2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes 340mm to 370mm rotors without changing calipers?
      02-25-2016, 05:09 AM   #23
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by BiscottiGelato View Post
These are much more aggressive wheel offset than the f3x right? Pic of the whole car by any chance??
Yes 18" x 8" x ET34mm all round. OEM MPSS F&R with Birds B1S suspension upgrade c/w F8x front LCA's
Pictures [before yesterday's brake upgrade]
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      02-25-2016, 05:26 AM   #24
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Originally Posted by quenotte View Post
Hi BP,
Do you have all OEM references of what you changed for this retrofit on your car?
Thanks!
Yes, I will post up once I have got an issue with handbrake sorted [rear discs sent were F3x part # ending 6797 600] and correct part number is last 3 digits 598.
Fronts - were items 9, 10, 11 and 12 on the attached
http://www.realoem.com/bmw/enUS/show...diagId=34_1992 Wrt pads, you can go for item # 8 and I got a deal on a set of F8x MP front pads 34112284765.
      02-26-2016, 10:00 AM   #25
quenotte
France
60
Drives: F87N M2 Competition
Hi BP,
Did you get all the hardware used?
I was compiling all parts to do the conversion:
With brand new parts, to change front calipers, front disc protection plate, 4 drilled M Performance discs and pads:
Code:
1	Caliper housing left			34 11 6 799 469			614,83 €		614,83 €
1	CALIPER HOUSING RIGHT			34 11 6 799 470			614,83 €		614,83 €
4	Hex Bolt (chrome-free CR(VI))	M12X1,5X43 ZNS3		34 11 6 772 117			3,17 €		12,68 €
1	Repair kit, brake pads asbestos-free			34 11 6 878 876			211,95 €		211,95 €
1	Brake pad wear sensor			34 35 6 789 440			22,32 €		22,32 €
2	Brake disc, ventilated, w/holes, front	370X30 		34 10 6 797 603			229,85 €		459,70 €
2	Inner hex bolt	M8X14 		34 21 1 161 806			0,90 €		1,80 €
1	Protection plate left			34 11 6 872 081			30,94 €		30,94 €
1	Protection plate right			34 11 6 792 238			30,94 €		30,94 €
8	Hex Bolt (chrome-free CR(VI))	M6X12-Z1-8.8 MK		34 11 6 772 886			0,63 €		5,04 €
									0,00 €
1	Repair kit, brake pads asbestos-free			34 21 6 876 422			141,74 €		141,74 €
1	Brake-pad sensor, rear			34 35 6 792 292			28,49 €		28,49 €
2	Brake disc, ventilated, w/holes, rear	345X24 		34 20 6 797 598			144,85 €		289,70 €
									0,00 €
4	Brake-pad paste (BMW Group)	3G		83 19 2 158 851			0,75 €		3,00 €
									2 469,76 €
=> 2469.76€
M Performance Big Brake Kit in red:
Code:
							Leebmann24		Leebmann24
1	Retrofit kit, sport brake, red			34 11 2 221 445			1 749,00 €		1 749,00 €
									2 038,70 €
=> 2038.70€
It's 400€ cheaper with rear calipers on top of the rest!
Even with used front calipers, Red BBK is very well placed price-wise.
But MPBBK is in red, yellow or orange and my car is EBII...
      02-26-2016, 01:11 PM   #26
BiscottiGelato
BiscottiGelato's Avatar
88
Drives: 09 135i M Sport 6MT
That was my argument. The kit seems like a bargain given that you can sell your blue callipers back out.
Ground Control Camber Plates, Ferrodo D2500 w/ E86 MZ4 2 piece rotors, Dunlop Direzza ZII on Apex EC-7s
      02-27-2016, 05:32 PM   #27
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Hi BP,
Code:
									0,00 €
									0,00 €
									2 469,76 €
=> 2469.76€
Code:
									2 038,70 €
=> 2038.70€
Calipers were bought used but in fact were brand new.
Pads, protection plates, discs and wear sensors - all new.
I also added braided steel hoses and RBF - came in much cheaper.
      02-29-2016, 10:01 AM   #28
quenotte
France
60
Did you have significant discount on new parts?
