BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      01-04-2015, 11:28 PM   #133
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Adding engine mounts to my list.
Mine were done at 50k. Bimmerworld track mounts installed yesterday and the car feels great.
      03-07-2016, 12:53 PM   #134
hayes180
hayes180's Avatar
398
Drives: E92 2013 M3
2013 E92 M3  [10.00]
Power steering: No issue to report
Brakes: destroyed stock pads, upgraded to Endless MX72, going in for change in rotors. Using Castrol SRF brake fluid.
Engine: 28K, 6 track days in the last 9 months. All conditions normal.
Bushings & Subframe: Nothing to report.. yet
Discuss..
Right wheel baring was replaced. Oil change every 5K miles 10W60 BMW M Performance.
March 5/6: this weekend at Buttonwillow car went into limp mode with a transmission malfunction, limited gear continued driving is possible... etc, etc (already a thread on this).. Taking it into the dealer this week (as I'm under warranty) and will see what comes from it.
      03-11-2016, 03:56 PM   #135
RickyBobby
RickyBobby's Avatar
108
Drives: M3
2016 update. I replaced my subframe, differential, and front control arm bushings with all metal parts. The old ones weren't in horrible shape, but the car wandered a bit similar to the sensation of slightly under inflated tires.
The new parts made a noticeable difference!
      03-12-2016, 03:38 PM   #136
admranger
Retired Curmudgeon
admranger's Avatar
2989
Drives: ‘19 X3M40i
Originally Posted by RickyBobby View Post
2016 update. I replaced my subframe, differential, and front control arm bushings with all metal parts. The old ones weren't in horrible shape, but the car wandered a bit and gave the sensation of slightly under inflated tires.
Any change in NVH?
Miles on car when you did the change?
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      03-14-2016, 02:53 PM   #137
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Any change in NVH?
Yes the differential bushings added quite a bit of gear whine. Nothing noticeable from the rear subframe or front control arm bushings in terms of nvh. I really like how the car feels with these parts so the trade off is worth it to me. Especially the crispness in the drivetrain.
      09-19-2019, 01:26 PM   #138
Richbot
2761
Drives: Jerez Black E90
I don't have much to add here, ever, really, because I track my car extremely rarely, but I tracked it again at 121,000 miles and change, for a light two-session day, last weekend, and the car performed flawlessly. It's one of the things that makes me love these cars so much, if it's running, it's probably running real good
Stuff like this is why I tell everyone to buy one. $15-20k for a car that can do all this and still be nice and relatively reliable for a fast car? How are there any still available?
      11-18-2019, 09:16 PM   #139
MasterP
722
Drives: All the M's
I'm at the point the only significant consumable i forsee continuing are suspension rebuilds and wheel bearings.
I do rod bearings every two seasons. Spark plugs every two seasons and ignition coils as they go.
My car makes all sorts of whines and buzzes now since poly engine mounts and trans mounts.
      05-08-2021, 11:20 AM   #140
m3peat
71
Drives: 2009 E90 M3
Reviving this for the 150k+ milers still tracking their cars.
I'm closing in on 150k and have only autox'd the car with no problems, other than the driver.
As I'm thinking of getting back into tracking the car with less and less autox venues available, I would like to address known issues on higher mileage cars.
I have done general maintenance (fluids/filters/plugs etc) way more than 'required' per BMW but what other things should I be on the lookout for at this mileage?
I have replaced the alternator after it went bad @118k, TA's (took a dump at 142k), Bearings, engine mounts (@94k but probably due for another set), thermostat (twice) and dampers recently (went with MCS singles and stock springs, along with all new rubber parts while in there).
Any other big ticket items I should replace or be aware of before venturing back out onto the track?
thanks in advance
Current: E90 M3
Previous: 15' M235i, 12' E92 M3, 03' E46 M3, 98' E36 M3 4 dr, 95' E36 M3 2 dr
All the above, missed and wish I kept them all.
      05-09-2021, 06:23 PM   #141
nicksm3
nicksm3's Avatar
No_Country
971
Drives: e92 m3 Competition
Alittle over 39k miles, 18,5k Track Day/event miles and it's a dream. Just keep on top of maintenance and it will take care of you!
      05-14-2021, 02:52 PM   #142
redpriest
redpriest's Avatar
2147
Drives: 2011 M3/Porsche 992 GT3RS
thanks in advance
Make sure you have the thermostat TSB harness fix installed or you'll just go through more thermostats.
I keep a set of camshaft position sensors around because those went bad on my car a few times as the engine aged. Ended up having to replace low pressure fuel sensor as well.
Water pump if OEM is probably on last legs. The plastic impeller was busted at ~165k miles.
You already did the alternator, mine died too.
Power steering pump might let go, mine did.
My TAs surprisingly enough at 180k miles is fine.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB
Porsche 992 GT3, 991.2 GT3RS, 718 Spyder
instagram.com/titomanlio
      05-15-2021, 02:48 PM   #143
m3peat
71
Drives: 2009 E90 M3
thank you for the feedback. You have some mileage behind you too.
Did you get codes or warnings for the camshaft sensors and lpfs?
Current: E90 M3
      05-18-2021, 02:22 AM   #144
redpriest
redpriest's Avatar
2147
Yes, you'll definitely get codes for all of them.
      05-20-2021, 05:24 AM   #145
rhyary
rhyary's Avatar
1571
Drives: 2013 M3
My radiator hose just gave up
      08-25-2023, 07:14 PM   #146
danvitmon
75
Drives: 2008 E90 M3 6spd
Figured I'd revive this a little bit, 4 track days this year so far.
Power steering: No issue to report, added GT4 style overflow
Brakes: PFC 11 pads holding up, Motul RBF660 with no issues. Got a front PFC Z54 BBK for cheap, gonna be installing that soon.
Engine: 146k miles, no issues so far. Oil changes every 6-7k miles depending on how many track days. Still on Motul 10w60, might swap to Redline 5w50 after this oil change.
Bushings & Subframe: Bought a set of Millway Delrin Diff bushes, gonna buy solid Bimmerworld SF bushes, already have a set of Revshift orange trans bushes, still deciding on BW engine mounts, or some revshift orange mounts I have on hand.
Driveshaft is completely fucked, the u-joints are toast and I already tore through a brand new CSB. Gonna go with the Seems Legit Garage Shaft since it seems to be decent with no vibrations, cheaper than a Genuine one and way cheaper than a cf one.
      11-16-2023, 11:37 AM   #147
Thumbie
Thumbie's Avatar
99
Drives: 2011 M3/4/6
I also would love to see some updates from those that were originally posting here 5+ years ago. I've only done one track day so far and the car runs great.
There is someone on one of the Facebook groups with a bright green e92 that gets raced all the time. I asked him and said there really aren't too many common issues outside of maintenance. No chasis issues.
So the Seems Legit driveshaft ...seems legit??
I'll leave now.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package
m3post
