07-22-2015, 07:47 PM | #67 | |
258
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
07-22-2015, 08:40 PM | #68 |
920
Rep 1,481
Now that No-Glare HBA is working as it should , here are my Top 10 (in order of preference):
1. Euro MDM 2. VLD + No-Glare HBA 3. Tail lights on with DRLs 4. No iDrive and cameras disclaimer 5. Shorter seatbelt reminder 6. Unlock doors at ignition shutoff 7. Separate Ambient Lighting and Instrument Cluster Lighting levels 8. Enhanced Bluetooth 9. Door handle lights on in Reverse 10. Shorter Comfort Access trunk opening delay Number 7 is a must IMO with black leather interior, since the Ambient Lighting is otherwise barely visible. Edit (8/16/15): I figured I might as well update my Top 10 to keep them current as I try additional features. So here is my updated list: 1. Euro MDM 2. VLD + No-Glare HBA 3. Updated M-HUD 4. Tail lights on with DRLs 5. No iDrive and cameras disclaimer 6. Shorter seatbelt reminder 7. Unlock doors at ignition shutoff 8. Separate Ambient Lighting and Instrument Cluster Lighting levels 9. Easy Entry 10. Enhanced Bluetooth
2015 Mineral Grey ///M4 6MT
07-22-2015, 09:39 PM | #69 | |
Christmas Poo
1099
Rep 1,212
I've seen this function but never programmed it to test it out.
07-22-2015, 09:50 PM | #70 |
920
Rep 1,481
The key issue is the accent lighting built into the doors. On light-color leather (e.g., SS), this is clearly visible, but on black leather it is very subtle indeed. Once you decouple the two settings, the Ambient Lighting becomes brighter. You then adjust the brightness of the Instrument Cluster with the controller next to the light switch and the brightness of the Ambient Lighting in iDrive.
07-23-2015, 06:58 AM | #72 |
920
Rep 1,481
Either FDL code
REM > MAPPING_TAGFAHRL_H_L_OUTPUT = "sl_l" REM > MAPPING_TAGFAHRL_H_R_OUTPUT = "sl_r" REM > MAPPING_TAGFAHRL_H2_L_OUTPUT = "sl_2_l" REM > MAPPING_TAGFAHRL_H2_R_OUTPUT = "sl_2_r" or, if you prefer, add 8TL to VO and VO code REM.
07-23-2015, 07:00 AM | #73 | |
172
Rep 383
07-23-2015, 07:14 AM | #74 | |
Christmas Poo
1099
Rep 1,212
07-23-2015, 07:25 AM | #75 |
920
Rep 1,481
Yeah, if you have Ambient Lighting maxed out in Settings > Lighting, you should definitely give this a try. You will probably want the setting in iDrive at less than maximum afterward.
07-23-2015, 11:23 AM | #76 |
26
Rep 131
What is the code for this? I set 3040 → CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK set to: aktiv and it doesnt work. Not sure if turning off MMI with door is open interferes 3020 → TCM_LOGIC_R_OFF_DOOR set to: aktiv |
07-23-2015, 11:47 AM | #77 |
920
Rep 1,481
That is the code. It works (at least, on my car), but only if the doors were auto-locked.
07-23-2015, 12:39 PM | #78 |
26
Rep 131
The doors auto lock once I start driving. When I stop and turn off the car the doors auto unlock but the seat does not move. Might be because its a 6MT? might be hard to start car if seat is pushed back.
07-23-2015, 12:58 PM | #79 | |
920
Rep 1,481
The one to have the seat move back should be SM > EINAUSSTIEGSHILFE (set to "Modus_FA" if you want only the driver's seat to adjust, "Modus_BF" if you want only the passenger's seat to adjust, or "Modus_FA_SLV" if you want both seats to adjust), but I have not tested it on my car. Edit: I finally tested this. EINAUSSTIEGSHILFE needs to be set to "Modus_FA_SLV" or it is ineffective.
07-23-2015, 03:24 PM | #80 | |
26
Rep 131
I was doing a lot of different coding yesterday. And both those items were not working correctly. But I was testing the auto unlock incorrectly. I was just sitting in the garage, turning the car on, locking the doors then turning the car off. You solved one of my issues. Thanks. Now to figure out why the auto moving back of the seat does not work. I coded this also. |
07-23-2015, 09:18 PM | #81 |
1596
Rep 3,945
Drives: 2015 M4 MG/SO
Ok was confused by the wording, thanks for confirming. I wish that we could switch off the engine and electronics from the Start button with one press.
07-23-2015, 09:23 PM | #82 | |
258
Rep 1,309
Drives: YMB M3
07-23-2015, 09:39 PM | #83 | |
11829
Rep 15,400
Try driving the car with setting that are meant for it.
07-24-2015, 12:00 PM | #84 |
111
Rep 1,338
you mean the understeer button? i hate the throttle (over)sensitivity in sport-plus mode. throttle modulation is far better in efficient or sport.
07-24-2015, 12:07 PM | #85 | ||
11829
Rep 15,400
Btw thanks guys for this list, I'm finally getting mine sorted this weekend and your lists have been good reminders.
07-27-2015, 09:41 PM | #86 |
63
Rep 274
Drives: 2007 e90 335i
I got this list off of here somewhere. Helped me decide what I want/don't want. At least it gives you most of the possible options.
ED 7/7/15, PCD 9/3/15: 2015 F82 AY with Full Blk & CF Trim, 6MT, ZEC, 19" Blk, HK, 2VF, Top & Side Camera's
BMWCCA referral # 385285 |
07-27-2015, 09:46 PM | #87 | ||
11829
Rep 15,400
He did more but I'm so cool I forgot them already.
07-28-2015, 07:49 AM | #88 |
Useful Idiot
1330
Rep 1,777
Drives: My wife and kids insane.
There are a ton of F30 cheatsheets out there which will give you more coding options than you can shake a stick at.....but it's worth noting that not all F30 coding options will work in the F8x. Personally, for coding i've used a combo cheatsheet trifecta of F10/F30/F80 references.
Btw, Lups I coded a ton in my car as well and I think i've forgotten the bulk of them....lol. Some features I will never actually see work (like the Emergency Braking triple flash). The one item that I initially coded and then changed back to default was setting the idrive to instantly power off when you open the door. It initially annoyed me that the car would just continue playing bluetooth music or whatever as I walked away until I locked the car. But after coding this to shut off, I found that I was more annoyed at not being able to continue listening to either music or sports talk radio while getting gas. So I went back in and re-coded this back to default.
