12-22-2012, 10:56 AM | #1 |
115
Rep 1,470
Front wheel bearing bolt torque
i am installing my BBK right now. i also have the OEM GT4 backing plates. to install them, I had to remove the wheel bearing from the hub with the four large bolts that come in from the back side of the hub. what is the correct torque for re-installation of those bolts?
Thanks |
12-27-2012, 12:12 PM | #3 |
115
Rep 1,470
Thanks. Yes, I found 83 ft lbs straight off my bolt torque charts for that size and grade bolt. That is close to the 81 ft lbs you quote.
The deal about replacing those bolts is not necessary. They are not stretched like head bolts. Just use the correct tap and die to clean the residual thread locker off, then clean it up with brake cleaner, let it dry and then use fresh red lock tite. Replacing the bolts after 3400 miles is ridiculous.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
12-27-2012, 12:16 PM | #4 | |
42
Rep 1,463
12-27-2012, 01:25 PM | #5 | |
115
Rep 1,470
I built this. IFS torched off. front axle out of a 1975 4x4 suburban on custom leaf springs. rear axle converted to a full floater with solid axle toyota 4x4 hubs. customized rear disk setup from a supra. custom crossover steering linkage. dual transfer cases. 4.88 gears and ARB lockers. it is sitting on 38.5x14.5-15 TSL SX tires for size reference. i can make my way around bolt removal and installation. |
