12-14-2019, 07:21 AM | #67 |
141
Rep 395
I just enabled the lane change assistant
Would also like to extend the time the car can drive without hands on the wheel when in bad traffic. The most important feature for me (if possible) is if the car is in electric/hybrid mode and you kick down the pedal, to make it jump into sport mode without pressing any button. Has anyone found codes for anything like that? |
12-14-2019, 11:29 PM | #69 |
30
Rep 44
12-15-2019, 09:47 AM | #70 | |
Rep 17
are you on iDrive 7 or 6? I am afraid on iDrive 6 it does not work -_- I do not see any option for screen mirroring when connecting my Android device. Do I need to have any specific app on the phone? |
12-15-2019, 10:19 AM | #71 | |
55
Rep 243
Where should it show up? In climate rules? |
12-15-2019, 02:04 PM | #72 |
208
Rep 547
Just to make sure but along with that AKT_Auto_Lenkrad and LHZ_CCM_IKF need to both be enabled. And yes if you hit the menu A/C button it should show as an option as shown in the picture in the first post.
Current: 2020 M340xi Previous: 2016 340xi |
12-15-2019, 04:08 PM | #73 | |
55
Rep 243
I didn't realize that it's in its own menu |
12-15-2019, 11:08 PM | #74 |
236
Rep 1,037
Does anyone know if it is possible to enable text message notifications? I do not have the wireless charging option...
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
12-16-2019, 01:19 AM | #75 |
22
Rep 8
[QUOTE=cjof2003;25506884]Getting Started
Start here - https://www.bimmerfest.com/forums/sh...php?p=10193333 NOTE: Do NOT follow the charity donation instructions in the PDF in the link above. Instead, email tokenmaster directly and request the donation instructions. You should receive an auto reply detailing the exact steps and requirements. Follow those and you should get launcher pro 3.x fairly quickly. Once you have all the software installed per the link above, go here - https://www.bimmerfest.com/forums/sh...d.php?t=983245 I had issues getting Launcher PRO to update the cheat codes, so I went to - https://github.com/packetpilot/bmw-f/tree/master/cheats - and downloaded the repository as a ZIP. I then extracted the contents of the cheats folder to: C:\Program Files (x86)\TokenMaster\E-Sys Launcher PRO\FDLCodes Then, in Launcher Pro I selected the Authors I wanted to load. The following are Authors are good to start with for g20 coding (s18a):
So far, I have successfully coded the following:
Hello Would you have a list with all of the coding you've done ? I have already done some basic coding, and some that you mention interest me |
12-16-2019, 04:52 AM | #76 |
Rep 50
Guys,
Some help please, I'm getting the following error message - The NCD file name "Almaretto.xml" has to contain the SGBMID (z.B. cafd_0000000b_001_000_001) of the appropriate CAF. [C011] What am I doing wrong? I have installed and loaded as per instructions, I have a G20 330e if this helps? TIA Charlie. |
12-16-2019, 09:39 PM | #79 |
55
Rep 243
Can someone explain how I can save all the code files to my computer for review?
I want to be able to sit at home and browse the cafd folder, without having to sit in the car connected |
12-16-2019, 09:41 PM | #80 | |
55
Rep 243
[QUOTE=luckyfrederic;25575431]
12-17-2019, 06:38 AM | #81 | |||
345
Rep 751
The list you quoted is the list I have coded. If you dont see an item in the table I posted, it is available through one of the cheat authors I mentioned. Just read and edit the corresponding ECU and you will see the cheats on the right side of esys Last edited by siegester; 12-17-2019 at 06:45 AM.. |
12-17-2019, 06:55 AM | #82 |
29
Rep 22
I see everyone setting only 3 codes for track change, but in the video are made 4 changes. You have made 3 or 4 changes to the codes. I haven't seen anyone talking about this: SICHT_ABSICHT_ENABLE
12-17-2019, 07:00 AM | #83 | |
22
Rep 8
Feature ECU Property Value seat heat distribution rear HU_MGU HVAC_SEATHEAT_DISTR_FOND aktiv seat heat distribution front HU_MGU HVAC_SEATHEAT_DISTR_FRONT aktiv auto steering wheel heat HU_MGU AKT_Auto_Lenkrad aktiv BDC_BODY LHZ_CCM_IKF aktiv BDC_BODY IKF_ENABLE ikf_alle_sitze lane change assistance BDC_BODY SPURWECHSEL_ASSISTENT aktiv HU_MGU SPURWECHSELASSISTENT gen_1 SAS2 C_SWA_VORHANDED NR001_VORHANDEN not others ? Thanks |
12-17-2019, 05:14 PM | #85 | ||
182
Rep 332
12-17-2019, 09:23 PM | #86 |
345
Rep 751
12-20-2019, 11:45 AM | #87 | |
658
Rep 1,480
Drives: 2020 M340Xi (G20)
I code using my laptop & do "research" & the like on my desktop. The first time I connected, I saved VO, SVT & all CAFD files (using SAVE file in E-SYS). I then copied to USB drive and further copied to appropriate sub directory on desktop's hard drive. There's a simple to copy all CAFD; I'd post it, but am not near it -- but not hard to just copy the respective directories to USB drive Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
