Diesel Fuel Additives?
12-07-2016, 09:03 AM | #23 | |
158
Rep 866
PL |
12-07-2016, 09:09 AM | #24 |
143
Rep 509
Archoil all the way. Have been using their products since I bought my e92 and having reviewed them on here, other e90 users have also gone on to use them and give positive feedback
12-07-2016, 10:53 AM | #25 | |
36
Rep 122
Interesting paper. Taking a quick scan through the document, I find it significant that the East Coast and Midwest as well as Canada have the lowest Cetane ratings in the world (mean of 44 and 45). They also have the lowest min. Cetane requirements. Right in line with what everyone has always suspected. Goes to show you that the petroleum industry isn't really interested in producing the best fuel possible, just the best fuel that meets the minimum requirement of that region. The most profitable and powerful industry in the world....sure they are looking out for my interests! |
EvanTheBruce57.00 civilator3.00 |
12-07-2016, 11:59 AM | #26 | |
14
Rep 158
Most business owners share the money mindset, in that they want to make the most they can. Therefore, tons of stations offer crap bio so they can get a tax break. Thats only the tip of the iceberg.
2012 X5d - Current
2009 335D - Totaled |
12-07-2016, 12:19 PM | #27 |
357
Rep 1,731
kydiesel35166.00 |
12-07-2016, 12:28 PM | #28 |
Master and Commander
17
Rep 55
I'm fairly certain
but not positive that most all of the diesel fuel in metro Atlanta flows through the same pipeline owned by Colonial Pipeline. That pipeline is the major one of two pipelines that serve Atlanta. It's the one that has had two separate issues (explosions) recently affecting gas and diesel prices and availability across parts of the Southeast. See link below.
I believe the local fuel distributors add their additives at the local distribution points. Who knows what kind of quality control they follow or how good the actual execution of that quality control plan is. I tend to believe it is probably pretty good, maybe even automated and excellent. I have no problem using Diesel-Kleen to ensure at my micro-level of use I am getting the lubricity and cetane bumps I want. Never experienced any issues I would attribute to Diesel-Kleen. I don't necessarily hit every tankful with Diesel-Kleen as sometimes it s just not easy (traveling away from home...). http://politics.blog.ajc.com/2016/10...gesttease_1101 |
EvanTheBruce57.00 |
12-07-2016, 12:37 PM | #29 |
103
Rep 580
This is true, IAW FAA regulations prohibiting anything but base fuel in pipelines. It's an airline safety issue, little known and completely overlooked by the pundits blindly expecting some intangible entity like an oil company, the gubmit, whatever, to look after their best interests.
EvanTheBruce57.00 |
12-07-2016, 01:09 PM | #30 | |
767
Rep 3,558
My brother works for pipeline company so I will ask him as back up concerning base fuel only allowed in line or not. |
12-07-2016, 08:56 PM | #31 |
NY BRAVEST
47
Rep 231
VP's fuel and additives have always been good stuff.. I use VPs Cetanium in the D and c12 and c16 and in my drag car and love there stuff.
EvanTheBruce57.00 |
12-11-2016, 07:19 AM | #32 | |
158
Rep 866
There is no data that gives any information on outcomes (s.a. failed fuel pumps etc.) nor any data that helps one decide on if any aftermarket additive does anything of value (even if some numbers improve s/a cetane or lubricity). There is no evidence here that we should go out and buy additive for our beloved diesel after companies competing with Infineum have provided pre-retail additives already, since there is no outcome data. There have been studies that imply the quality of the base stock plus pre-market additive is what determines outcomes and which is not altered significantly by aftermarket additive, even if the numbers are better (think of a cholesterol drug that improves the numbers but is not proven to improve life expectancy or quality of life - there are such drugs on the market!). Of note, for the entire East Coast, only 9 samples of diesel were used and this was winterized diesel, which tends to be tougher to produce. 32 samples were used for the entire Midwest and 10 samples only for the entire West Coast. Noteworthy that even the cetane numbers hovered into the mid to high 40's, which seems good. No detail is published in the report as to where the samples came from brand-wise as only regional refinery outputs were randomized. None of these numbers are significant statistically as the variability is likely too much for the number of samples used (i.e. one would need many more samples to make the conclusions from the data statistically significant for a particular region). The Infineum survey seems good for only one thing, charting world trends in diesel quality measures according to how they have measured them. PL Last edited by Pierre Louis; 12-11-2016 at 07:35 AM.. |
12-11-2016, 07:56 AM | #33 | |
166
Rep 460
All the "aftermarket" additive companies work closely with the chemists that sell additive packages to the large refineries. They both work together in conjunction to produce the best blends possible. The only downfall is they only need to have "bare minimum" lubricity and cetane, in order to make more $$$$ (Shell, BP, PL, you get it). 40 cetane and who knows what else? No thanks. Lubricity being the cheapest chemical then deposit control, antigel, cetane, water control, being the most expensive. Whatever you wanna believe is up to you man. But you are astronomically wrong. I advise everyone on here to pick a good additive to run this winter to protect their investment. Don't be fooled. |
12-11-2016, 08:06 AM | #34 |
166
Rep 460
We are trying to be a community that helps each other to have the best possible outcomes to fix issues. Why are you knocking this? What's your objective? Do you believe everything a corporation tells you? Even BMW?
