05-02-2024, 05:28 AM | #1 |
Rep 36
HK stereo cutting out after sub and amp install please help
HK speakers cutting out after about 30 seconds of listening then popping. Sounds like a loss of signal. Please help, just installed sub and amp with technic add a sub harness. Thanks guys
05-02-2024, 07:37 AM | #2 |
8316
Rep 16,199
That may indicate a short circuit in the speaker wiring, causing the amp to go into protect mode.
patsf16.50 NealfromNZ554.00 |
05-02-2024, 05:23 PM | #8 |
103
Rep 284
Awesome glad you sorted it out before I had a chance to respond!!
So what did you end up doing for upgrades? I'm getting ready to go down that rabbit hole myself for my F36!! It will be a summer of fun!
2017 430ix Gran Coupe
05-02-2024, 11:54 PM | #9 |
Rep 36
Cool, I built this system from old components I had lying around just used the pnp add a sub harness and hooked everything up. Sounds nice!!
NealfromNZ554.00 Arthurrs102.50 |
05-03-2024, 09:33 PM | #10 | |
554
Rep 538
https://integralaudio.com/phantom-su...coupe-f36.html |
patsf16.50 |
05-03-2024, 10:14 PM | #11 | |
103
Rep 284
The m0bridge K2 8.1.1 might come later in the summer, after a full color correction of my car, PPF and ceramic coat, I have a few chips to fix with a difficult paint finish to touch up (mineral white). Damn this hobby is expensive!! I kept my Earthquake under seat woofers and Morel Hybrid 402 for the front doors from my previous F30 install, so it should be interesting to make a comparison with the HK system. This time around I'll take some response measurements with my Smaart rig before and after the upgrades. I have to wonder if a better passive crossover for the HK door speakers might prove beneficial? I haven't opened the door panel yet to see what is there now, but I suspect it's just a capacitor. I'm waiting for it to warm up. Summer tire swap happening tomorrow if the weather is nice!
NealfromNZ554.00 |
05-03-2024, 11:24 PM | #12 |
554
Rep 538
HK and Hifi just use a single capictor on tweeter and nothing for a low pass filter on the door mid.
But Bill has shared a design for a superior crossover build and component for hifi and HK. It would also work with and improve most aftermarket passive crossovers no doubt. |
patsf16.50 |
05-05-2024, 12:02 AM | #14 |
Rep 36
Thanks, I had an idea of using fiberglass but I got a 1/4 sheet of MDF for £5 and thought why not give it a go and see what happens. So I got the jig saw out, a few swear words and some fettling we got there. It took about a day and a half to sort the box out from scratch. It’s about 15l inside which was the minimum requirement for the sub (focal P 27v2) 300w rms. If anyone is doing a similar setup I would advise using the lowest setting on the crossover, for best results. This things pounds you and it’s clear all the way through the volume range.
NealfromNZ554.00 |
