ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      05-25-2022, 11:24 AM   #1
wyshyvanuk
456
Drives: 2008 Z4 MR
BlueBus
Are there any differences between removing the trunk rear bulkhead panel on a roadster and removing it on a coupe? I'm about to install a Bluebus unit. Lots of coupe pics and instructions but I haven't seen anything on the roadster. Thanks!!
      07-12-2022, 12:59 PM   #2
WAGMI
21
Drives: '08 Z4MR
Just ordered a bluebus for the roadster too, looking to see if you ever found the difference?
      07-12-2022, 01:26 PM   #3
wyshyvanuk
456
Drives: 2008 Z4 MR
Greetings. I haven't attempted the installation yet, but I've received some TIS pages from Ted Salmon with BlueBus. If you PM your email address I'll forward the email string.
Thanks,
Ted
      07-25-2022, 09:17 PM   #4
mothy5000
mothy5000's Avatar
Drives: '08 BMW Z4 3.0si E85
I installed mine in my roadster. Extremely easy. There is a YouTube video on it.
      07-25-2022, 11:08 PM   #5
Clearancediver
97
Drives: 2004 Z4
If you drill down further in the software link on the website… there is more info on install etc.
Sent from my smart phone...
      07-29-2022, 04:13 PM   #6
wyshyvanuk
456
Drives: 2008 Z4 MR
mothy5000: Did you locate any E85 specific instructions? I've looked both on the BlueBus site and on YouTube, but without success. Am I overcomplicating the installation?
Thanks,
Ted
      07-29-2022, 07:43 PM   #7
Clearancediver
97
Drives: 2004 Z4
Look at the links available here…
https://github.com/tedsalmon/BlueBus...rmware-Upgrade
Install of a 2007…. https://www.bluebus.dev/install
And a Google search results page of install on Z4…
https://www.google.ca/search?q=Blueb...;client=safari
      07-30-2022, 03:03 PM   #8
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Does the Z4 require an additional adapter? Also, does this mean you have to give up Sirius/XM stock unit?
      09-12-2022, 07:19 AM   #9
bob'smerlot
11
Drives: 2004 bmw z4 3.0i
Realize this is an older post, but was hoping there might be an answer......
Bueller?
      09-16-2022, 10:44 PM   #10
DRandall
Drives: 2003 BMW Z4 e85 2.5i
I’ve ordered a bluebus unit and am waiting. in thr meantime, I went in my trunk and found the necessary connections. There are 2 connectors hidden in the wiring bundle for a CD changer. And, if you are going to add bluetooth phone integration, there is a 54pin port that you’ll also need. If you have the nav system, then there is a silver telematics unit a bit larger than a paperback book. you disconnect the 54 pin cable from this unit and use the bluebus adapter to connect it. The hardest part was getting to the wires. pulling up the carpet by the rear trunk wall is a serious PITA. The actual install should take about 10 minutes, if that. there is a pull tab that pokes through the carpet. I cut 2 horizontal and 2 vertical slits in the carpet to push it through. There are also a number of plastic carpet rivets that are bound to break when you remove them. I bought a bunch of replacements for when the unit is installed and the carpet goes back in place.
      01-08-2023, 03:22 PM   #11
mothy5000
mothy5000's Avatar
Thanks,
Ted
/Sorry for the late reply. Did you get yours installed? Ted has a YT video on the BB website for e85s. The e46 is pretty much the same. I velcroed mine to the trunk side of the back wall just behind the center console compartment.
      04-06-2024, 02:37 PM   #12
homebrw
homebrw's Avatar
Drives: 06 Z4 MR, 22 Mustang GT PP1
Hi. I am currently on the struggle bus. I have found zero videos of an E85 roadster. Carpet sucked. Still wasn't able to remove it at top. I can only find one wire (3 pin) behind amp. Anyone know of a video for the Z4 M Roadster?
      04-24-2024, 02:44 PM   #13
Auelox
Auelox's Avatar
Drives: 2022 X5 M50i
2006 BMW Z4MR  [0.00]
2022 BMW X5 M50i  [0.00]
Take a look here; https://www.zpost.com/forums/showthread.php?t=1746682 and https://www.zpost.com/forums/showthread.php?t=2095223
zpost
