05-10-2024, 10:31 AM | #1 |
20
Rep 18
Engine Caps Dressup
I was wondering if anyone had any experience with the Verus Engineering Fluid Cap set and confirm if they fit on the B58 for the X3. Also what other alternatives have others tried and worked.
I messaged Verus directly and they were not able to confirm if the set would fit on the X3. This was their response to me; "Unfortunately, we cannot confirm. The only models we know 100% all these caps will work with are the (G20) M340ix, (G42) M240i, (G22/G23) M440, and (G29) Z4. Even though the engines are the same (B58), BMW has used different OEM caps from model to model. It's possible one or two or the caps may fit, but it's also possible that none of them will fit." https://www.verus-engineering.com/sh...ory=57#attr=41 https://www.verus-engineering.com/sh...ry=57#attr=183 |
05-10-2024, 10:42 AM | #2 | |
Your Average B58'er
306
Rep 253
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
05-10-2024, 01:03 PM | #3 | |
3410
Rep 1,840
Drives: 2022 X3 M40i
05-10-2024, 03:24 PM | #4 |
20
Rep 18
Thanks for your reply and the pics. So I guess the guy from Verus was right, even with the same B58 engine, BMW uses different OEM caps from model to model.
