2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Ceramic Removal or whatever it is
      09-15-2023, 06:42 AM   #1
Hapbob
Hapbob's Avatar
230
Drives: M240 2018
Used white car
When looking at angle with sun just there you can see streaks that looks like a coating was put on uneven or to sparsely/thin in a wipe formation. I would like to remove it all and just wax it. Nothing I have tried so far touches it. Any Ideas what a plan would be for a very in-experience car finish guy.
Hap
      09-15-2023, 02:09 PM   #2
Kernel Kurtz
Kernel Kurtz's Avatar
347
Drives: 2020 M240i xDrive
I'd try a clay bar first. It is hard to mess up anything with that.
If that does not work you will probably need to use an abrasive compound and a power tool, and that will depend on your skill/comfort level.
      04-09-2024, 06:23 AM   #3
Hapbob
Hapbob's Avatar
230
Drives: M240 2018
Clay
I tried the clay bar and still have the streaks. I am guessing is some sort of Ceramic coating that wasn't put on great or its been there a long time. Its a 2018 car. I am going to take to a detailer to get estimate to strip it down to paint and I just want to wax it.
Nothing I tried touches the problem.
Hap
      04-09-2024, 07:10 PM   #4
John in VA
998
Drives: 2015 228i M Sport
Most professional specialists agree that using an orbital polisher with a polishing compound is the best way to remove a ceramic coating. Because polishing may essentially "cut" through the resistive coating until the clear coat is reached, it is by far the simplest method. However, this requires knowledge of polishing techniques and the ability to know when one has successfully cut through the ceramic coating, but has not penetrated too deeply into the underlying transparent layer.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      04-14-2024, 10:38 PM   #5
fiveightandten
fiveightandten's Avatar
111
Drives: F22 M235, E36 M3, E30 325, E90
Hap
There are products specifically designed to strip products off the paint; both car wash concentrates and spray on/wipe off products. Of course, a ceramic coating is designed to hold up against this, but I'd start by chemically attacking it with a car wash designed to strip. Then wipe the car down with a 50/50 mix of iso-propyl alcohol and water. This will minimize the mechanical work you need to do.
After that, you'll need to attack it mechanically, as you've tried. But be aware that you're removing a solid. So what happens is it will load up onto the polishing pad that you're using. Then you're just grinding it into the paint, which can introduce more imperfections. The key here is controlling the contamination on the pad to avoid that. Use some compressed air to blow the dust off the pad often.
What kind of polisher, pad, and product have you been using to try and remove this?
      04-15-2024, 04:33 AM   #6
Hapbob
Hapbob's Avatar
230
Drives: M240 2018
Thanks for response
I haven't tried mechanical removal. Just Claybar and various cleaners. I don't have the equipment or knowledge/skill for that I am afraid. I have talked to a local detail guy who seems to know what he is doing and will take it all off for $350. Still deciding if thats what I want to do.
Hap
      05-01-2024, 11:35 PM   #7
fiveightandten
111
Hap
Yeah, clay bar won’t touch it. CarPro Eraser would be a good chemical to try.
How prevalent are the streaks on the car? If it’s just in localized spots, you could likely remove it by hand with a polishing compound. Any light cut off the shelf polish on a microfiber will do. I’d try that. There’s little risk in this.
For the next step up, there are cheap DA polishers available at Harbor Freight and Amazon. DAs have fairly low risk and you’d have to work hard to do damage. You’d want to stay away from an orbital polisher, as you can easily do damage with one if you’re inexperienced.
If the local guy is good, that may be worth the money. Just be sure to come to an understanding with him that you want to remove the streaks and perform any necessary correction, nothing more. Make sure he’s not one of these detailers that’s going to burn through a bunch of your clear coat trying to make the paint flawless (unless that’s what you want).
      05-10-2024, 06:31 AM   #8
Hapbob
Hapbob's Avatar
230
Drives: M240 2018
OK
I will try your suggestions...Thanks
2addicts
