BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > New water pump not turning on
      04-19-2024, 07:24 AM   #1
e92Kim
e92Kim's Avatar
Drives: 2013 BMW 335i XDrive n55
So i have a 2013 e92 335i xdrive with n55, i recently replaced the water pump and thermostat and that stopped the leaking/overheating but there still was no heat, id have to be driving the car for about 30 minutes to an hour for the heat to kick in and that was only when i was stopped. I’ve tried bleeding the system multiple times and nothings change. Then about two weeks later i started leaking coolant again, i decided to drive it home and all was good till i was pulling into my driveway when the car started to over heat. Then every time id turn the car on the radiator fan would turn on full blast and then minutes later it would overheat and leak coolant. Today i started it up and let it run for about 30 minutes till it was fully warmed, the car never overheated and the radiator fan never turned on but i don’t believe the water pump was running at all, and i still had no heat. I’ve tried doing the bleed procedure after i got it home but the water pump doesn’t make a sound and the bleeding procedure never starts. (yes i’m doing it right i’ve had to do it on multiple bmws even this one and they all had the same steps) i’ve tried looking for fuses in the glovebox and in the engine bay and all seem good. I’m new to the whole mechanic scene and i’m just stumped on this problem and would really appreciate some help Diagnosing this problem and i don’t necessarily want to just buy another water pump and thermostat and wasn’t 6hrs of my time doing it again for it to be something stupid. PS when the car was overheating and leaking the codes were(3446, 348A, 387C, 38A4, 293E, 2C42) and when i had the car running and it wasn’t overheating the only codes i got were (3446, 387C, 38A4,)
      05-08-2024, 03:13 PM   #2
Greazywxrld
Greazywxrld's Avatar
Drives: 2007 E90 328i
BMW 328i  [0.00]
I’ve been having the same problem. New water pump and thermo, bleeding procedure just refuses to start for whatever reason. Checked fuses, battery, nothing. So I’m ruling it out to maybe an old code that needs cleared. The paper that came with my water pump says to keep an eye out for “002E83 DME”
Or “002E84 DME” I have not a clue in the world what this means and I’m also new to this stuff but I would probably call your local shop that specializes in Euro Vehicles for a diagnostic and explain your situation. Absolute worst case scenario you replace everything (yay!)