      02-29-2016, 04:59 PM   #29
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
On some yes.
      02-29-2016, 05:02 PM   #30
rwalker
330
Drives: the wheels off
Originally Posted by Bee Pee View Post
On some yes.
Bee Pee, you're talking about the discounted 370mm calipers in particular, right? I used the same source as you, they're less than half the price of new!
      03-01-2016, 03:31 AM   #31
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
These look good value for anyone stateside looking to upgrade - a pair of 370mm calipers and pads for 620 bucks...:-
http://f20.1addicts.com/forums/showthread.php?t=1231761
Also the thread has a great photo to illustrate the difference between 340mm caliper [top] and 370/380 MP BBK/F30 msport/F8x std front caliper [bottom]
      03-07-2016, 08:43 PM   #32
rwalker
330
This is where I sourced my blue f30 msport / blue MPBBK callipers from. Excellent service and product.
Bee Pee, I've just received a set of calipers from this seller. Took a while to get to the US from the EU...
The part numbers on these calipers appear (I scanned the bar codes on the back) to be 34116799467 and 468, which appear in no ETKA.
Did you verify the part numbers of the calipers you installed?
Thanks,
Rob
      03-08-2016, 02:39 AM   #33
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Hi Rob,
I didn't scan them TBH so can't verify the part numbers you quote. Looking at the markings embossed on your calipers they look the same as mine.
BP
      03-21-2016, 11:47 AM   #34
MrBimmerM235i
105
Drives: M235i
What a mission if you only wanna change rotors...
      03-22-2016, 04:23 AM   #35
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Not really - I got OEM MP BBK upgrade for less than 1/2 the cost.
      03-22-2016, 10:41 AM   #36
BiscottiGelato
88
30mm rotor size change is a huge difference. If this is under $1.5k new rotors included to get 30mm more, that's a steal.
And if u consider selling those old 340mm calipers out to 228 owners, then it might even be less than $1k. Total steal
      03-22-2016, 11:15 AM   #37
rwalker
330
And if u consider selling those old 340mm calipers out to 228 owners, then it might even be less than $1k. Total dtral
for me (haven't yet installed, though)
$700 for used calipers, pads, and clips (same vendor as Bee Pee)
$600 for new 370mm rotors (blank face, not drilled)
well under $1.5k...
      04-02-2017, 12:31 AM   #38
TYC
TYC's Avatar
24
Drives: 2015 M235i TE
so those are the stock m sport calipers ?[/QUOTE]
To confirm you fit the larger Mperf 370mm rotors on the front stock M235i caliper without issue?
@theyoungcarmody
2015 m235i track edition
PTF / Bm3 n55 dev car / brand ambassador
Cscs time attack - street rwd
Who says a race car can’t also be a show car?!?!
      04-02-2017, 12:37 AM   #39
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
To confirm you fit the larger Mperf 370mm rotors on the front stock M235i caliper without issue? [/QUOTE]
No.
Bee pee fitted F3X M sport calipers with the 370 rotors. F2X calipers won't work on 370 rotors I believe
      04-02-2017, 07:13 AM   #40
rwalker
330
F2X front calipers will not work on 370mm rotors. You need front calipers from the F8X, which are the same as the M Performance calipers for the F3X.
rwalker@rwalker.com (I really dislike Private Messaging)
      04-03-2017, 04:35 PM   #41
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Pika - 100% correct
      04-04-2017, 05:14 PM   #42
Dylan86
Dylan86's Avatar
1330
Drives: F15d msport, F22 m235i
Any place online to grab the F3x M-Sport Calipers new, without getting a$$ r@ped? If there were any on the classifieds I'd scoop them up, but not having much luck lately. Missed out on Rob's set...
D
      04-05-2017, 08:24 PM   #43
dukeapenguin
42
Drives: M235i Convertible RWD MT
After research and test on my 235 and friends 228 I don't think there is a real improvement between 340 kit or 370 kit.
Only improvement is 30mm diameter which make a longer torque distance.
The weak point of this break sets I believe is disk, everybody changed pads but the fixed solid disk really making some issue when it get heated.
Get a floated disk, thats make the new world.
2addicts
