Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions G20 US spec headlights compared - LED (base), Adaptive LED (ZCV) and Laser
      01-11-2019, 09:14 PM   #67
stvding
stvding's Avatar
662
Drives: G20 M340ix
Originally Posted by jlin101 View Post
Originally Posted by timmahh View Post
Hopefully the law is changed, if it hasn't been already.
https://www.reuters.com/article/us-u...-idUSKCN1ML2UW
Adaptive = Adjusts up/down/left/right
Selective Beam = I use the term VLD (Variable Light Distribution), is what does the magic with high/low beams and diverting light / creating light tunnels for vehicles you're following or vehicles that are approaching you. The gov. also refers to them as matrix lighting [specific to certain headlights/manufacturers it seems] or Adaptive Driving Beams (ADB).
RE: Hardware, it depends on the equipment the vehicle has. In the G30 for example, the base is Adaptive LED and the upgrade is Iconic [Adaptive] LED with high beam assist. Since it's the same hardware + camera used where the feature is permitted, it is simply disabled via coding for the US. It can be manually enabled.
Hopefully what the revised law means is a) going forward, we get to enjoy these features, and b) hopefully a simple update from BMW will enable it for models where it was turned off via software.
That announcement or news is a bit "deceptive," especially for those of us pining for adaptive/matrix-type headlights. It merely stated that DOT was "moving to approve" the new headlights, meaning DOT was receptive to "approving" them. The next phase would be 12-18 months of soliciting public feedback/opinion on such lights (not sure how that's possible when no such lights exist in the U.S.), after which the agency makes the final decision.
Hopefully G20 laser's anti dazzle can be coded. I coded my MY2016 f32 with adaptive LED. It wasn't too hard.
      01-11-2019, 10:23 PM   #68
jlin101
107
Drives: 2018 X3 M40i, 2016 750i
I would be more interested in restoring the US-spec Laserlights to the full brightness like EU-spec cars.
stvding662.00
      01-11-2019, 10:28 PM   #69
stvding
stvding's Avatar
662
Drives: G20 M340ix
Why not both
      01-12-2019, 02:08 AM   #70
sq86
sq86's Avatar
363
Drives: 2013 328i E92 LMB
I believe that selective beam was recently put up for adoption with the NHTSA. Toyota initiated it from my understanding. This was specifically for matrix adaptive beams which seems to be selective but correct me if I'm wrong. It's no longer open for public reply but it was.
Here's the link: https://www.regulations.gov/document...RDOC_0001-2008
Hopefully this gets adopted so we're in unison with the rest of the world.
BMW CCA Member# 481791
Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown
Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black
clee1982797.50
      01-12-2019, 02:56 PM   #71
SpenceRx
SpenceRx's Avatar
243
Drives: BMW 330i EBII
These look like they have a "projector" in them which is nice to see. My 2017 LED headlights look cheap in my opinion without the projector.
alex23642867.50
      01-12-2019, 03:35 PM   #72
alex2364
alex2364's Avatar
2868
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
+1
I'm not a fan of the current reflector style LEDs. I had a F30 with projector style HID and it had better light output.
      01-12-2019, 08:38 PM   #73
SpenceRx
SpenceRx's Avatar
243
+1
I agree. I had a 2013 F30 with HID and I prefer it over these new LED headlights on the 2017.
      01-14-2019, 07:39 AM   #74
themnmd
themnmd's Avatar
1691
Drives: 23 X5MC
Originally Posted by LemonOne View Post
Can you weaponize that laser by coding?
I believe you can 😉, also never been a fan of DRL's
      01-14-2019, 10:38 AM   #75
bimmer456
2963
Drives: 340i
Is LED is base? Though LED has always sucked. So we aren't getting anti dazzle? Just auto high beams.
      01-15-2019, 11:09 AM   #76
volsfan0911
28
Drives: 2017 VW GTI
At this point, that is correct.
      01-15-2019, 11:59 AM   #77
Influence
396
Drives: 2020 X3M, 2016 X5 35i
Check the actual IIHS tests on the headlights. If you look at the results on the 2016 3-series (the closest model year to your 2013), even the "upgraded" adaptive LEDs were pretty lousy - earning a "Marginal" rating. The LED reflector base headlights were rated "Poor." It wasn't until the adaptive LEDs on the 2017s that the headlights actually started performing well, earning an "Acceptable" rating. The standard LEDs are still rated as poor though.