40k miles put on my car since I bought it. Injector history in the past and guess what??? None now, must be a coincidence huh... Do what makes you happy |
12-11-2016, 08:08 AM | #35 | |
614
Rep 2,410
That's just silly, Pierre. Bosch and others HPFP manufacturers have published all kinds of data on HFRR and fuel pump longevity. https://www.arb.ca.gov/fuels/gasolin...22003bosch.pdf Cold characteristics for those of us who live in cold weather is a critical parameter. Saying otherwise is silly. We'll be having single digit F highs and negative F lows this coming week. Having had diesel vehicles plug their fuel filters in extreme cold temps in the past, the cold flow properties are extremely important... This is also something easy to test at home. You can take a sample and put it different containers with and without additive and test for yourself. No supporting data that aftermarket additive do anything of value? This is just silly. Of course, one can always find "reasons" not to believe measured data due to some aspect of the tradeoffs required in setting up the study, the cost of sample sizes, lab testing fees, resource constraints, etc....
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
12-11-2016, 08:29 AM | #36 | |
158
Rep 866
Again, there is no reason to use aftermarket additives, only the belief that they might work. This is technically not "naysaying" but perhaps just a statistical argument. PL |
12-11-2016, 08:31 AM | #37 | |
158
Rep 866
Not believing is not the same as believing in the wrong thing. PL |
12-11-2016, 08:34 AM | #38 | |
158
Rep 866
PL |
12-11-2016, 08:46 AM | #39 |
Kind of a Big Deal
167
Rep 857
There is much that is hype and snake oil in the fuel additives world.
It does not follow that all claims are bogus. I would refer folks to tdiforum and DubFamily's carefully monitored results over tend of thousands of miles, showing a linear correlation between Optilube use and improved mileage. Last edited by Persian Whisperjet; 12-11-2016 at 09:51 AM.. Reason: Went to tdiforum and checked -- his tests were on Optilube not PS |
12-11-2016, 09:04 AM | #40 |
103
Rep 580
Gawd, I LOVE the Interent!
I can only see Louis' posts after somebody quotes him, because he went on my ignore list quite some time ago after our first interaction here. I did see his comment quoted above about some additive company being "incentivized" to find problems. People believing these companies have an incentive for anything other than profit must be either ignorant or a shill. I thought I remembered seeing something from this person a couple weeks ago regarding a new car and they no longer even own a BMW. If I was mistaken from reading between the quoted lines it wouldn't be the first time, but if that is the case, the shill possibility seems more likely. Maybe an unofficial shill who works or worked for one of the greedy corporations.
