      12-31-2018, 09:39 AM   #1
Docflyer
18
Drives: M5 2019
Wheel/Rim coatings
Purchasing a different set of wheels for M5. I would like to coat them in the best and longest lasting product (ceramic) available before installation. What would you guys recommend? Really tired of BMW break-dust and would like to make wheel maintenance as painless as possible.
      12-31-2018, 11:15 AM   #2
josec70
josec70's Avatar
4079
Drives: 22' Individual Chalk M5C
Hopefully a manufacturer releases some Carbon Ceramic aftermarket pads soon. I went this route on both of my F10 M5's and never looked back.
The applications help when cleaning the wheel but do little to keep dust off of them; this has been my experience.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      12-31-2018, 09:46 PM   #3
stbm5
261
Drives: 2018 M5 DG
I concur with the last post. I've coated wheels and honestly it doesn't make a huge difference. Getting low dust brake pads is much more helpful but even then they will still get dirty.
      01-01-2019, 08:47 AM   #4
Docflyer
18
Drives: M5 2019
Thank you for the replies. You would think that a thick ceramic coating would prevent the brake dust from adhering.
      01-01-2019, 09:06 AM   #5
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
It helps, but still requires regular cleaning, just with less effort. For those who fastidiously clean their wheels, it probably is less useful.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      01-01-2019, 11:40 AM   #6
josec70
josec70's Avatar
4079
BMW brake dust is merciless ... I've not yet tried anything that's been remotely effective.
      01-01-2019, 02:58 PM   #7
stbm5
261
Drives: 2018 M5 DG
are the brakes on the F90 the same as the brakes on any other bmws? it seems unlikely that they'd have something totally different - given that there aren't any low dust pads advertised specifically for the F90, is there something else that will fit?
i had porterfield low dust pads on my F82 and they were great.
      01-01-2019, 03:32 PM   #8
josec70
josec70's Avatar
4079
I inquired and was informed they were different pads (versus F10 M5 pads at least); I reached out to Powerstop who informed me they were working on something. I had their pads on one of my F10 M5's and they were very good so hoping they release these sooner than later. I assume Akebono, Cool Carbon and Carbotech may follow suit but who knows when that will be.
      01-03-2019, 03:27 PM   #9
kdeleon
94
Drives: M5
So is the consensus to skip a professional ceramic coat for the wheels? I received my new wheels and am being offered a discount to do the ceramic coating from my pro as they are pretty much prepped for application and have no tires.
For my OEM wheels, I have tried all sorts of waxes and spray on coats. They make it easier to clean for one or two washes then it is back to normal. I know new brake pads are the long term solution. But wondering if a professional coating is even worth it or just continue to wash it well.
Has anyone tried the home version of applied coatings like Gyeon Rim. Maybe that is a good alternative or in between solution.
      01-03-2019, 05:33 PM   #10
Docflyer
18
Drives: M5 2019
kdeleon the Gyeon products do seem to have good reviews. The company states the ceramic coating is designed to withstand the higher wheel temps. Has anyone here had experience with these products?
      01-04-2019, 07:18 PM   #11
josec70
josec70's Avatar
4079
I honestly would not bother ...
      01-04-2019, 07:21 PM   #12
josec70
josec70's Avatar
4079
I've tried Gyeon and was not impressed with the results.
      01-05-2019, 04:57 PM   #13
marcvtec
407
Drives: M5
FWIW - I have the full Cquartz pro done to the car and wheels.
While I can do a $3 dollar coin op rinse and get most of the crap off the body - the wheels always still need the brush. Other wise they look dull.
      01-05-2019, 05:58 PM   #14
stbm5
261
Drives: 2018 M5 DG
an aside: its highly doubtful that there are many different formulas for ceramic coatings. after using several different brands i'd say they are all roughly the same. i think its exceedingly unlikely that say gyeon and cquartz are markedly different - and I've used both. id say there are some differences in ease of application with some being very thin and easy to wipe off and some being thicker and harder to remove. of the several i have tried i found the opticoat to be the easiest application and the cquartz uk to be the most difficult.
i have some new wheels on the way and yes i will coat them but only because i have some left over cquartz dlux. i have not coated my current wheels because the effort required to remove and prep wheels is more effort than i want. at least the new wheels won't require any surface prep.
the wheel coating claims need to be taken with several grains of salt. they just are not very effective at reducing brake dust adhesion.
      01-12-2019, 10:45 AM   #15
Docflyer
18
Drives: M5 2019
Has anyone here tried Carpro iron-X for brake dust removal? I’ve seen reviews that say it works very well.
      01-12-2019, 11:33 AM   #16
kdeleon
94
Drives: M5
I can't imagine that iron-x would be much different than Sonax. The later I tried on my wheels and the previous only on the body paint. They both have the same active ingredient that turns dirt/iron purple. They both stink (as in smells). But I find on the wheels no matter what spray or formula I use, I have to agitate things with a brush. There is no spray and done. I am going to try the Auto Fanatic foaming solution. That is coming this week. It seems different than all the other solutions.
      01-12-2019, 07:29 PM   #17
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Please let us now how this works when you get it.
      01-12-2019, 09:04 PM   #18
stbm5
261
Drives: 2018 M5 DG
it does work well but its not as the youtube videos claim. its not simply spray on rinse off. you will still need some elbow grease.
