05-26-2021, 09:00 AM | #1 |
249
Rep 535
Drives: 18%E2%80%99 M3 Comp Pkg
Rock Chip on Front Bumper MW
Hello Everyone ,
I seem to be having the worst luck with my front bumper attracting every rock here in NJ. I am rarely on highways and if I am a short period of time and 100% stay away from anything that would throw rocks up however…. Just looking for some forum advice and the best plan to attack this rock chip which I call a rock chip and and push also… I've already researched heavily Dr color chip and automotive touch up knowing that the OEM touch up paint is not good at all. Any advice is appreciated Thank You!
2010 Apline White 135i - Sold
2018 Mineral White M3 /// Comp Package |
05-28-2021, 09:50 AM | #3 |
581
Rep 1,055
No matter how proactive you are, something will still happen eventually. This will just be the first of many. The first one is the hardest one, then subsequent ones are just "wear and tear" and you stop to care as much....well that's how I was. I got the "high impact areas" PPF'd which helped, but it still had minor issues with rock dents (much like what you have minus the paint damage) from debris.
bmwbrad22249.00 |
06-06-2021, 07:13 PM | #4 |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
Even if you had PPF, that probably would have tore through it. The cheapest thing to do is just to use touch up paint and fill it. If that fails and it really bothers you, painting the entire thing is the only thing you can do.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
06-06-2021, 08:07 PM | #5 |
249
Rep 535
Yea it was really nasty as you can see , I actually filled it with Dr. Color Chip and the color match isn't that bad at all considering it's Mineral White and fairly difficult to find a good match for touch up. I attached a photo just a quick fill.
06-06-2021, 09:55 PM | #6 |
7609
Rep 3,611
Looks great! Had to look to find it tbh
Current: F80
Prior: F82, F32 |
06-26-2021, 12:45 PM | #7 |
285
Rep 498
How many coats?
06-26-2021, 12:51 PM | #8 | ||
249
Rep 535
I did pick order touch up paint from another seemingly good site and I have yet to do a test on material to see the color match etc. They have a base coat a mid coat and then a clear coat , I ordered this to see again how that match would be. I will share results for others looking for a good color match for touch up paint for BMW's mineral white A96 color code.
03-31-2022, 08:34 PM | #9 |
249
Rep 535
Another one…. And there is a noticeable dent from the impact off to the repair shop this time for some PDR. Not happy about this and then I'm going to just do a front expel wrap on the front 1/3 of the hood.
04-04-2022, 01:27 PM | #10 | |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
You'll be surprised how things hit you.... I even have chips on the power dome part of my hood that punctured the PPF. It's like little black dots if you look up close.
N1rve
bmwbrad22249.00 |
04-16-2022, 05:56 PM | #11 | |
Rep 2
First time poster and trying to figure out the best touch up paint to fix a scratch inside the door of my MW 2019 X5. Did this second batch of touch up paint look better than Dr. ColorChip? Can’t decide which touch up paint to get! Thanks for your input. |
04-16-2022, 06:00 PM | #12 | ||||
249
Rep 535
DO NOT BUY THE BMW MW touch up paint Share a photo here of the scratch and then I can make the best recommendation on which company kit etc
05-09-2022, 12:24 PM | #13 | |
Rep 2
Unfortunately someone closed one of my soft-close doors without the seat belt retracting and the automatic door shut itself. This created a pretty large gash in the paint and a slight dent. Hoping some touch-up paint will make it look better. I've also got a couple rock chips on the front of the car. Trying to cover/fix those up as well. Ugh Thanks again for any advice you can provide! Mineral White seems to be tough to match, so I was hoping to get some input before I purchase some touch-up paint. |
05-09-2022, 05:28 PM | #14 |
165
Rep 359
Hey,
After trip to sea side last week I got few rock chips on the front bumper and the hood. Front bumper is going to get fixed next week but I'd rather not want the hood to be repainted. why you do not advice to use BMW MW touch-up paint? once I fix everything I'm getting PPF for full front. Those rock chips are my nightmare now. |
bmwbrad22249.00 |
05-09-2022, 05:53 PM | #15 | |||
249
Rep 535
Hey Guys ! It's always sad to see the damage BUT living in NJ we know what happens Mineral White - Stay away from re spraying panels at all COSTS!! The Last Photo is the most recent with all my touch ups done & actually PPF on the front quarter of the hood actually. The BMW A96 mineral white touch up paint is closer to Alpine White then mineral white it will stick out even worse the the bare metal. My recommendation for touch up paints are as follows that I have personally used . By no means am I an expert but there are two that seemed to have fit the bill for an at home DIY repair to get the job done. For smaller chips Dr. Color Chip (they sell a few kits) - I have my touch ups that I posted done with that so you can see the paint match through there. For Larger chips scratches Automotive Touch Up Paint - you will have to buy a base coat a mid coat (which has the mineral flake layer in it) and then a top coat and then potentially sand wet sand & compound (but again go by your level of skill here )
Gertsee51.00 |
05-09-2022, 05:55 PM | #16 | |
249
Rep 535
These cars suck up any and all rocks , I did a lot of repair on my front bumper with the Dr. Color Chip kit and they are not noticeable at all. Not that my front bumper was in bad shape but it had some wear being it was mid 30k miles