This is simple common sense once you get past the fact that money and the financial system from the Federal Reserve down to you and me and everybody in between provides the basis for everything to function in this society. All the rest of the related gobbledygook is just a bunch of conspiracy theories. Who knows? Don't care. Just be careful what you read on the Internet. As an aside, any word on the pipeline topic, BB? Wouldn't want anyone believing I'm spreading false or misleading information.... |
kydiesel35166.00 |
12-11-2016, 09:58 AM | #41 |
767
Rep 3,558
12-11-2016, 10:25 AM | #42 |
Kind of a Big Deal
167
Rep 857
This is more in the mileage lane vice lubricity but FYI:
Originally Posted by DubFamily View Post Round 1: Optilube Summer Tank 1: (1oz added 4/24/13) 616.9 miles; 14.310 gallons added; 43.110 mpg Optilube Summer Tank 2: (1oz added 4/29/13) 613.1 miles; 14.164 gallons added; 43.286 mpg Optilube Summer+ Tank 1: (2oz added 5/03/13) 604.1 miles; 14.044 gallons added; 43.015 mpg Optilube Summer+ Tank 2: (2oz added 5/09/13) 606.0 miles; 13.902 gallons added; 43.591 mpg Un-additized Diesel Tank 1: (Pure D2 added 5/15/13) 573.7 miles; 13.806 gallons added; 41.554 mpg Un-additized Diesel Tank (Outlier): (Pure D2 added 5/21/13) 605.2 miles; 13.638 gallons added; 44.361 mpg Un-additized Diesel Tank 2: (Pure D2 added 5/24/13) 567.2 miles; 13.990 gallons added; 40.543 mpg Optilube XPD Tank 1: (4oz added 5/30/13) 621.9 miles; 13.918 gallons added; 44.683 mpg Optilube XPD Tank 2: (4oz added 6/05/13) 609.7 miles; 13.723 gallons added; 44.429 mpg Round 2: Optilube Summer Tank 3: (1oz added 7/10/13) 656.1 miles; 14.726 gallons added; 44.554 mpg Optilube Summer Tank 4: (1oz added 7/15/13) 618.3 miles; 14.264 gallons added; 43.347 mpg Optilube Summer Tank 5: (1oz added 7/19/13) 603.0 miles; 13.516 gallons added; 44.614 mpg Optilube Summer+ Tank 3: (2oz added 7/26/13) 650.0 miles; 14.677 gallons added; 44.287 mpg Optilube Summer+ Tank 4: (2oz added 8/02/13) 643.8 miles; 14.257 gallons added; 45.157 mpg Optilube Summer+ Tank 5: (2oz added 8/09/13) 600.2 miles; 12.095 gallons added; 49.624 mpg Un-additized Diesel Tank 3: (Pure D2 added 8/15/13) 524.0 miles; 13.792 gallons added; 37.993 mpg Un-additized Diesel Tank 4: (Pure D2 added 8/27/13) 569.5 miles; 13.796 gallons added; 41.280 mpg Un-additized Diesel Tank 5: (Pure D2 added 9/03/13) 586.6 miles; 14.307 gallons added; 41.001 mpg Optilube XPD Tank 3: (4oz added 9/08/13) 609.2 miles; 14.173 gallons added; 42.983 mpg Optilube XPD Tank 4: (4oz added 9/13/13) 651.4 miles; 14.251 gallons added; 45.709 mpg Optilube XPD Tank 5: (4oz added 9/18/13) 679.4 miles; 14.241 gallons added; 47.707 mpg Round 3 (Double Dose): Optilube Summer Tank 1: (2oz added 9/23/13) 628.3 miles; 14.216 gallons added; 44.197 mpg Optilube Summer Tank 2: (2oz added 9/30/13) 638.0 miles; 14.438 gallons added; 44.189 mpg Optilube Summer+ Tank 1: (4oz added 10/05/13) 618.9 miles; 13.695 gallons added; 45.192 mpg Optilube Summer+ Tank 2: (4oz added 10/11/13) 605.8 miles; 13.657 gallons added; 44.358 mpg Optilube XPD Tank 1: (8oz added 10/17/13) 624.7 miles; 14.253 gallons added; 43.829 mpg Optilube XPD Tank 2: (8oz added 10/24/13) 579.5.7 miles; 14.176 gallons added; 40.879 mpg |
kydiesel35166.00 |
12-11-2016, 12:00 PM | #43 |
Curmudgeon and Pedant
690
Rep 3,489
Anyone know if the biodiesel content is factored into the lubricity as delivered to the station? B5 makes for way better scar/HFRR scores than straight ULSD.
Although the CARB diesel scar standards are the same 520 HFRR, almost all the diesel in CA states is B5 or so. For the newbies, TDIWyse and Pierre have been arguing this stuff for years. Although I have to say I've learned a lot from their posts. |
12-11-2016, 02:29 PM | #44 | |
64
Rep 266
