04-23-2013, 06:20 PM | #24 |
127
Rep 938
fyi - best prices i found are 2wheelpros.com for the tank, and fcpeuro.com for the hose.
i suspect ill have extra length of hose if anyone is interested.. |
04-23-2013, 06:21 PM | #25 |
BimmerPost Supporting Vendor
8268
Rep 18,855
Drives: BMW
Coolant reservoir on the Supercharger.
04-24-2013, 12:51 AM | #26 | |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
04-24-2013, 06:42 AM | #27 |
115
Rep 1,470
You should be able to walk into any dealer, find a 3 series, pop the hood, and if it has it just get the VIN number off the car. Then any dealer parts counter can get it for you.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
04-24-2013, 11:08 AM | #28 |
8268
Rep 18,855
Drives: BMW
P/N: 32416767161, (#1 in diagram), about $30 from your local dealer and fits within the OEM bracket. The M3's return line is a bit smaller than the reservoir's, so a step-adapter is needed - which can be obtained at any local auto parts store.
Assimilator1595.50 |
04-25-2013, 08:01 PM | #29 |
IG: limited.slip
335
Rep 1,922
Well here's what I did.
Parts: * Rear brake fluid reservoir from the BMW F650GS PN# 34 21 7 706 055 * 2 feet of vaccum line (Napa) * 90° fitting is a 5/32" elbow connector PN#9873 (Napa) * 1 M6 bolt (+ M6 washer) Total cost: less than $40. Notice the logo on the cap? Yup, Brembo! Also notice the nipple on the cap is angled so it fits perfectly bolted to the ground bolt thingy on the side of the engine bay without bending the line. I used a little under 2 feet of line just so I can unscrew/screw the cap without disconnecting anything. I'll find out next weekend if this setup works as expected. Last edited by kaiv; 06-24-2013 at 07:20 PM.. |
IamFODI365.50 |
04-25-2013, 11:36 PM | #30 |
894
Rep 9,034
kaiv, thanks for the info.
Any info on the bolt? This is a must do.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-26-2013, 12:14 AM | #31 |
IG: limited.slip
335
Rep 1,922
Important note: I just realized there is a seal in the reservoir. You want to remove that seal. Just open the cap and pull it out with plyers. This is only meant as an overflow tank and the PS system still needs venting to function properly.
Aus: the bolt I just found in my box of misc random hardware. Any bmw bolt with a 10mm head should work provided it's not too long. |
04-27-2013, 04:08 PM | #32 |
68
Rep 869
^ This is a great idea!
To create an air vent, could you just puncture the top of the black on the overflow reservoir? I doubt that enough fluid would backfill that distance to actually overflow that container... I'm definitely going to get these parts. This has been a recent source of frustration after every track day. Thanks!
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
04-28-2013, 09:03 PM | #33 |
IG: limited.slip
335
Rep 1,922
Yeah I thought of that and that would work fine (as far as venting), the issue I see with that is not fluid filling the little tank to the point overflowing, but rather the pressure/heat creating a mist that could potentially dirty the engine bay out of that hole just like it did out of the original reservoir cap.
I want to say it's unlikely given the length of hose I'm using but either way I don't think it's necessary to poke a hole in the cap. I blew through the hose to check venting and there is (with cap tight and seal removed). In any case I will be testing this setup on Friday and will report back! |
04-29-2013, 04:56 AM | #34 | |
12
Rep 206
04-29-2013, 07:43 AM | #35 | |
115
Rep 1,470
04-30-2013, 12:30 AM | #36 | |
68
Rep 869
OK. But wouldn't the hole in the original cap also allow contamination? Seems we would just be making that pathway a lot longer with the extra tubing... I will order the reservoir and remove the seal as was suggested. Looking forward to beating this problem. Thanks.
04-30-2013, 06:22 AM | #37 |
115
Rep 1,470
I am talking about a hole on top. Don't pull a hole on top.
05-04-2013, 11:01 AM | #38 |
15
Rep 324
How does that solve the problem of overheated PS oil and possible damage to the pump? I'm more concerned about the possibility of a PS pump failure than with keeping the engine bay clean or not having to top off the PS oil.
05-08-2013, 07:26 AM | #39 |
18
Rep 227
05-08-2013, 07:27 AM | #40 |
18
Rep 227
05-09-2013, 02:35 AM | #41 |
IG: limited.slip
335
Rep 1,922
Took my car to Chuckwalla last weekend (~100 degrees, half hour sessions etc) and I'm happy to report that the catch can worked exactly as expected! No mess in the engine bay!
rnr_m34.50 Assimilator1595.50 |
05-09-2013, 10:19 AM | #42 |
12
Rep 206
Here are photos of the reservoir with the number on the bottom of it and on the cap. I hope this helps. And also a photo of the whole in the screwthread thread.
I'm glad to hear it works well for you too. |
05-09-2013, 04:04 PM | #44 | |
Smiling Politely
1383
Rep 29,118
This looks like a good solution. My last track day resulted in oil all over my right fender.
I guess I will just need to keep an eye on my oil level to make sure the pump doesn't get starved.
