12-05-2018, 05:40 PM | #23 | ||
6456
Rep 8,520
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
12-05-2018, 06:04 PM | #24 |
197
Rep 368
I will say I would be cautious with that procedure. When I changed mine I put a new pan and filter on, then topped it off which only took about 2 quarts before it dribbled out. Following the instructions on ISTA with regards to the trans temp and shifting the gearbox, the trans sucked in about another 3 quarts. Not sure I'd want to drive the vehicle without that fluid in there.
12-05-2018, 06:38 PM | #25 | |
6456
Rep 8,520
The transmission is run through all gears when the vehicle is off the ground so as to ensure that it can be fully filled. The car is then driven on the road. The transmission fluid is then drained and refilled a second time. Same procedure : run the AT through the gears when the car is off the ground, drive the car in the road following a specific programme, and run AT adaptations. The point I was making is that the fluid is drained and refilled twice so as to fully flush the torque converter. Some people baulk at the cost of a fluid change by BMW until they realise that the process is rather more involved than a 'simple drain amd fill'.
12-05-2018, 07:31 PM | #26 | |
2474
Rep 5,460
Drives: F30
No mention of double drain and fill with a road test in between. |
12-05-2018, 10:14 PM | #28 |
197
Rep 368
I used about 5.5 quarts from changing the pan and refilling following the procedure. I plan to repeat every 60-80k or so I dont see the need to get that last quart or two out. It won't hurt anything if you feel the need, but it seems unnecessary IMHO, and certainly will cost a bit more. It's already $300 on a diy scale for a simple drain and fill. The mech unit doesnt have to come out just for a fluid change though so theres def a dirty quart or two left behind, but 80% fresh fluid works for me. Dont forget, its lifetime fluid anyways, roll it to 300k lol
12-19-2018, 07:48 AM | #29 |
50
Rep 308
What "Sleeves"? I saw the ZF transmission service kits with bolts, drain plug, fluid and pan. but no mention of a "sleeve".
2017 F31 328d xDrive
M Sport M Performance |
12-19-2018, 08:51 AM | #30 |
197
Rep 368
The older 6 speed BMW's have a sleeve on top of the mechatronics unit as well as another sleeve that the wires go through from inside to outside the transmission. They commonly crack on those models, so are routine maintenance. I don't believe the 8hp45 has those components, I have not seen them available, although I also did not drop the mechatronic unit to confirm.
Hypermile50.00 |
12-19-2018, 12:57 PM | #32 | |
2474
Rep 5,460
Drives: F30
Approximate out of pocket cost? Approximate time frame to complete? Mileage on vehicle when completed? Any side notes, hurdles or warnings to mention? Appreciate the info. A lot of us out here debating whether or not to this and whether or not to DIY. |
12-19-2018, 03:13 PM | #33 | |
126
Rep 424
It wasn't difficult but a little time consuming. I utilized a foxwell scanner for transmission temperature. It took FOREVER for it to come down to temp low enough for me to be comfortable to begin the process. While I waited I did an oil change, rear diff fluid, fuel filter, air filter and a brake fluid flush. After draining the pan I got 4.25 quarts out of the transmission. I was able to put about 2.8 back in with the car off. Started it and followed ZF's instructions (rev to 2k for 30 seconds in park to fill torque converter) then hold each gear for 10 seconds. At this point the transmission was slightly above ZF's recommendation for temperature but I continued with the fill process. With the engine running and car in park I was able to add about 1.7 more quarts into the transmission. (Give or take some as it ran out of the transmission a few times during the fill process.) Ultimately, I added just a little more than I took out which made me feel good about the whole process. I removed this bracket to give me more space to remove the fill plug and to give room to run the hose for the fluid transfer pump. I took a sample of the old fluid that I will send out to Blackstone in the next few days. I know it says lifetime fluid but I am curious to see what Blackstone says. The filter looks pretty full and was doing its job for sure. My 2014 328d had 49,960 miles on it and you can see in the photos the filter and what the magnets caught! The new ZF fluid is a very clear green. I put some of the old fluid on a paper towel so you guys could see. |
12-20-2018, 05:44 AM | #34 |
50
Rep 308
^ Thanks man! definitely giving me more confidence to DIY. Is it safe to go with ZF pan and fluids. The price difference between ZF and BMW parts are huge. I don't want this to be one of those "you get what you pay for" moments.
12-20-2018, 08:45 AM | #35 |
197
Rep 368
ZF is the manufacturer so I dont think you can go wrong. Just picked up the supplies to do mine a second time at around 120k, first was at ~60k when the first xfer case went.