So if both your 2013 and 2017 had the base headlights, they both are pretty lousy. If you had the adaptives on both, the 2017 is significantly better.
      01-15-2019, 02:06 PM   #78
alex2364
alex2364's Avatar
2868
2020 BMW M4  [10.00]
Uh, the F30 LCI in 2016 completely changed headlight design. 2012-2015 F30 had a different headlight design than 2016+.
      01-15-2019, 03:04 PM   #79
Influence
396
Absolutely get the LCI change in 2016 (also the first year IIHS started testing headlights) but there is more to this:
Look at the tests, even the Adaptive LEDs in the optional "lighting package" for 2016 models only scored a "marginal" rating. As of 2017, those same headlights scored a good. Clearly something changed with the actual design/implementation of the Adaptive LEDS in the lighting package between 2016 and 2017, otherwise they would have scored the same.
      03-19-2019, 04:41 PM   #80
Skeewiff03
Cyprus
38
Drives: BMW 320i (G20)
Originally Posted by JayPichardo View Post
There will be 3 different headlights available for G20: LED (base), Adaptive LED (ZCV) and Laser.
any chance we can get the first two pics with the lights on?
      03-20-2019, 04:03 PM   #81
Cobra86
50
Drives: BMW G20 330i M Sport
hope this will help
Appreciate 5
hans007604.50
lyas4.50
otay826.00
      03-21-2019, 11:33 AM   #82
upsidedownfunnel
1996
Drives: 2014 335i
2014 BMW 335i  [0.00]
There were no adaptive LEDs in the pre-LCI cars. What the pre-LCI cars had were the adaptive HIDs (bi-xenon) which were the best headlights for all F30 cars. Adaptive LEDs on the later F30s were 2nd best. Both the base LEDs and halogens for LCI and pre-LCI cars were pretty bad.
      03-21-2019, 11:46 AM   #83
Influence
396
Correct, Adaptive LEDS first showed up for 2016, which were tested by the IIHS and found to be inferior to the adaptive HID/Xenons available for 2016. However, what I was pointing out was that IIHS tested again with 2017 models and there was a category level improvement of the Adaptive LEDS' performance, so BMW must have made some sort of change to the adaptive LEDs as of 2017 to improve their performance. This doesn't mean that they were any better than the Adaptive Xenons, just that the performance of the Adaptive LEDs improved with the 2017 model year.
      03-21-2019, 11:48 AM   #84
Pauleebe
Pauleebe's Avatar
380
Drives: Inbetween BMW's.
Interesting, as I have a 2016. I wonder what the changes were? I guess I'm returning my 2016 soon so it's a moot point. I just didn't realize this.
      03-21-2019, 04:04 PM   #85
upsidedownfunnel
1996
Drives: 2014 335i
What you say is confusing. You said this in response to someone who was saying they liked their HIDs better:
Which seems to imply that you think their 2013 was similar to the 2016 adaptive LEDs. Maybe I'm just misunderstanding, but why would you try to contradict someone saying they prefer their HIDs over any adaptive LEDs, if you now are saying that the HIDs in fact might have been better.
Probably just a misunderstanding. The Adaptive HIDs are visually better for the F30. I'm sure they've figured things out by now for the G20 generation since there certainly are very good LED headlights in production with other cars now.
      04-03-2019, 05:43 PM   #86
Dallas TX Wes
Drives: 2016 BMW X1 (current)
I've noticed a couple of US-spec cars that have the Adaptive LED headlights (S5A4A) without the convenience package. Examples:
  • WBA5R1C58KAJ99382
  • WBA5R1C51KAK08052
Any ideas on whether this is simply a fluke or something that can be ordered?
      04-03-2019, 09:33 PM   #87
Pauleebe
Pauleebe's Avatar
380
  • WBA5R1C58KAJ99382
  • WBA5R1C51KAK08052
I may be incorrect, but I thought Adaptive LED's are also included in the M Sport Package/Trim.
      04-04-2019, 03:18 AM   #88
Dallas TX Wes
That is correct since the contents of the convenience package is included in the M-Sport package. These two builds are Sport line, though.
g20
