02-27-2022, 02:22 AM | #45 |
162
Rep 687
My car has done 118000km
Had shudder on rev and 1st gear Stage 2 tune for 30k Oil change and reset at bmw only cost $800aud Car drives really well Shudder gone |
TinCanSailor633.00 |
02-27-2022, 06:41 PM | #46 |
15
Rep 34
02-27-2022, 06:56 PM | #47 |
177
Rep 149
xHP transmission tune.
04-23-2022, 08:17 PM | #48 |
13
Rep 24
I just put 1100 miles on my 2nd set (warrantied) SSP clutches...First set were super sluggish and toasted on a full throttle downshift into 3rd. On throttle downshifts still suck, slow sluggish on throttle downshifts. Feels like the clutches will toast again if I full throttle and the car downshifts manual or auto. Would say they did get a little better but I still do not have enough faith in them to use as intended .
05-11-2022, 02:48 PM | #49 |
Frozen_Solid
98
Rep 38
I'm seeing a few of these issue post when searching, I'm running xHP stage 3 right now without issues for the power im making but would like to push it a little more. For sure going to look into DEKA if I make the jump
2016 Frozen Bronze Metallic M5 (Current) ApexBuilt Downpipes, Charge coolers, Titanium charge pipes and Titanium Front mount intakes, MHD stage2 93oct, XHP Stage3
05-11-2022, 10:43 PM | #50 | |
Fueled by Recycled Dinosaurs!
633
Rep 1,177
Drives: F06 M6
You'll end up melting a piston, bending a rod or seizing the rod bearings. There are issues with the injectors and intake manifold as well but if you get ahead of them before the motor eats itself you'll have many years of fun.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
05-11-2022, 11:58 PM | #51 | ||
177
Rep 149
05-12-2022, 09:02 PM | #52 | |
Frozen_Solid
98
Rep 38
05-12-2022, 09:39 PM | #53 | ||
633
Rep 1,177
Drives: F06 M6
Mishimoto has a large oil cooler in ore-sale ordering status right now. It has larger cooling surface and will hold about .8 quart more of oil. These are great cars but the heat eats em up.
05-13-2022, 03:43 PM | #54 | |
Frozen_Solid
98
Rep 38
Getting it changed next friday, I only have 21k on the clock but going to send it out "just is case" I also have been looking into that cooler especially with my being in Florida. The heat is extra bad here so thinking on meth injection as well
05-13-2022, 09:01 PM | #55 | ||
633
Rep 1,177
Drives: F06 M6
07-19-2023, 11:41 AM | #56 |
Rep 4
08-11-2023, 08:32 PM | #57 |
Rep 22
08-11-2023, 08:46 PM | #58 |
633
Rep 1,177
Drives: F06 M6
Thank you for the follow up. I am looking at replacing my clutches with SSP or Deka. Turner Motorsports is selling Deka clutches on their website with a lifetime warranty. The warranty is structured in a way that requires buying new clutches and getting a credit back to your TMS account. We own multiple bimmers so I am pretty sure we will use the credit if the clutches ever need to be replaced. So I am leaning a bit more on the Deka setup.
08-15-2023, 08:31 PM | #59 |
633
Rep 1,177
Drives: F06 M6
After watching the Evolve Automotive M4 Deka clutch install video again; I have decided to go with the Deka stage 2 clutch set. I was going to go with the Stage 3 but the comment about the hard kick going into reverse persuaded me otherwise as my wife does drive the car for me when I am deployed.
SpeedProtocol381.00 |
08-16-2023, 09:42 AM | #60 |
381
Rep 319
great to see. we need some good tested options.
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock |
12-25-2023, 07:16 AM | #61 | |
Rep 10
02-10-2024, 08:19 PM | #62 |
13
Rep 24
Honestly been to scared to let it auto downshift and go WOT fully. I have just been using the paddles and waiting for full engagement before going WOT. It is def better than what it was but still an issue. I have tried to learn the valves 100+ times to see if it would fix but half of the time I would get failures and when I did get completed learnings didn't seem like they did much.
05-03-2024, 07:22 PM | #63 | |
Rep 9
I have same issue , i now run my second deka stage 2 clutch First clutch toasted short after breakin in Now im after 400km on my second clutch but downshifting with delay , if driving slow downshifting is ok but if downshift around 2.5k rpm it feel like there is delay in engage the clutch , upshifting is fine for now but im still on breakin in so i dont go hard on the clutch I hope it get better after breakin in... |
05-06-2024, 12:34 AM | #64 |
564
Rep 1,457
There is another brand called Dodson I’m not sure if they’re still around or if anyone has used them. It seemed like BMS had positive experience with their development F10 M5.
05-07-2024, 01:45 AM | #65 | |
Rep 8
