Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > diverter valve removal, plastic grey clips
      12-17-2006, 10:47 AM   #1
Edman951
Edman951's Avatar
50
Drives: 2014 i3, Capparis White
Hey guys,
I'm tring to swap out one of the diverter valves with a HKS valve.
But i can't get the dam plastic grey clips off.
These are bizare clips that they use instead of regulaar hose clamps.
Does anybody know the trick to remove these clips????
Please help.
      12-17-2006, 10:57 AM   #2
Bob at Stratmosphere
Drives: Space Gray BMW 335i
You will have to twist the connector located on the bottom of the hose.
      12-17-2006, 11:07 AM   #3
NaViT
NaViT's Avatar
69
Drives: 04 M3/E92 335i
Originally Posted by Edman951
Hey guys,
Please help.
nice let us know how this goes and the results
      12-17-2006, 11:12 AM   #4
Edman951
Edman951's Avatar
50
bob,
Twist unsrew or screw?
I tried that but its hard. and i didnt want to break it.
Thanks
      12-17-2006, 11:19 AM   #5
Edman951
Edman951's Avatar
50
ooo yes i got it.
Thanks alot Bob.
will post result later
      08-08-2013, 11:22 AM   #6
ashmostro
1254
Drives: 2020 M4cs | 2022 M550i
Reviving this old one bc I'm trying to remove my valves to install a charge pipe and can't seem to get the technique right... the twist lock connector isn't budging!
Is there a special trick to it our just brute force?
      08-08-2013, 11:35 AM   #7
135Pats
135Pats's Avatar
456
Drives: A few BMWs
They can get very gummy, and tough to remove by hand. I used a simple wrench for grip and toque, and gave it a good twist around the grey locking collar. I did this months ago, but don’t recall any issues after that approach. I have no plans to re-use the DVs, but it didn’t damage them or anything like that.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      08-08-2013, 11:37 AM   #8
ashmostro
1254
So there's no locking clip to unlatch first, while twisting?
Thanks
      08-08-2013, 11:39 AM   #9
BoostAddict
48
Drives: SGM 335i
It can take a bit of force sometimes. It sounds dumb, but make sure you are turning them the proper direction.
      08-08-2013, 11:42 AM   #10
135Pats
135Pats's Avatar
456
Drives: A few BMWs
Thanks
IIRC its’ just that grey collar that unlocks when turned the correct way, I don’t remember which way that is though. Just find yourself a bit of mechanical torque/grip and it’ll turn without too much trouble.
F30 N55 XDrive EBII
      08-08-2013, 11:46 AM   #11
ashmostro
1254
Ten four. Thanks fellas.
      08-08-2013, 12:13 PM   #12
007_e350
007_e350's Avatar
217
Drives: 335i 2008 MHD'd / x5d E70
If I remember correctly move it counter cw from top ... becareful not to put too much pressure on the pipe itself .. I had to pay to get DPs removed to push in the rear turbo inlet that came half way out because of strangling while airbox removal ... there are no clamps on the turbo end
      08-08-2013, 01:09 PM   #13
ashmostro
1254
Will do it once my car cools off and I get some work done. I think the directions to twist are pretty clear as there is a stop in the twist-lock channel that only would allow the mechanism to go in one direction once locked. Will try some channel locks in a bit and report back!
Thanks all
      08-09-2013, 12:12 PM   #14
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Be careful with channel locks. These should be able to twist by hand and channel locks may put too much pressure and crack them.
I recall giving them a quick push in and then twisting it to unlock. Sometimes pushing it in helps. (Push in, Push out then try twisting). No homo.
      08-09-2013, 12:18 PM   #15
BD_F22
BD_e92
358
Drives: 2015 m235i xDrive
      08-09-2013, 12:31 PM   #16
ashmostro
1254
Lmao
Yeah, I chose not to use the channel locks and just used bare handed brute force (Hulk MAAD!). Everything worked out just fine and the CP-e/BMS pipe is now in there!
FWIW the installation instructions CP-e provides are a bit overkill. Don't need to remove the diverters entirely to install them on the new pipe. Didn't want to pull the vacuum hose if I didn't have to.
Thanks for the encouragement, fellas
      03-11-2014, 02:09 AM   #17
diegopiedra
diegopiedra's Avatar
39
Drives: 335i
How did ur turbo sound when this happened? I think i might have the same problem. Did you throw any codes
Fbo stage 3 mmp turbos 100% e85 335i n54 e92
      01-01-2016, 12:09 PM   #18
Narcosis
The dude abides
Narcosis's Avatar
50
Drives: 2016 F82
I've swapping in an ER charge pipe & TiAL valve. The front DV came off very easily, but I'm having a heck of a time getting the rear return line to release - the grey ring closest to the firewall just won't budge. Before I start removing it the hard way, any advice?
There's not room for channel locks on the underside of the ring, and an attempt to use them on the to grab & rotate didn't work.
      01-01-2016, 12:18 PM   #19
Narcosis
The dude abides
Narcosis's Avatar
50
Drives: 2016 F82
And nevermind, got it.
      11-09-2017, 03:57 PM   #20
vrmoreno3
Drives: 2019 G05 X5 40
Just curious, how do you know when it’s time to replace the DV?