Liqui-moly fluid is supposed to be acceptable too and is a little cheaper, but I stuck with the ZF8 fluid / ZF pan and filter. The kit is about $250 for ZF and $150 for Liqui moly |
12-20-2018, 08:57 AM | #36 |
180
Rep 466
Great posting n00bkiller944 sorry been out of the loop. I ended up doing it myself, as he mentioned it wasn't difficult just takes a few hours. I didn't have access to a lift so i bough some 4x4 wood and 2x10 and made some blocks so i can lift my car onto. Put jack stands for extra bracing at the jack points and kept my jack there for extra extra support lol.
Removed the under shields. Removed bracket (he showed) drained and removed pan cleaned up and installed new pan filled and followed ISTA I also changed front and rear differential fluids while i had it lifted. Oh and oil, cabin filters, air filter. I drove a few days and lifted it back up to make sure it was topped again. which i learned wasn't needed. In total. wood and screws- $18 differential and new plus- 38 transmission fluid kit- 165 Total 221 oil- 69 cabin filter- 27 air filter- 46 coolant- 8 i ordered my stuff through FCP Euro. Great company fast and easy. Also takes returns so I get credit back for next round. |
n00bkiller944125.50 BMW BRAD212.50 |
12-20-2018, 10:07 AM | #37 | |
2474
Rep 5,460
Drives: F30
Id like to make a pair to compliment my jack stands. |
12-20-2018, 10:09 AM | #38 | |
50
Rep 308
12-20-2018, 10:21 AM | #39 | |
2474
Rep 5,460
Drives: F30
How many litres did you legit need? Ive heard a lot of variance on this. |
12-20-2018, 12:13 PM | #41 | |
126
Rep 424
Exact same for me. Except I am RWD so just did the rear diff and also did a fuel filter while I was under there. Did you drain the coolant and do a refill? I bought coolant to do so but found out unfortunately these cars don't have a petcock or any place to drain coolant from except the lower hose which is all but low in the engine bay. I struggled to get the plastic hose to disconnect so I gave up and figured I would do it some other time. Would love some insight if you did this. |
12-28-2018, 08:19 AM | #42 | ||
180
Rep 466
2x10 2x4 4x4 Put small strip to brace tire roll Made the 2x10 18 inches long so my jack can fit under it to lift. Jacked 1 side put brace under. Repeated for all 4 sides. My jack lifted one side high enough for me to put front and rear braces under. Put jack under stands and jacked it will I can put next piece( if needed) used jack stands and jack at extra security. This is where i got the idea. I just made my own, i couldn't justify 285 (plus ship) for a pair. Just to do maintenance once in a blue moon. I had the 4x4 already and 2x2 so i just went and bough a 2x10 8ft. cut it up 18 inches and got 4 pieces. I honestly didn't need the 2nd set of 4x4 blocks. If your going higher id just use another 2x2 under it. Home depot with out 2nd 4x4 blocks 2x10 8ft: 6 bucks 4x4 6ft: 7 bucks 2x2 8ft: 3 bucks Total: 16 bucks I use the remaining 2x10 to cut strips for the wheel strips If you want another 4x4 under thats another 6 ft (cut 18 inches) and 2x2 is 8ft. Get the measurements based on your jack. My jack is 10 inches wide so i gave myself some wiggle room (1inch). Put the 4x4 blocks on the outside of it and got 18 inches total. You jack could be narrower or wider. 4x4 is really around 3.5 inches so [3.5]-11 inches- [3.5] =18 inches []=4x4 wood Last edited by jdr78569; 12-28-2018 at 08:43 AM.. |
sspade2474.00 |
12-28-2018, 08:29 AM | #43 | |
180
Rep 466
I changed my coolant on a mere mess up. While changing my NOX sensor on the exhaust i managed to snap a plastic nipple piece that i couldn't figure where it went too. Turns out it was to my DEF fluid. was leaking all over, so i ordered it at BMW and crawled under to swap it. WELL... turns out that same piece had a coolant line attached to it. So when i disconnected it spewed all the HOT coolant all over my back. Swapped out the piece and had to fill the coolant lol. It was on my todo list and i was going to do it by pulling the bottom hose (believe its the only way. I can send pics of my book if you'd like) |
12-28-2018, 08:43 AM | #44 |
197
Rep 368
Interesting, so you put the 2x10 spread across two 4x4's under each tire and it holds 1/4 of the weight of the car with no issues?
I usually lift the front right point with jack 1, and then slip jack 2 under the front center jacking point (my car is low) and raise it. Then slip jack stands under both front points. Set it down on stands (leave the front jack as well). Then go to the rear and lift from the differential with a block of wood, then install both rear stands. The front is a breeze, I really hate lifting the rear that way though. I always leave front / rear jacks in place Ha! My coolant change came when I was messing with the cooler for the DEF line as well. Managed to slice it and it drained the whole tank onto the floor. I wasn't going to roll around in it to try and stop the leak! |
