2A9A Camshaft sensor inlet signal, again?
08-07-2012, 03:31 PM | #1 |
84
Rep 98
2A9A 10906 Camshaft sensor inlet, signal.
I just recently replaced my Camshaft inlet sensor as well as both intake and exhaust solenoids due to 2A9A, 3100 codes being thrown. Symptoms were intermittent long crank and 1/2 engine light. I could turn off the ignition and restart the car and all was good, for a while. Now a few weeks later, I am getting the same symptoms and codes. I am running Proceed v2.5 and v5 4/23 stage 1 maps. ETS intercooler and BMS DCI. Other then that, the car is pretty much stock. The symptoms seem to appear when the car is warm. I drive the car at lunch time, it sits for a couple of hours, and then bam! Any ideas what else I should be troubleshooting? Thanks. |
08-08-2012, 08:19 AM | #3 |
Some dude
92
Rep 1,780
Might want to recheck all the connections on the Procede and harness. Clear it and see whether it comes back quickly or takes a while.
RRT
E92 335i/6MT with stuff and things |
08-08-2012, 09:04 AM | #4 |
84
Rep 98
Thanks, kinda been there done that. The harness is a fairly new replacement due to issues with the previous harness. All connection appear clean and secure. I did a full reset yesterday. Waiting to see if / when issue returns...
08-08-2012, 11:14 AM | #5 |
Some dude
92
Rep 1,780
Could be that it has nothing to do with the Procede, too. I'd have to check wiring diagrams, but a bad 5V output, bad ground, or some other issue could be causing the problem. See it somewhat often the older the car is. The voltages and 0V/grounds are soooo sensitive that it doesn't tolerate much of a bad connection.
RRT
08-08-2012, 11:21 AM | #6 |
202
Rep 1,950
Drives: 335i
injectors
10-01-2012, 08:07 PM | #7 |
Power without control is no power at all...
15
Rep 190
I'm in the same boat - just got the code two days ago, but I've been too busy to post about it since I hadn't combed the net for an answer yet (search first). My car bogs down when I go WOT uphill, 80-100mph, but only occasionally. I thought it was the plugs and was going to swap them out, but then this 2A9A popped up. Bump for a solution.
*edit: I get 3100 "boost-pressure control, deactivation" also like OP.
2009 335i Coupe 6MT Blk Sapphire / Blk Leather
2007 328i Coupe 6MT Blk Sapphire / Blk Leather *Sold 1985 Toyota Corolla GTS 5MT 1.5-way Slvr / Blk *Sold 1987 Toyota Corolla GTS 5MT KAAZ 2-way Blk / Blk *Sold Last edited by Figure807; 10-01-2012 at 08:20 PM.. |
10-26-2015, 10:04 AM | #8 | |
46
Rep 177
Drives: E90
02-01-2017, 02:42 AM | #10 |
44
Rep 359
Camshaft ledges is another semi common failure in n54s.. Earlier designs had a metal ring around the cams which overtime makes a little groove in the camshaft ledge. The groove results in a little oil pressure drop enough to mess with vanos system and makes throw some random vanos codes.
