BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
      07-08-2013, 06:14 AM   #1
yoelev
yoelev's Avatar
20
Drives: M3
12,000 miles, 3 rattles
after just fixing (in crude fashion) the "glue coming unstuck" rattle on the drivers side door, and still attempting to figure out the "can't find it rattle in the center armrest/console" i appear to have gotten the worst rattle of all, the "somewhere around the speedometer and you can feel it in your hands while steering" jarring.
a caveat: i live in NYC, and the roads here are pretty bad, lots of potholes which for the most part i do a good job avoiding, but unavoidable bumps etc. am i nitpicking? or are these rattles just the bane of the e9x M3's existance.
anyway, does anyone know how to fix the speedo rattle? don't tell me to press the search button
      07-08-2013, 06:23 AM   #2
jchristianp
Drives: M3 E90
Mine had a rattle coming from the cruise control set button at the end of the arm. This might sound like it's coming from the speedo area.
      07-08-2013, 06:25 AM   #3
yoelev
yoelev's Avatar
20
Drives: M3
yeah it rattles through the steering column but when i pushed on the top of the speedo, it seems to have stopped. trouble is, i can't drive with one arm pushing the left hump up.
and my fix for the glue sticky door jam is to stuff some cardboard on the side.
      07-08-2013, 06:50 AM   #4
yoelev
yoelev's Avatar
20
Drives: M3
i think there's really nothing for it. going to bring it in to see if they can replicate the sound. it's driving me up a wall
      07-08-2013, 07:01 AM   #5
RMB
RMB's Avatar
97
Drives: 2018 Audi TTRS
Maybe try some thin sheets of foam (i.e Lowes or Home Depot), with or without the tape/adhesive backing. Kind of similar to the foam for door jams to fill voids/openings. I have also seen people use felt, but I think the foam is better because it will fill the void better and prevent movement of the plastic. Just a thought.
      07-08-2013, 08:56 AM   #6
mdosu
314
Drives: Double Vanos'd Civic-M3
do you have aluminum trim? My dash rattle was caused by my trim piece. The Aluminum is glued on to a plastic backing, and if not secured, it rattles.
      07-08-2013, 09:01 AM   #7
dmk08
Gone Fishin’
dmk08's Avatar
7318
Drives: Walks
I had a rattle until I replaced my aluminum trim with carbon leather. I still get a little noise when in the stiffest EDC setting. But I run 30 series all around and have H&R springs which are kind of rough.
      07-08-2013, 11:24 AM   #8
thekurgan
Bad Lieutenant
thekurgan's Avatar
233
Drives: E90M3
2008 BMW M3  [0.00]
There is a huge, informative thread here on m3post related to rattles, some of which you have mentioned and there are some creative solutions.
http://www.m3post.com/forums/showthr...t=rattle+index
on the speedo rattle. You can remove the cluster with the two torx screws at the top, and apply some thin automotive felt in areas that touch.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      07-08-2013, 12:11 PM   #9
exmowner
exmowner's Avatar
683
Drives: 22 M3X / 14 GTR
Mind explaining how you fixed this?
2022-G80 Xdrive BG
2014-GTR BE FBO
2016-HURACAN 610-4 (SOLD)
2021-G82 BASE (SOLD)
      07-08-2013, 12:16 PM   #10
mdosu
314
did the same swap, no more rattles in the dash. My rear sunshade still rattle a little.
      07-08-2013, 01:12 PM   #11
yoelev
yoelev's Avatar
20
Drives: M3
well i fixed it sort of by basically wedging a piece of cardboard between the leather insert and the door right by the latch attachement. you can hear the sound of the glue tearing when you wedge the space open. it's really annoying
      07-08-2013, 01:13 PM   #12
yoelev
yoelev's Avatar
20
Drives: M3
nope carbon leather. will report back after my dealer says he can't replicate anything
      07-08-2013, 01:43 PM   #13
deletedelete
deletedelete's Avatar
365
Drives: m
I like how it's assumed the dealer won't be able to replicate the issue. So true.
      07-08-2013, 01:46 PM   #14
CSanto
640
Drives: 2015 BSM/SO M3
i hate my rattles, but i have 51k. I think its the M3 dude, not too much sense in beating yourself up over it.
      07-08-2013, 02:06 PM   #15
bsmack
bsmack's Avatar
Drives: 2011 e92 M3
Mind posting a link for what you would use? I have this noise and would love to get rid of it!
Current: 2011 BMW e92 m3
Past: 2012 Audi TT-RS
2009 VW GTI
      07-08-2013, 02:11 PM   #16
thekurgan
Bad Lieutenant
thekurgan's Avatar
233
Drives: E90M3
2008 BMW M3  [0.00]
Stuff like this from Amazon, it comes in all sort of sizes and thicknesses.
http://www.amazon.com/JVCC-FELT-06-P...utomotive+felt
      07-08-2013, 02:14 PM   #17
thekurgan
Bad Lieutenant
thekurgan's Avatar
233
Drives: E90M3
2008 BMW M3  [0.00]
I removed the door panel and applied some krytox to the areas where the panel meets the steel. Invisible and solved. OPening the door panel actually leads you to find more sources of rattles. The bowden cable moves around too much, the clips at the top need lubrication with krytox, the bowden cable can use lubrication, all the door clips can have their gaskets deterioriate and need replacement (dirt cheap), removing the window/lock switch mechanism and using some krytox eliminates the "creak" from that shitty plastic used by BMW.
      07-08-2013, 07:26 PM   #18
yoelev
yoelev's Avatar
20
Drives: M3
I totally hear you and i appreciate. You're right of course. I guess the fact that this latest rattle is impacting my feeling of the wheel in my hands really set me off. I will have the car for a long time, I know I will have to get used to the rattles. But really? In my hands?
      07-08-2013, 09:25 PM   #19
debraarzn
Drives: bmw
      07-09-2013, 09:11 AM   #20
CSanto
640
Yeah true. You should be able to find that one and fix it. I've found a few here and there and have fixed them. This car definitely isn't for people with OCD haha.
      07-09-2013, 09:29 AM   #21
thekurgan
Bad Lieutenant
thekurgan's Avatar
233
Drives: E90M3
2008 BMW M3  [0.00]
This may be coming from the steering column mount(s), under the dash. Do you get this when going over small bumps at slow speed, like an EMS street reflector or a Bott's dot?
      07-09-2013, 09:43 AM   #22
yoelev
yoelev's Avatar
20
Drives: M3
actually no its when i go above say 45mph. and it's always there. no matter the smoothness of the road. i think it has to be something in the speedometer section but im very hesitant to open it up.
m3post
