BMW X5
      10-09-2023, 10:12 AM   #1
cycolac
Drives: 2023 X5MC
X5 M Competition tire question
Wanting to put all-season tires on my X5MC, but apparently none exist in the standard OEM format.
Considering 3 options:
1) Read in another thread that some were considering putting the 295/35/21 tire size on all 4 corners.
2) I can get Pirelli Scorpion Zero A/S in the 295/35/21 for front axle and Pirelli P Zero A/S in the 315/30/22 for rear axle... all have same speed/load/tread ratings
3) Suck it up and just use winter tires
Has anyone tried option 1 or 2, or is that highly discouraged because it might cause issues in the car?
other thoughts?
      10-09-2023, 10:51 AM   #2
Gfit
2758
Drives: 2023 X3M, 2024 X5M. Sold 2022
They exist..
https://e89.zpost.com/forums/showthread.php?t=2049060
Oldgixxer1994.00
      10-09-2023, 10:54 AM   #3
Jeff J
109
Drives: '24 X5M, '18 M2, '09 135i
Is option 1 intended to use the factory 21" wheels (808m), or at least wheels with the same offsets? If so, no problem - it's a factory fit option.
Option 2 will likely be shot down by most. It's never a good idea to mix different tire models front/rear, and Scorpion Zeros and P Zeros are not terribly similar except in name. Would it work for commuter-style (non-performance) driving? Probably. Would the handling be predictable? Maybe not.
I'm leaning towards Option 3 myself. Conventional wisdom would say to put a narrower winter tire on (square 21's, for example). I'm strongly considering using OEM staggered sizes on the factory wheels for winter, and getting a new separate set for summer.
Remember - winter tires are as much about temperature as snow. We had our first cool (upper 40s) weekend of the year this week in Kansas, and the PS4S's on our M2 were clearly down on grip already.
      10-09-2023, 06:35 PM   #4
cycolac
Drives: 2023 X5MC
Originally Posted by Gfit View Post
Who knew.... you're right - I couldn't find reference to these anywhere I looked... VERY interested in how you like these.
      10-10-2023, 10:31 AM   #5
cycolac
Drives: 2023 X5MC
Just purchased these Arroyo tires from prioritytire.com - thanks Gfit for this great catch
Gfit2758.00
      10-16-2023, 11:55 PM   #6
bmwarg
62
Drives: 2008 E90 335i, 2012 E70 50i
Aren't the Pirelli P Zero All Season another option?
https://simpletire.com/brands/pirell...hicleYear=2020
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
      10-17-2023, 03:38 AM   #7
Gfit
2758
I believe the tires you referenced are the P Zero Summer Tires. I don’t think they make a matching AS in X5M sizes.
      10-17-2023, 07:39 AM   #8
cycolac
Drives: 2023 X5MC
The website you show does indicate this, yes, but it is not reality. Pirelli's own website shows the P Zero A/S comes in the rear size 315/30/22, but not the front 295/35/21's
https://www.pirelli.com/tires/en-us/...ero-all-season
      10-17-2023, 08:26 AM   #9
bmwarg
62
Got it - sorry for the confusion!
      10-17-2023, 08:54 PM   #10
Black5spdz
Drives: 2021 x5m
I put Continental dws 06+ on ours, did one size taller than oem on stock competition wheels. Ride is better and suits my wife’s needs, it is also lowered with no rubbing. 295/40/21 front and 315/35/22 rear
      10-17-2023, 09:08 PM   #11
bmwarg
62
Is the all season good enough for Chicago winters? Does the extra height make the ride quality softer?
      10-18-2023, 08:40 PM   #12
Black5spdz
Drives: 2021 x5m
Ride is slightly less harsh. I think so, they are definitely not dedicated snow tires but depending on how much you drive probably they will probably be good. We have other options if the weather is really bad but plan to drive this most of the time. We live in Michigan and get decent snow.
Bankerbry403.00
      10-19-2023, 07:47 PM   #13
bmwarg
62
My wife would appreciate a less harsh ride. Michigan is the same as Chicago. Where did the idea for these tires come from? I didn’t know you could install tires with greater height… any safety concerns?
      10-19-2023, 08:19 PM   #14
X5MGuy
10
Drives: X5 M
Height of the spare tire might be an issue if you go taller all around. That may or may not mess with the AWD system assuming you try and run it in winter.
      10-19-2023, 09:13 PM   #15
Black5spdz
Drives: 2021 x5m
Just something I decided to try, I work in the car industry and enjoy modification. Speedo is now dead on at 80. Spare could be an issue if ran for an extended length of time but doubt it would cause any issue to reach a destination. No safety concerns for me at all.
      10-19-2023, 10:03 PM   #16
bmwarg
62
Im starting to lean on getting one larger aspect ratio. It appears the Pirelli Scorpion winters also come in the 295/40ZR21 and 315/35ZR22. I assume the softness of winter plus the thicker tire wall will make it comfortable. But is that too much? Would winter tires already soften the ride a bit? Would it void the drivetrain warranty?
      04-30-2024, 08:55 PM   #17
Bankerbry
Bankerbry's Avatar
403
Drives: 23 X5MC, 21 M8CGC, 19 X7 M50
I just wanted to follow-up with you on this and see how the Continental tires have treated you? I just purchased a 23 X5MC that has Pirelli's on it, and I'm willing to try anything to soften up the ride a bit! Living in SD, I also prefer an all season tire anyways.
I've owned a lot of cars and currently have a M8CGC & Audi RS7 and I can't believe how horrible this ride is. It doesn't even compare to the M8, and don't completely understand why they would need to make it this stiff. Not only to you feel every single bump & Crack in the road, but you also hear them. This thing shakes & vibrates over every bone jarring bump.
Don't get me wrong it's an absolute beast, but now my wife forces me to drive her X7 every time we go anywhere because the X5MC is so rough.
I appreciate your feedback and any suggestions on tires.
Thank you
      05-01-2024, 05:11 AM   #18
Gfit
2758
Thank you
I’m sure you already did this but did you check your tire pressure. My 24 X5M is so much smoother and more comfortable than my wife’s 23 X3M and my previous 22 M3. Family loves it for road trips.
Bankerbry403.00
crabman312.50
      05-01-2024, 07:27 AM   #19
crabman
313
Drives: 2024 X5M
Good call, mine had 55 psi all around on the lot. Not just too high for comfort, 5 psi above the maximum safe inflation pressure of 50 for a PS4.
xbimmers
