Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Front suspension noob (pics of your suspension setup)
      09-08-2018, 03:42 PM   #1
markie864
Drives: 08 335i
Hello all I'm new to the bmw scene and i was looking into lowering my e92. Ive noticed in bumpy roads it sounds as if my struts are shot but on smooth road they're fine. I was looking to replace them but not sure what options i have combined with lowering springs. I'm not looking to slam it but maybe lower tastefully on the stock wheels so maybe .5 inch to a inch at most. If you guys can post some pics of your setups it would be greatly appreciated also how can i tell if mine is a sport? I saw that matters in the strut selection. Thanks in advance
      09-08-2018, 07:56 PM   #2
mweisdorfer
mweisdorfer's Avatar
1909
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I don't know of any lowering kits that will drop the car only a 1/2 inch. Most start at an inch and go from there. If you can wait until November, the Bilstein B12 kit is a great set up. I would look into the Koni Performance Suspension Cup Kit. Another kit to would be the BMW Performance Suspension.
https://www.ecstuning.com/b-assemble...yABEgLbVPD_BwE
https://www.ecstuning.com/b-genuine-.../33500444832g/
Appreciate 2
feuer4277.00
      09-09-2018, 12:34 AM   #3
whyzee125
1704
Drives: Dinan stage 2 335i
Even bad struts will feel fine on good roads unless they're completely blown The most mild lowering springs would be the Dinan springs, BMW performance springs, and Eibach pro kit. These can be paired with BMW performance shocks, Koni Yellows, Koni Orange, or Bilstein sport. You can run them with OE equivalent dampers too but it's not recommended as they'll be wearing out much quicker.
Appreciate 2
feuer4277.00
      09-09-2018, 09:10 AM   #4
Biginboca
Biginboca's Avatar
3768
Drives: 2009 E92 328i 6MT
Bmw performance suspension is a mild drop (~1/2”) and gives a nice ride.
feuer4277.00
      09-09-2018, 12:21 PM   #5
avocet
252
Drives: 2007 328i 2011 X5d
What sort of ride are you looking for? I have a sport spring set up and just ordered a set of swift spec r's. Apparently they are some of the stiffer springs you can get with a published 1"/.8" f/r drop. I am going to use Dinan camber plates up front to get back 5-8 mm of height and 10mm e30 rear spring pads to get back some height back there.
I am attempting to get the same height as stock sport with the much stiffer spring rate(am currently running bilsteins).
      09-10-2018, 07:19 PM   #6
bluewater328
627
Drives: 2011 bluewater 328i LCI sedan
This.
      09-13-2018, 07:29 PM   #7
Emilime75
1209
Drives: 2010 335i E92 LeMans Blue
There are the lowering spring perches, and cutting the locating tabs on the front struts as mild lowering options.
Run your VIN through an online decoder to determine what options(sport/non sport suspension) your car came with.
feuer4277.00
      09-22-2018, 02:40 PM   #8
SHEEDI
603
Drives: 2009 335i - Sport PKG
2009 BMW 335i  [8.50]
what springs will be ideal for 2009 335i sedan with sport suspension with stock Bilstein 4s struts? I m not looking for too much drop, something in between comfort and better handling?
I have following shocks/struts
https://www.fcpeuro.com/products/bmw...rber-19-135052
      09-22-2018, 10:13 PM   #9
whyzee125
1704
I'd recommend Eibach pro kit. They're pretty mild with about the same spring rates as stock and a slight drop. Bilstein B4's are capable of handling them without bouncing.
SHEEDI602.50
      05-06-2024, 07:33 PM   #10
S.Ward
Drives: 2008 BMW 328i E90
I have a quick question for this post, would the koni Red 87451014 L&R special active suspension work for a BMW E90 328i 2008 with M sport suspension package. having trouble getting the struts in and the newer ones are an inch longer than the older ones. thank you.
