about 1500 miles on the pads and took the first fews laps relatively lightly. Did extensive cool downs too.
Advice please.
      06-02-2016, 03:26 AM   #2
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
There is not a lot you can do about this... as you mention it is very likely pad deposits on the rotors and something that is simply common when street pads are used at the track. Give it a week or two of normal driving and it will go away. Outside of the precautions you already noted, I haven't found a way to avoid this (outside of being easier on the brakes at the track) with OEM pads.
I have found that track pads are far less prone to this issue. Also, they are so abrasive when cold that they naturally clean the rotors themselves on the drive home. No new rotors needed... just pads swapped before track days.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      06-02-2016, 05:35 AM   #3
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
Agree track pads. You may be able to find a compromise pad that is able to handle the track work you do (since the factory pads seemed to provide the stopping power ok) and use for DD as well. Other wise if you go aggressive track pads you will definitely have to swap out again for street.
If street driving a few days doesn't clear the problem you could take some fine sand paper and lightly sand off the deposits on the rotor.
      06-02-2016, 06:15 PM   #4
Fullofdays
41
Drives: m
I've used abrasive pads with a drill mount on the rotors with past track/street cars. Other option is just to drive it per usual on the street for a week or so.
      06-02-2016, 06:59 PM   #5
LBBDrew
336
Drives: 2017 LBB M2
I had pretty bad deposits on my rotors from a track day 4 months ago on my S4. I swear I still feel a slightly mushy pedal when I brake hard...
      06-03-2016, 12:51 PM   #6
jritt@essex
BimmerPost Supporting Vendor
jritt@essex's Avatar
1029
Drives: e90 335i, NSX, 997.2, 987.1
As others have said, street pads are for the street, and track pads are for the track. When you exceed a pad's Max Operating Temperature (MOT), they tend to break down and smear on the discs (or come off in chunks). Once that happens, it can be tough to cure. Street pads have a relatively low MOT. Track pads have a much higher MOT, and tend to adhere to the disc in a uniform manner up to far higher temps.
We have some great track/race pads for the M2...Ferodo DS1.11. You can see the details on our site.
Friends don't let friends drive street pads on the track...wish I had a better answer for you. Sorry brother!
      05-21-2017, 04:47 PM   #7
rich8566
rich8566's Avatar
609
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Advice please.
Same issue here. How was your problem resolved?
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      05-21-2017, 05:00 PM   #8
Pyrat 2
Pyrat 2's Avatar
1419
4 new rotors covered under warranty. Track pads after that and I haven't had the issue since.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      05-21-2017, 05:03 PM   #9
rich8566
rich8566's Avatar
609
Drives: M2 + Z-4
Which track pads? On OEM rotors? Do you switch back and forth between track events and DD? What if any break in procedure do you use when switching pads? And the big question - are you judder free?
      05-21-2017, 05:17 PM   #10
Pyrat 2
Pyrat 2's Avatar
1419
Originally Posted by rich8566 View Post
Which track pads?
Carbotech XP10 in front and XP8 in the rear.
On OEM rotors?
Yes.
Yes.
None other then original bedding procedure the first time. I've heard that this is not recommended. But I have had no issues and just ran at the track yesterday with no issue.
Yes.
rich8566608.50
      05-22-2017, 08:00 PM   #11
rich8566
rich8566's Avatar
609
Drives: M2 + Z-4
Which track pads?
On OEM rotors?
Yes.
Yes.
Yes.
Many thanks.
      05-24-2017, 04:42 PM   #12
M2 Belgium
27
Drives: BMW M2
Did my second trackday today with the OEM pads. After the first time I had the same problem with the pad deposits. Now the problem has disappeared. Consistent feel and no judder anymore, despite heavy breaking (Zolder). Did about 6 sessions of 6 laps at 80%. Michelins held up fine as well. In the future track pads and brake fluid will be a necessity though...
      05-24-2017, 09:48 PM   #13
rich8566
rich8566's Avatar
609
Drives: M2 + Z-4
I just ordered a set of Pagid RS29s
      05-27-2017, 08:08 AM   #14
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
Bmw doesnt warranty for track use does it? So did they replace under warranty assuming these pad deposits were acquired under normal road usage?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
      05-27-2017, 08:35 AM   #15
Pyrat 2
Pyrat 2's Avatar
1419
Correct. They wouldn't normally cover. I know my local sa and dealer very well so they managed to get it approved by BMW which they told me is required for all M rotor replacements. They know I'm at the track as some of them have been out there with me in the past. Anyhow they told me there was no way they would be able get another set approved. I bought track pads and all has been well since.
      05-31-2017, 04:07 PM   #16
CosmosMpower
CosmosMpower's Avatar
2052
Drives: F87c, GT3, MK7 GTI
Don't run stock pads if you don't want deposits.
      06-02-2017, 12:28 PM   #17
Rock Sweden
Rock Sweden's Avatar
270
Drives: 2016 M2
I have not tracked my car or really leaned on the brakes very hard and I have what I think is judder. When the rotors get hot the brakes make a howling sound/ sensation. It happens when stopping from highway speeds.
      06-02-2017, 06:39 PM   #18
LBBDrew
336
Drives: 2017 LBB M2
Anyone experienced issues with deposits running a hybrid pad? Looking to snag a set of Ferodo DS2500s, but not keen on rotor deposits.
      06-04-2017, 01:20 PM   #19
HP Autosport
3885
Drives: F80 M3
As long as you don't exceed the max. operating temp of the pads you will be fine. You will need to manage your brake well to keep them from getting too hot. If you want to keep the pads on, these are your best choice. Otherwise a full track pad like the DS1.11, RS29 or PFC08 will be better suited for the application.
      06-04-2017, 02:46 PM   #20
J.M
J.M's Avatar
Netherlands
264
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
Also got 4 new rotors and brake pads last Friday, replaced under warranty.
Check out my M2 YouTube channel: The HyperCar Collective
m2
