02-28-2021, 12:56 AM | #23 |
259
Rep 71
Seems a popular mod this.........
These are the tyre sizes I'm going with for my new wheels also.😉
Also on Instagram @w2blw_x3m
Kevin_The_Clean13355.00 |
03-01-2021, 11:37 AM | #25 |
445
Rep 616
Technically yes. You could have a situation where they try to claim the tire size change caused a problem. Lets say you're differential started to make noise and they didn't want to deal with it so the blame it on your tire swap. Comes down to the service department you use. Then you'll have to fight to get things fixed or take it to another dealer and hope for an actual diagnosis.
freshxdough3546.00 |
03-09-2021, 05:11 PM | #26 | ||
Rep 12
03-10-2021, 02:30 PM | #27 | |
125
Rep 172
03-10-2021, 11:36 PM | #28 |
21
Rep 112
Exactly, me either. Not quite trusting yet...maybe after the factory tires, but mine has already been down for a lot of warranty work on the engine in the first 1k miles...it’s been good for the next 1k, but still only 2k miles on it so not that much time to gain the confidence. My dealer was great, so I don’t think they’d do anything shady, but still a little nervous about needing warranty.
03-11-2021, 12:18 PM | #29 | |
125
Rep 172
03-11-2021, 01:44 PM | #30 | |
1719
Rep 1,391
Drives: 2020 X3MC
Thtshowiroll47127.50 |
03-12-2021, 07:27 PM | #31 |
1882
Rep 3,341
On top of more tire, no more skittish handling over bumps. Rides a lot better too. Always get the Michelin’s.
Edit- I’ll add they wear better too. My contis were 2/3rds worn at 6k miles
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
03-15-2021, 05:02 PM | #32 | |
87
Rep 81
Now if you changed the ratio (OEM is 1.0099:1) then you could argue premature wear to the vehicle. For reference the 255/40 and 295/35 is 1.0033:1. I wouldn't do 265/40 front as that makes the front tire larger in diameter than the rear tire, which is the opposite of the stock sizes. |
03-16-2021, 01:28 PM | #33 | |
Rep 4
Been wondering the same thing as I hold off on ordering mine... anyone have any ideas? |
03-16-2021, 01:49 PM | #34 | |
445
Rep 616
Rim Width Range (Min/Max) 10.00" - 11.50" That is straight from Michelin's website for the 295/35/21. |
03-17-2021, 08:32 PM | #35 |
Rep 15
03-20-2021, 04:56 PM | #36 | |
21
Rep 112
03-20-2021, 09:09 PM | #37 |
87
Rep 81
Yes, using the 295 rear and 255 front would create a ratio that would be close to the factory ratio, while still having the rear tires be larger in diameter than the front (just like the factory setup). If you went to a 265/40 front 295/35 rear then your front tires are now larger in diameter than your rear.
03-20-2021, 10:27 PM | #38 | |
21
Rep 112
03-21-2021, 12:34 PM | #40 |
21
Rep 112
03-21-2021, 02:06 PM | #42 |
21
Rep 112
Oh ok, so we're talking real minor differences that don't really have an impact. Gotcha. Thanks!
03-21-2021, 06:47 PM | #44 |
4949
Rep 3,820
