01-19-2022, 08:28 AM | #1 |
33
Rep 34
Plug and Play Amp upgrade for Base Audio system
Hi all, this isn’t a question, more a very simple solution I have found that I’d like to share and hopefully make someone’s life a little easier and their crap base audio system sound a little better.
Firstly, I’m not affiliated with Vibe. I’m just a guy with an F30 that has base audio and got to the stage where I wouldn’t listen to music because the sound system was crap. I’ve seen a lot of threads in a lot of different forums talking about what upgrade can you do and what coding and wiring do they need to do so. I’ve researched the hell out of this so here’s my two cents for you all. I just bought a Vibe Powerbox 65.4M with BMW T harness. It took about 25 minutes to fit. I had to remove the head unit so that meant removing some trim which was really only 6 torx head T15 (vids on YouTube of course). It came with clear and concise instructions so your technical level doesn’t need to be that high to hook it up. I placed the amp under the glove box between the underside of the glove box and the removable panel. It fit like a dream and no visible wires with enough room for it to breath. I used BimmerCode to change my head unit EQ range to HiFi As someone who’s always had good sound systems and was horrified by the quality of the base audio system, I can tell you that this upgrade is the best €210 I’ve spent. It powers the 4 door speakers and the two sub ls with no extra wiring. Running the stock speakers, the difference is nuts. Although if you push them hard enough, they will crackle. I had to fine tune with gain on the amp for front and rear and mess with some settings on my Apple Music EQ but after that it’s just a matter of adjusting your bass and volume settings through your idrive sound options depending on what you listen to. All in all this was a very simple and effective upgrade to a very lacklustre sound system. I’d recommend it to anyone and I hope this post does someone some good. |
01-19-2022, 11:02 AM | #2 |
144
Rep 171
Thanks for posting this. There are not that many discussions about base audio upgrades on the forum (probably because this is not an available config in USCAN, good for them!)
01-19-2022, 11:14 AM | #3 |
33
Rep 34
No hassle. I said I’d post it because I’ve had a long hard look at what upgrades were available to those on a budget. After shelling out 20k for the car, I wasn’t inclined to go and spend another 1500-2000 just on audio. I’ve been using it all day and apart from having to slightly adjust bass for different songs at different volumes, it’s absolutely mighty!
rytec2.50 |
01-19-2022, 11:27 AM | #4 |
144
Rep 171
Good to read.
I actually proceeded to an upgrade based on: - Changing all the speakers (including subwoofers and adding front tweeters) for decent/high-end ones - adding a Focal 4.320 D-class amp to drive the front speakers (4 ohms - 2x50W) and the subwoofers (2 ohms - 2x80W). No plug and play, I did all the wiring (amp in the boot/trunk). The result is however quite underwhelming, reason why I keep an eye on similar topics. |
01-19-2022, 11:46 AM | #7 | |
33
Rep 34
01-19-2022, 11:53 AM | #8 |
33
Rep 34
I’m my case I have base audio. The head unit has an internal amp but the power output is pathetic. I looked in to upgrading to HiFi from base using all oem equipment and was told to steer clear so I never looked in to it too much more after that. I would assume there are plug and play options for what you’re looking for. Since what I have is a Vibe unit, I’d suggest starting there. I do know from my own research that the Match stuff is not cheap so if you’re budget conscious have a look elsewhere.
01-23-2022, 02:38 PM | #9 | |
Rep 20
We don't have an amp only option (can shed more info on why if you're curious just ask) but we do have some speaker upgrades and more robust / complete systems designed specifically for the F3x for basic, hifi, and harmon kardon that we're super proud of since they've been designed and purpose built from the ground up for the acoustic characteristics of that specific vehicle cabin. Feel free to take a look if you're at all interested (https://integralaudio.com/products/b...eries-f30.html) and if you have any questions of course give us a holler anytime.
Phil
Integral Audio - We make the finest vehicle specific audio systems on the planet. www.integralaudio.com |
01-31-2022, 04:04 AM | #10 |
“M”ing
53
Rep 52
Thanks for posting this OP, my F80 also has base audio and having come from a couple of cars with HK I’m planning an upgrade.
I had seen this Vibe box but no reviews, so this is great. My only concern for the small outlay is that it’s using quad lock pass through, and I’m worried that won’t play well with the MMI Carplay box. Don’t suppose you have one installed? Also Phil - I have your page book marked for review in due course V useful info |
02-04-2022, 08:15 AM | #11 |
Rep 54
Thanks for this post, im in the same situation, base audio with no amp at all. Will first change the speakers (Focal for BMW) and now im searching for this Vibe power that i never heard of.
Question: I already have an Android MMI Box, i can't just have another bypass of this system right? Cheers |
02-04-2022, 09:19 AM | #12 |
8313
Rep 16,198
The weak point of BMW audio isn't the speakers, it's the amplification, be it the Base, Hi-Fi or H-K system. That's where all upgrades should start. Where the speakers are concerned the most improvement will be had with the underseat woofers, if you have sufficient power, and if the speaker is actually better than stock. Most are not, a few are. For instance: https://f30.bimmerpost.com/forums/sh....php?t=1730058
TX55257.50 |
02-04-2022, 09:23 AM | #13 |
69
Rep 164
I installed (only 2!) Focal speakers (ICBMW100L) in the front in my Base audio system. Even that alone was a difference between day and night. The base system is absolutely crap, with this it does sound like a base system should sound. Not amazing, but not crap.
I’ll have a look at the Amp option as well. |
02-06-2022, 02:55 PM | #14 | |
Rep 54
02-07-2022, 03:13 PM | #16 |
Rep 54
02-10-2022, 07:39 AM | #19 |
“M”ing
53
Rep 52
02-10-2022, 08:55 AM | #20 |
67
Rep 240
I went for the Rainbow front speaker upgrade kit and it did make quite a big difference for me (I am mot an audiofile by any means) and I then left it at that.
You get separate tweeters and mid bass speakers with this upgrade, which really makes a difference in my opinion. I got them when they first came out and the cost about £340, but I think you can get them now for about £230 now! You will need to get the window plastic surround from BMW to house the tweeters - I think that they cost me about £50 for the 2!? HTH Andrew |
02-10-2022, 10:22 AM | #21 | |
“M”ing
53
Rep 52
Found these, not sure if the same as you have? https://www.raysmith.co.uk/products/rainbow-bmw-e-f-series-il-c4-2-mix-component-speakers Already have the covers, but thanks for the heads up |
Tags |
amplifier, audio, base, upgrade |
